Official Seiki SE50UY04 50-Inch 4K UHD Owners Thread - AVS Forum | Home Theater Discussions And Reviews
 26Likes
post #1 of 454 Old 05-21-2013, 09:50 AM - Thread Starter
Sterling's Avatar
Let's collate information on this relatively new low cost 4k LCD TV/Monitor
Seiki Digital SE50UY04 50-Inch 4K UHD 120Hz LED HDTV
I just received mine from Amazon: http://www.amazon.com/Seiki-Digital-SE50UY04-50-Inch-120Hz/dp/B00BXF7I9M/ref=sr_1_1?ie=UTF8&qid=1369154891&sr=8-1&keywords=seiki+4k
Here is a thread I found related to using this TV with 4k quality video/editing etc.
http://www.reduser.net/forum/showthread.php?98027-1299-Seiki-UHDTV-50-quot-SE50UY04-Bought-it-today/page1
Let's update this post with more links to useful information from other AVS threads and forums etc on calibration, uses, problems, etc.
Here is another thread with some calibration sharing in the HTPC area of AVS: http://www.avsforum.com/t/1469063/seiki-se50uy04-50-4k-display/60
EmmaDarknet likes this.
Sterling is offline
post #2 of 454 Old 05-21-2013, 10:15 AM - Thread Starter
Sterling's Avatar
Not exactly reference material, but it does show the TV displaying the OPPO 4k output and up-scaling of Blueray to 4k.
None of my family cares about resolution, but they definitely noticed when I shifted it down from 4k to 1080p. I didn't tell them, they just said it looks 'less good'.
Now I need to figure out some good color/image settings. I'm an amateur here, so any help would be appreciated.
Sterling is offline
post #3 of 454 Old 05-21-2013, 10:31 AM - Thread Starter
Sterling's Avatar
The TV keeps blanking out and coming back on 4k resolution from my OPPO.
I emailed Seiki about it since I've seen a few threads saying this was a Seiki firmware issue.
They just responded and said it's a know issue with OPPO and OPPO is supposed to fix it.
Is that true?
I forwarded that to OPPO to see what they say, awaiting response...
Anyone else seen this particular problem and/or solved it already?
Sterling is offline
post #4 of 454 Old 05-21-2013, 05:07 PM
hdantman's Avatar
What is "OPPO?" I was under the impression that Seiki was working on a firmware fix. I have the same problem--blacks out every hour or so.
hdantman is offline
post #5 of 454 Old 05-21-2013, 05:14 PM
8mile13's Avatar
Quoted: 1705 Post(s)
Liked: 992
http://www.oppodigital.com/ Google is your friend wink.gif
8mile13 is offline
post #6 of 454 Old 05-21-2013, 05:20 PM - Thread Starter
Sterling's Avatar
I have contacted both OPPO and Seiki now. Both have been very responsive as far as manufacturers go. OPPO is saying they are working on improvements now that they have the set in house.
But OPPO also says other boxes are causing similar/same issues so they can't be the only ones and Seiki will have to fix something in their firmware likely.
Seiki said it was a known issue with OPPO and that OPPO was fixing it.
Given what I've read online, it appears there was a firmware update on the Seiki site that is no longer there, that fixed the problem, but caused the audio to fail?
I think Seiki needs to fix something. I'm sure they will figure it out soon, but until then I will have to suffer with 1080p for consistent video.
Sterling is offline
post #7 of 454 Old 05-22-2013, 06:27 AM
hdantman's Avatar
While Google may be my friend, it's clearly not Seiki's friend, since I have no such device connected to my Seiki TV--just a standard ole run of the mill GTX Titan. And yes, I have that firmware update, and can re-up, if someone wants to try it.
hdantman is offline
post #8 of 454 Old 05-22-2013, 05:09 PM - Thread Starter
Sterling's Avatar
Seiki just sent me a firmware to try so I'll see what that does tonight or tomorrow.
Update, I loaded the firmware and it did help a bit, but still has frame/video glitches. Just not as bad as before where it would go completely blank for several seconds.
So I think they still have to work on things.
BUT, I am using a 60' series RedMere HDMI cable, so that might be a problem.
I do have another really thick HDMI cable for this run that I can try on it to see if that helps any.
