Official Sony [X9] XBR-55X900A / XBR-65X900A Owner's Thread - Page 442 - AVS Forum | Home Theater Discussions And Reviews
 907Likes
post #13231 of 13628 Old 10-06-2015, 02:00 PM
impetigo's Avatar
Quoted: 118 Post(s)
Liked: 55
Originally Posted by William Chiu View Post
Maybe it has something to do with which USB port the feed is coming from. I will be getting my Amazon 4K TV tonight. I am eager to set it up to watch 4K videos I made stored on a hard drive as well as watch Netflix 4K with it.
If I find the display, will share here.
If nothing works, Amazon's return policy is pretty easy.
Thanks, the Fire TV works fine (including UHD). The resolution info not displaying is a TV issue I would think, and not a big deal really just annoying.
impetigo is offline
post #13232 of 13628 Old 10-07-2015, 09:47 AM
Quoted: 34 Post(s)
Liked: 5
I have 2 boxes that need HDCP 2.2 and you know the xbr only has 1 hdmi with hdcp 2.2. Anyone try this box to give you more hdmi inputs?
Panlong 3-Port HDMI 2.0 Switch Switcher with IR Remote Control (3 In 1 Out) with HDCP 2.2, 4K at 60 / 30, 3D, 1080P, 1440P Support
http://www.amazon.com/Panlong-Splitt...p+2.2+splitter
Huskers15 is offline
post #13233 of 13628 Old 10-08-2015, 04:47 AM
LeeSoFl's Avatar
Quoted: 260 Post(s)
Liked: 279
You've probably figured out by now, that the (picture) link you posted is a HDMI splitter, not the switch you'd need. This one might work because it specifically says HDCP 2.2:
http://www.amazon.com/Panlong-5-Port...304217&sr=1-21
LeeSoFl is offline
post #13234 of 13628 Old 10-08-2015, 01:33 PM
adamwe's Avatar
Liked: 34
The 5 in 1 is out of stock at Amazon
This one that is 3 in 1 is available.
http://www.amazon.com/Panlong-3-Port...-Port+HDMI+2.0
I received the 3 in 1 switch today. It works great on my 900a. I have the Sony media player, the new Fire TV, and have room for the Roku 4
It does not auto switch correctly for me but that does not matter as the remote it comes with works great.
I would highly recommend this product to any 900a users. This solves the one HDCP 2.2 port problem on our TV.
Adam
adamwe is online now
post #13235 of 13628 Old 10-09-2015, 05:27 AM
LeeSoFl's Avatar
Quoted: 260 Post(s)
Liked: 279
The 2.2 compliant switch has (only) a single HDMI output. The non-HDCP 2.2 switches offer an optical out, and also RCA out plugs.
Does anyone make a HDCP 2.2 switch with an optical output? Do you think the reason they don't is the intentional restriction in 2.2 which wouldn't permit separating any portion of the secured signal?
Thank you.
LeeSoFl is offline
post #13236 of 13628 Old 10-09-2015, 06:40 AM
adamwe's Avatar
Liked: 34
Thank you.
None that i can find I have searched abit, but no results
It doesn't matter with my set up though.
I run optical from the TV to my receiver.
Run the Amazon Fire TV to switch box connected to TV hdmi 4.
Run the Sony media player to switch box, use the hdmi out on Sony media player for sound to receiver.
Run the Roku 4 when its out to switch box, use the optical out on the Roku for sound to receiver.
Adam
post #13237 of 13628 Old 10-09-2015, 10:26 PM
SwedishChef's Avatar
You're referring to the brand new Fire TV that does 4k? Do you have these two issues:
1. Sound output over HDMI at a very low level so you have to crank your amplification to even achieve conversational level volume? To the point where Fire TV remote button presses make really loud sounds, and you dare not switch to another source without bringing the volume WAY down first?
2. The Fire TV won't let the Sony "go to sleep," or even stay switched off?
I'm having both these problems and am planning to send it back if they don't fix it with a software patch soon
Adam
SwedishChef is offline
post #13238 of 13628 Old 10-10-2015, 02:58 AM
adamwe's Avatar
Liked: 34
1- Yes the sound on the Fire TV 4K is low but only on playing movies through Amazon. Netflix and others seem fine to me. Even streaming prime music is normal, but prime movies the volume is low.
2- I don't have the sleep problem on my 65 900a at all. The TV and the Sony media player both stay off when turned off.
Adam
post #13239 of 13628 Old 10-10-2015, 08:00 AM
William Chiu's Avatar
Quoted: 65 Post(s)
Liked: 66
Has anyone with new Amazon 4K Fire figured out a way to view Youtube 4K content on the Sony 65X900A or similar sets?
Also, is there a way to make use of that USB port on the Fire 4K as 4K movie file player?
