Official Sony [X9] XBR-55X900A / XBR-65X900A Owner's Thread - Page 415 - AVS Forum | Home Theater Discussions And Reviews
 905Likes
post #12421 of 13617 Old 11-02-2014, 11:33 AM
looneeii's Avatar
Just noticed the "retail" option was still on from the initial setup...oops..
side question...
is there a way to see the uptime of the TV...IE: Service Menu?
looneeii is offline
post #12422 of 13617 Old 11-02-2014, 11:42 AM
Geoff D's Avatar
Quoted: 303 Post(s)
Liked: 335
Heh. Not turning off the demo mode: rookie mistake.
If by uptime you mean the running time, turn the TV off and press these keys on the remote: i+, 5, vol-, on (i/o). A table of green numbers should appear on screen, at the very bottom on the left is three sets of numbers ordered like this: xxxxx-xxxxx-xxxxx, the set of figures on the right (bolded) is the panel operation time.
Geoff D is offline
post #12423 of 13617 Old 11-02-2014, 12:57 PM
looneeii's Avatar
Indeed...lol
And thanks!!
looneeii is offline
post #12424 of 13617 Old 11-02-2014, 04:03 PM
Grndzro's Avatar
Discrete IR Hex Codes
I am looking for discrete IR hex codes for inputs. I have seen a few listed but none are working for my XBR65X900B. Please post the discrete codes.
Thank you!
Grndzro is offline
post #12425 of 13617 Old 11-02-2014, 04:06 PM
** Man of Leisure **
AustinJerry's Avatar
Quoted: 6856 Post(s)
Liked: 3813
This is the "A" thread.
RiED27880 likes this.
AustinJerry is online now
post #12426 of 13617 Old 11-03-2014, 05:33 AM
Grndzro's Avatar
Both the A and B units will use the same IR codes. Thank you for anyone that can help with the hex codes.
Grndzro is offline
post #12427 of 13617 Old 11-03-2014, 11:07 PM
spinachpie's Avatar
Quoted: 144 Post(s)
Liked: 40
Originally Posted by jjnbos View Post
After having looking at Wikipedia a bit more ("motion interpolation" I --THINK--
"motion flow" is really trying to correct for the effect of fast moving objects recorded on video, interlaced video in particular (i.e. football on 1080i) and
"cinemotion" is trying to correct for artifacts related to converting film to video, and video shot in 60i way, way back, and so on.
In other words I think "soap opera effect " is more related to "cine motion" than "motion flow", but motion flow would be more likely to make you sea sick!
At least that would make the names meaningful, and the problems are conceptually unique. But what do I know?
Can you help me achieve the SOE to it's maximum? Just having Smooth on MotionFlow is not enough for me.
I can't find the Cine Motion option?
spinachpie is offline
post #12428 of 13617 Old 11-04-2014, 03:49 AM
Liked: 3813
Cinemotion is the setting immediately following MotionFlow.
post #12429 of 13617 Old 11-04-2014, 01:13 PM
spinachpie's Avatar
Quoted: 144 Post(s)
Liked: 40
Only option I have is CinemaDrive, which I am assuming is the same function
I used to think this set was quite dark, but I then stumbled upon a forum who mentioned turning the auto dimming function off (can't remember what this is called officially in the settings). It made a huge difference to the brightness of the set
post #12430 of 13617 Old 11-04-2014, 01:49 PM
Liked: 3813
What set do you have? The menu doesn't look like this?
If you check the setting listing towards the bottom, there are several Eco settings that should be turned off.
post #12431 of 13617 Old 11-04-2014, 03:39 PM
Geoff D's Avatar
Quoted: 303 Post(s)
Liked: 335
'Smooth' is the strongest motion interpolation mode available on these sets.
CineMotion/Cinema Drive/Film Mode (as it's called on UK sets) is to do with detecting film/video cadence of the image and should be left on Auto.
RiED27880 and Mdjones9137 like this.
Geoff D is offline
post #12432 of 13617 Old 11-06-2014, 05:49 AM
RiED27880's Avatar
Quoted: 154 Post(s)
Liked: 186
Geoff, do you have cinemotion set to "auto" for cable satellite also? I find that leaving it off looks much better for over the air content, but setting it to auto for bluray is a must! It seems to affect the blacks in a way to my eye. am I correct on this? setting it to auto for my dish receiver seems to make the picture a bit darker.
RiED27880 is offline
post #12433 of 13617 Old 11-06-2014, 05:48 PM
Mdjones9137's Avatar
Quoted: 312 Post(s)
Liked: 207
For what it is worth I have my cinemotion on Auto for my cable input but don't notice a diff in the picture when i toggle it between auto and off on my TV. I have comcast cable though. If it looks better off on your system then i would leave it that way. I also may have some settings different than you. For instance I have my black corrector set to Low.
Mdjones9137 is offline
post #12434 of 13617 Old 11-06-2014, 06:14 PM
Liked: 3813
FWIW, when watching DirecTV HD content, I can toggle CineMotion On and Off, and I cannot tell any difference in the PQ. I leave this setting off.
post #12435 of 13617 Old 11-06-2014, 06:54 PM
cembros's Avatar
Quoted: 191 Post(s)
Liked: 42
Quick question. In regards to HDMI 2.0 what features does the TV have and what does it lack? HDCP 2.2, 4k 60hz etc...
cembros is offline
post #12436 of 13617 Old 11-06-2014, 07:16 PM
Liked: 3813
This has been discussed many times. All ports are HDMI 2.0, although restricted to 30Hz. HDMI4 has HDCP 2.2, and is used currently to accept content-protected material from Sony media players such as the FMP-X10. The TV does not have the HVEC codec required to receive streaming 4K content from services like Netflix. The FMP-X10, however, does have the codec required for Netflix (and future) streaming 4K services.
post #12437 of 13617 Old 11-07-2014, 04:43 AM
RiED27880's Avatar
Quoted: 154 Post(s)
Liked: 186
that could be it, because I have black corrector set to off. Thanks for the response though
post #12438 of 13617 Old 11-07-2014, 02:48 PM
Geoff D's Avatar
Quoted: 303 Post(s)
Liked: 335
The ports can accept 60Hz 4K signals, but only at 4:2:0 colour sampling and 8-bit depth (so Blu-ray-level colour and gradation, basically).