Sterling is offline
post #9 of 454 Old 05-23-2013, 09:05 AM
vilfrard's Avatar
Link to new firmware, this should help with the video issues some people are having.
https://www.dropbox.com/s/utwpxioqd8eahj5/install.img
vilfrard is offline
post #10 of 454 Old 06-01-2013, 08:32 PM
JeremyMc's Avatar
Has there been any update or details on the 39" or 65" yet? We're almost half way through 2013 and both were promised for later this year back at the start of the year. Unless they're not going to announce ahead of time then we might not see this year. Of course if they're just waiting for HDMI 2.0 before they release the 39" and 65" then I would rather wait. The last thing I'd like to see if have them release the new sets with 1.4a and then shortly after 2.0 comes out.
JeremyMc is offline
post #11 of 454 Old 06-13-2013, 11:49 AM
SpecTP's Avatar
official firmware is out on Seiki's site. http://www.seikidigital.com/support/downloads.php#remote
Does anyone know the code to set the remote for Verizon FIOS?
SpecTP is offline
post #12 of 454 Old 06-16-2013, 04:37 PM
bballista's Avatar
Did the new firmware fix the issue for anyone?
I am using their Blue Cable with a ATI 7950 video card. Still seems to blanking out for me.
bballista is offline
post #13 of 454 Old 06-16-2013, 07:45 PM
TexDanny's Avatar
Same problem here, every hour or so I get a blank screen for around 15-60 seconds. I've tried two different cables. I was starting to think my ati 7970 was the problem.
I couldn't install the firmware on the TV yet though. I disconnect power, instert usb with install.img file on it (fat32, empty, etc...), connect the power and it just stays on red led as normal. No red/blue flashing as it should.
What am I doing wrong?
TexDanny is offline
post #14 of 454 Old 06-16-2013, 08:01 PM
bballista's Avatar
This TV doesn't seem to work that way. I think that was a "generic" how to upgrade firmware for their TVs but this one is different smile.gif. Not complaining, still an amazing price lol.
Here is what you need to do:
1) Insert the USB
2) Turn the TV on
3) hit menu
4) hit 0000 (4 zeros)
5) Navigate the menu and find firmware upgrade
6) Click on it, and it will upgrade it.
Careful not to hit any of the other options in there. I heard some people screwing their screen up.
I also turned on the power on so that my TV comes on if AC power is lost and returns. Default is you always need to turn the screen on.
By the way, my screen only blanks out for like 1 second. It's very quick. What is your CPU and what were you doing when it happened?
I'm trying the redmere cable now, see if that makes a difference.
Cheers
post #15 of 454 Old 06-16-2013, 11:11 PM
bballista's Avatar
Seems to be stable now:
Changed the HDMI input to "HDMI 1".
Changed the cable from Blue wire supplied to a redmere cable (6ft) which I got from monoprice
Updated the firmware to the version on the seiki site (June 16th, 2013).
So far it's been pretty stable at 30Hz 3840x2160.
i5, 8gb ram, 128 ssd, ATI 7950
About 2 hrs of youtube videos with a 4k application (flash) running in the background.
I am also running the TV in portrait mode.
post #16 of 454 Old 06-16-2013, 11:41 PM
TexDanny's Avatar
Thanks a lot, I remember scanning through the menu without finding anything related to updating the software. I was starting to think the TV couldn't read my usb thumb drive, lol.. Hopefully it stops blanking out so much, or at least takes less time to come back.
Will report back if there's any improvement.
Btw, I don't know if this is possible to do, probably not and I'll look like a dumb but who cares. Is it possible to utilize (windows 8) part of the screen on 1920x1080@120hz while having the desktop at 3840x2160? Like having a movie or a game playing back at full hd 120hz in windowed mode?
Will google myself wtf a 'redmere' cable is :P
Thanks again.
TexDanny is offline
post #17 of 454 Old 06-17-2013, 01:52 AM
bballista's Avatar
You can buy the cables here:
http://www.monoprice.com/products/search.asp?keyword=redmere
I bought a lot of stuff from them, and I am sure many on this forum has as well
Regarding your movie question, yes I don't see why not. I mean, you just open a window with some program like VLC, play your movie, and expand the window to take up 1/4 of the screen which will be 1080p resolution.
I maybe misunderstanding your question.