William Chiu is offline
post #13240 of 13628 Old 10-10-2015, 08:17 AM
TweakerInWA's Avatar
Quoted: 443 Post(s)
Liked: 212
Does the Fire decode VP9? If not, then no..check the specs
Sent from my SM-N910T3
TweakerInWA is offline
post #13241 of 13628 Old 10-10-2015, 07:30 PM
falconhawke's Avatar
4K Fire Tv Streaming and NETFLIX 4k/ YouTube 4k on XBR65X900A
Imp, you said:
Originally Posted by impetigo View Post
One thing though, is there no way to have the TV display the source input resolution? I hate that hitting "display" doesn't show "3840x2160" or any source info, at least for when I have the Fire TV connected. At least that would be a little bit satisfying.
I have a 65X900A, and have recently connected the new Amazon Fire TV 4k to the HDMI4 input, grouped along with HDMI 1,3 at the bottom of the set.
When FIRE is connected to HDMI 4, if I am watching a streaming Amazon Prime UHD video, the Sony briefly displays a resolution of 3840 x 2160, after pressing the 'Home' button and selecting the input (4) where the FIRE is connected.
When I view the FIRE TV / NETFLIX home screen showing videos available, while I am in the selection menus this same button press shows 1080p on that input, and then after launching the 4k vid, the same button presses immediately indicate that the Sony is displaying a
UHD 3840 x 2160 4k source. Very nice.
As far as I can tell so far, the 'Display' function of the Sony remote does not function at all with the FIRE TV, thus requiring the use of the 'Home' button to see what is going on with the source the Sony thinks it is getting.
At the moment, doing the same steps as described, but using the FIRE TV's 'YouTube' app to play 4k vids (including Samsung/Sony 4k demo vids there), I can only get a 1080p indication from the Home/Input button presses, whether in the YouTube home selection screens or during the actual 4K vid playback.
Again, the 'Display' button does absolutely nothing with the FIRE.
However, IMO the FIRE TV/YouTube vids look great, even though it seems that they are 1080p, or at least the Sony thinks they are, as do I.
Here is a VP9 info page I found: http://www.tomsguide.com/us/what-is-...ews-18221.html
Here are the supported formats on the FIRE from Amazon: "Content Formats Supported Video: H.265, H.264, Audio: AAC-LC, AC3, eAC3 (Dolby Digital Plus), FLAC, MP3, PCM/Wave, Vorbis, Dolby Atmos (EC3_JOC), Photo: JPEG, PNG, GIF, BMP"
I am wondering if, as you said, that is why I see no indication that the FIRE TV/YouTube app is playing 4k UHD, or is it something else? Does no VP9 on that list really mean that any 4k YouTube video is limited to 1080p?
falconhawke is offline
post #13242 of 13628 Old 10-10-2015, 08:34 PM
Roku 4 Specs for XBR65X900A
If the FIRE TV can't play 4k YouTube, the Roku 4 should, but VP9 on the Roku is 30fps only, whereas HEVC is 60fps. Here are the Roku 4 specs from their site :
Tech specs:
Networking
802.11ac MIMO dual-band wireless
10/100 Base-T Ethernet
Video Outputs
Up to 4K UHD (3840 × 2160) on 4K UHD TVs
Up to 1080p HD (1920 x 1080) on HD TVs
Up-scales 720p to 1080p HD on 1080p HD and 4K UHD TVs
Up-scales 1080p HD to 4K UHD on 4K UHD TVs
4K UHD 60 fps HEVC Playback
4K UHD 30 fps VP9 Playback (YouTube)
Playback from USB drives
Audio Output
Dolby Digital Plus 7.1 surround sound passed through via HDMI or optical output
Storage Expansion
microSD card port for additional game and channel storage
USB port for personal media expansion
Remote Control
Enhanced remote with voice search, point anywhere use, headphone jack, and motion-control for gaming.
Player includes IR receiver, compatible with various universal remotes.
Speaker for Remote Finder alerts
Power Consumption
12.4W (typical) when streaming 4K UHD video
Power Input
12V – 1A power adapter
USB Media Formats
Video: MP4 (H.264), MKV (H.264), HEVC (H.265)
Audio: MP3, Apple Lossless, WMA, AAC
Image: JPG, PNG, up to 4K UHD resolution
Size
6.5 x 6.5 x 0.8 inches
Weight
0.9 lb.
Notice that the specs here mention VP9 video in one place, but not the other.
post #13243 of 13628 Old 10-10-2015, 08:48 PM
Quoted: 65 Post(s)
Liked: 66
Besides the Roku 4K you posted here that can play 4K files from an USB external hard drive, do you know of another such box capable of this?
Tech specs:
Networking
Video Outputs
Audio Output
Storage Expansion
Remote Control
Power Consumption
Power Input
USB Media Formats
Size
Weight
0.9 lb.
post #13244 of 13628 Old 10-10-2015, 08:49 PM
Adam
Thanks for that.