Geoff D is offline
post #12439 of 13617 Old 11-07-2014, 02:51 PM
Geoff D's Avatar
Quoted: 303 Post(s)
Liked: 335
The Film Mode setting (as it's called on my TV) makes no difference whatsoever to blacks or day-to-day picture quality overall. Its purpose is to ensure that the TV locks on to the correct video cadence of the material it's being fed, i.e whether it's flagged for film or video, hence why I suggest leaving it on Auto.
Geoff D is offline
post #12440 of 13617 Old 11-08-2014, 08:07 AM
LeeSoFl's Avatar
Quoted: 256 Post(s)
Liked: 277
I'm switching over to Comcast xfinity X1 boxes next week. What settings on the cable box should I be using?
I don't think Comcast sends anything through in progressive 1080.
My current Scientific Atlanta 8300 boxes are set to 1080i and I let the 4K televisions take it from there.
LeeSoFl is offline
post #12441 of 13617 Old 11-08-2014, 09:09 AM
Liked: 3813
Same with DirecTV. Only some PPV content is in 1080p. I output everything from DirecTV in its native resolution, up-scale everything to 1080p on my Denon AVR, and only have the display do the final 4K up-scaling.
post #12442 of 13617 Old 11-08-2014, 09:18 AM
Liked: 3813
I keep tweaking my settings PDF. So many of the settings now have a note, "Based on Geoff D's recommendation". Thanks for your input!
Geoff D likes this.
post #12443 of 13617 Old 11-08-2014, 09:54 AM
Quoted: 312 Post(s)
Liked: 207
I have yet to switch to the xfinity x1 but saw a demo in best buy last year when they launched here (not on a Sony TV though) that showed a big improvement with 1080p selected on the cable box vs 1080i. I will be interested in your tests and findings with the 900A.
post #12444 of 13617 Old 11-09-2014, 08:12 AM
m61376's Avatar
Question Help setting up 3D??
I apologize for the stupid question of the day (week??month???)- trying to watch a 3D movie from Starz on demand on Optimum cable and I only see split screen images. First time I've tried out the 3D on my set, so I assume I am doing something wrong (and I did put on the glasses but that doesn't change anything). Is there a special setting I should be using that I'm not (do I have to set it for 3D to watch the 3D)?
Thanks for the help.
m61376 is offline
post #12445 of 13617 Old 11-09-2014, 08:18 AM
Quoted: 312 Post(s)
Liked: 207
When watching 3D on cable you have to go into 3D settings and choose the type of 3D (side by side) in the case of Starz. This extra setup is not required when watching a 3D bluray since the player handles all of this.
Hit 3D button on remote and select the type of 3D based on the image on the screen and then ENJOY
post #12446 of 13617 Old 11-09-2014, 08:30 AM
m61376's Avatar
Wow- thanks for the fast answer! And double WOW for the 3D on this set! I actually bought it because of the passive 3D, but life has intervened and haven't had a chance to enjoy it. Frozen is amazing.
Any recs for good passive glasses for kids? Funny- I had a cheapo paper movie pair and they were awful when compared to the SONY glasses. Anyway, anyone have recs for good kid sized frames? Thanks!!
m61376 is offline
post #12447 of 13617 Old 11-09-2014, 09:05 AM
Liked: 3813
I assume you found the four pair of glasses that came with the TV?
post #12448 of 13617 Old 11-09-2014, 09:14 AM
acermen1212's Avatar
Quoted: 185 Post(s)
Liked: 44
x900
I was wondering about the quality of the HDMI cables and what to buy. I need to purchase longer cables due to a updated installation (new Sony X900 TV) and I will be needing 6 Ft cables. I currently have 3 FT cables from Monster and Audio Quest (overpriced).
I have heard good things from Monoprice RedMere series- 6ft 18Gbps Ultra Slim Series High Performance HDMI® Cable w/ RedMere. But I am concerned weather I need this design at the 6 ft length and the circuit affects that is built into the cable. There is also a Mono Price 6ft 24AWG CL2 Silver Plated High Speed HDMI or 6ft 24AWG CL2 High Speed HDMI® Cable w/ Net Jacket, see links below. Just wondering if any of you have any experience with these cables or suggest others. Also BlueJean makes some good cables such as BJC Belden Series-1 Bonded-Pair HDMI Cable, Looking for su great performance. Thanks.
http://www.monoprice.com/Product?c_i...seq=1&format=2
http://www.monoprice.com/Product/?pg...=4#description
http://www.bluejeanscable.com/store/...hdmi-cable.htm
acermen1212 is offline
post #12449 of 13617 Old 11-09-2014, 09:18 AM
Liked: 3813
Already answered in the X10 thread...
post #12450 of 13617 Old 11-09-2014, 09:29 AM
Quoted: 312 Post(s)
Liked: 207
I save the black plastic real3d ones from the theater for the kids. They are sturdier than the Sony ones and the price is right.
Reply LCD Flat Panel Displays
Sony Xbr 65x900a 65 Inch 1080p 120hz 3d Led 4k Ultra Hdtv , Sony Xbr 55x900a 55 Inch 4k Ultra Hd 3d Led Tv