The HD Fury "Integral" here http://www.hdfury.com/shop/splitters...60-444-600mhz/ might help get a 4k streaming signal through older receivers w/o HDCP 2.2.
I have two on the way.
post #13245 of 13628 Old 10-10-2015, 08:52 PM
Sorry, I do not. Perhaps the NVIDIA?
post #13246 of 13628 Old 10-11-2015, 03:02 AM
adamwe's Avatar
Liked: 34
falconhawke:
The display button works while using my Firetv. I have used it on the amazon app and netflix to make sure what I was getting was in 4k. It works every time for me on my 65900a. I use the small second remote that came with the TV.
1- I hit the keypad button on the remote.
2- Navigate to the the word Display.
3- Press center button to select the word Display, and it shows the resolution.
This works every time using the new Firetv Box. I dont know if it works with the Firetv stick but I think it should.
Adam
post #13247 of 13628 Old 10-11-2015, 07:56 AM
falconhawke:
Adam
I might return the FIRE, so far no 4k YouTube, and that may be a box killer for me.
I have pre-ordered the ROKU 4 due later this month as it indicates 4k YouTube ready. Meanwhile, I am working with the FIRE.
Thanks. I tried your suggestion, but it did not work for me. Following your steps, I get nothing. With the small remote, only after I navigate to 'Input' on the keypad screen, then pressing the 'Select' button twice do I get a brief display of the resolution the Sony thinks it is receiving; essentially so far I need to check 'Connected Devices' and select the 'Input' device for the HDMI connection to get the displayed resolution for a few seconds.
Strange. Does your 65X900A have HDMI 4 grouped with HDMIs 1 and 3 down low? I can't think of other settings that might make my TV differ from yours, any suggestions on something I might change to get the 'Display' function operational with the FIRE TV?
post #13248 of 13628 Old 10-11-2015, 08:42 AM
adamwe's Avatar
Liked: 34
Falconhawke:
My TV has HDMI 4 to the right of 1 & 3, but its separate in its own boxed area.
My HDMI 2 is to the side by itself.
Like I said it works on my TV but only with the small remote, pressing display with the standard remote shows nothing.
Adam
post #13249 of 13628 Old 10-11-2015, 09:04 AM
Thanks Adamwe, on mine HDMI 1,3, ad 4 are all next to each other close in line, and HDMI 2 is on the side.
Nothing I do gets the 'display' function to work, and some other issues are there, also.
Being a big user of Amazon Prime, I had hoped the new FIRE would be better, took me like 5/10 minutes to get the freakin' remote open! Apparently, no VP9 support means no 4k YouTube so far.
Disappointed some, probably returning the FIRE this week. Will see what the Roku 4 offers in a few weeks.
post #13250 of 13628 Old 10-11-2015, 09:24 AM
Quoted: 65 Post(s)
Liked: 66
no 4K Youtube App is a mistake as that is the biggest source of 4K publicly available at the moment.
No working app to connect a personal hard drive with 2K/4K videos is the other oversight.
post #13251 of 13628 Old 10-11-2015, 09:27 AM
adamwe's Avatar
Liked: 34
I have the Roku 4 pre ordered
I will be keeping both lol. I like the Fire TV prime music streaming.
I was told a big update for the Fire TV is coming by the 21st. Hopefully thats true.
Adam
post #13252 of 13628 Old 10-11-2015, 04:20 PM
rand0182's Avatar
Quoted: 45 Post(s)
Liked: 24
Question -
I just bought a Denon AVR-S910w
I plan on connecting a PS4, AppleTV, DirecTV and possibly a newer 4K streaming device -
With that said - which HDMI input should I be directing all this to in my 65x900a?
I'm from the U.S. And have a May2014 build date.
rand0182 is offline
post #13253 of 13628 Old 10-12-2015, 09:42 AM
Quoted: 443 Post(s)
Liked: 212
Originally Posted by rand0182 View Post
Question -
HDMI 4, then again if HDCP 2.2 isn't an issue, might not matter. It's been a bit, but I think all are 4K capable, just HDMI 4 is HDCP. ..How soon we can forget lol
post #13254 of 13628 Old 10-16-2015, 04:34 PM
Quoted: 20 Post(s)
Back Light Question
Hey guys. I took this night shot the other night at my house and noticed a strange oval shape light pattern. Is that the way the back light works on these sets (65 900a)? I feel like I've notice dark corners before and I don't really like it...
Sandro Natale is offline
post #13255 of 13628 Old 10-16-2015, 05:54 PM
** Man of Leisure **
AustinJerry's Avatar
Quoted: 7440 Post(s)
Liked: 4140
I suspect that is an anomaly of the photo. I don't notice any unusual unevenness with my display.
Sandro Natale likes this.
AustinJerry is offline
post #13256 of 13628 Old 10-17-2015, 02:13 AM
Jorgens's Avatar
Quoted: 44 Post(s)
Liked: 72
have any of you gents looked in detail at the sony 2014 and 2015 UHD models (using sony's own in house nanocrystal tech) to see how the onscreen picture quality compares to the sony 2013 models (using quantum dot's made by QD Vision)
i have the HD version of your model (kdl-55w900a) and find that the cadmium based quantum dots give a more vivid and life like color reproduction then anything i have currently seen from the major brands in showrooms since (be this from the panasonic or samsung 2015 nanocrystal models, or sony's own implementation in 2015). the higher UHD resolution provides better sharpness and crispness to the image (as 4k should) then my HD, but to me the end result of the video quality on screen of these newer models just doesnt match what sony did for their 2013 range
For the sony 2013 QD models, using a good quality video source (and at high mb/sec, eg on a good bluray disc) can create an almost 3 dimensional immersive effect that adds a great sense of depth to the image, with almost palpable realistic textures. the end result produces a "suspension of disbelief" that makes you forget you are looking at a flat screen in your living room. I just dont get the same sense of video quality from the newer models, however good these new 2015 models are. hopefully future models in the next years will surpass it (as technological evolution should), but it is not quite there yet and imho sony made a mistake in not continuing to use the technology from QDVision. my only criticism would be that i would like more detail in the black range of the spectrum, blacks are good (and i am not asking for oled black), but a minor weak point of this sony 2013 sony QD range (for my HD at least) is that i'd like more detail in the very dark "near total black" .
some of you might have some frustration that the 2013 UHD range from sony didnt fully implement the new UHD standard (for ex using rec.709 color space for UHD instead of rec.2020) but if you are able to get in UHD (upscaled HD) what i see in HD you must have a pretty amazing display that has not been surpassed yet (imho)
what are your observations when comparing your 2013 UHD displays to the recently released 2015 models from sony or the other major brands ?
Jorgens is offline
post #13257 of 13628 Old 10-17-2015, 07:05 AM
Quoted: 443 Post(s)
Liked: 212
I think there are some pretty nice displays out there with amazing picture quality from different manufacturers. I'd take an OLED or FALD panel without hesitation over the 900A ten times out of ten... Not knocking the PQ on the 900A, but you asked....
post #13258 of 13628 Old 10-18-2015, 01:51 AM
luism2008's Avatar
Quoted: 46 Post(s)
I have been using Seagate as my media server connected o my comcast modem wifi connected to my tv.. but all of a sudden when I go the media server choice on the TV as I always have and choose video it now says "there are no items to display" where as before I would see a listing of all the files..
Any one experience the same? Was there a recent TV update that changed the DLNA server?
luism2008 is offline
post #13259 of 13628 Old 10-20-2015, 09:13 PM
Liked: 0
Hi CSPerera,
Apologies for the delayed reply. I have been travelling on work.
So if I buy and install the component, I would be able to view protected content, including netflix?
Sri
Sriraj is offline
post #13260 of 13628 Old 10-22-2015, 04:09 PM
Liked: 0
Originally Posted by ggw2000 View Post
Manufacture date and country is right on the back of the TV on a label.... My X900A was made in Japan in April 2013 and it has the HDMI 4 port by itself over to right. It had the upgrade already done when I bought it.
As far as the X10- stay away from it in my opinion! It is a dead machine that alot of us got burnt on by Sony . Make sure that the Nvidia has all the currently installed apps that you want as there are a lot of promises made that companies today don't bother following through on!!
Having said that the only real way you will know is to buy a 4K streamer and try it...
Gerry
Ok I just purchased the Amazon fire TV 2015 edition with the 4k streaming. When I hooked it up to the hdmi 4 on my Sony xbr55x900a I don't see the 4k categories in Netflix. When I go into the settings in the fire tv it says this under resolution "the selected cdmi port on my tv does not support hdcp 2.2". So from here I know I need the hdmi 4 board swap to get the hdcp 2.2. So now I know the sony reps just told me I was good to go to get me off the phone.
So I called sony back to try and get them to do this and they have me another run around. They said that since I live in Canada, I need the sony fmp-x5 (canadian version of the fmp x10) to do the 4k activation, and since they no longer carry the x5 I am SOL. So is this just their way of telling me to F off? I am pretty frustrated with all this. Has anyone just ordered the cx2 mount and done the swap successfully? I am interested in doing this now since I have no other options. If anyone can help I would be very grateful!
kidcisco is offline
Reply LCD Flat Panel Displays
Sony Xbr 65x900a 65 Inch 1080p 120hz 3d Led 4k Ultra Hdtv , Sony Xbr 55x900a 55 Inch 4k Ultra Hd 3d Led Tv