Also, did an overnight test. It's been solid for over 14 hours now. I fairly confident now that it won't have that problem anymore.
post #18 of 454 Old 06-17-2013, 01:25 PM
reallynotnick's Avatar
Quoted: 398 Post(s)
Liked: 268
No that's not possible, cool idea but an HDMI cable simply sends one picture to the TV so you either have to do 2160p30hz or 1080p120hz for the whole screen.
Vizio 2016 P65, Denon x2200, Elac C5, A4 and 2x F5
PS4 Pro, AMD 7950, 360, and Plex
(Plex Profile for P65)
reallynotnick is online now
post #19 of 454 Old 06-19-2013, 07:30 AM
BillFree's Avatar
Quoted: 36 Post(s)
I would like to find out if those of you that own this 4k 50" Seiki have you tried out the new released blu-ray's mastered in 4k offered on Amazon. More to be released on July 16th. Your input would be very helpful.
BillFree is offline
post #20 of 454 Old 06-21-2013, 08:46 AM
MonnieRock's Avatar
Liked: 30
Hello Everyone,
I too am interested any information on the 65" model projected to be released. Has anyone heard anything?
Thank you,
Monnie
You breed them, You feed them.
FairTax.org
MonnieRock is offline
post #21 of 454 Old 06-21-2013, 10:26 PM
3dArtist's Avatar
Seiki 4K tv as computer monitor?
I am looking for a large computer monitor to work with Photoshop, Zbrush, Maya, 3D Coat....
It would be great to work with large Maya port views....
My rig???
Processor: Overclocked 4th Generation Intel® Core™ i7-4930MX (8MB Cache, up to 4.3GHz w/ Turbo Boost)
Operating System: Windows 8, 64-bit, English
Display: 18.4" WLED FHD (1920 X 1080) TrueLife Display
Memory: 32GB Dual Channel DDR3L at 1600MHz
Dual NVIDIA® GeForce® GTX 780M with 4GB GDDR5 - NVIDIA SLI® Enabled
3dArtist is offline
post #22 of 454 Old 06-25-2013, 09:34 AM
MonnieRock's Avatar
Liked: 30
JeremyMc,
I found this posted on the web yesterday evening:
SEIKI Announces 39" 4K Ultra HDTV for $700. SEIKI also announced a 65" 4K display, which they hope to ship by Fall 2013
Thank you,
Monnie
FairTax.org
post #23 of 454 Old 06-25-2013, 09:46 AM
JeremyMc's Avatar
Originally Posted by MonnieRock View Post
JeremyMc,
Thank you,
Monnie
Thanks, I saw it hours ago and forgot to post for everyone. I was actually kind of shocked. The original plan Seiki has posted was the 65" for summer and 39" for Christmas. I was hoping they would hold out on both of them long enough to add HDMI 2.0. As we see the 39" at least still only has 1.4 like the 50" sad to say.
JeremyMc is offline
post #24 of 454 Old 06-25-2013, 11:12 AM
MonnieRock's Avatar
Liked: 30
JeremyMC,
I agree that no HMDI 2.0 is a sad fact. I would of been happy if Display Port 1.2 was added.
Here is to hoping the 65" will have HDMI 2.0 and / or Display Port 1.2 wink.gif
Thank you,
Monnie
FairTax.org
post #25 of 454 Old 06-26-2013, 01:37 PM
jeanyes's Avatar
What source videos are you guys using to show off your new TV? I'm using 4K Video Downloader to grab the stuff up on youtube. Some of the videos are reasonably good but the biggest problem is the low bit rates. Any motion at all causes terrible artifacting. Does anyone have a source for good high quality 4K videos with high data rates? I'm guessing the in-store demos that Sony and Samsung are using are not available for download or purchase somewhere?
jeanyes is offline
post #26 of 454 Old 07-18-2013, 01:12 PM
p5browne's Avatar
Quoted: 3073 Post(s)
Liked: 2393
New 4K Streaming Device:
Nuvola4k.com
UN65HU9000 with SEK-3500U - Mine
UN75JU7100 / UN55HU7250 with SEK-3500U / UN32EH5300 / 2 X LG 55LHXs - wife's ! New addition UN40J5200AF
PN64F8500 up for sale
p5browne is online now
post #27 of 454 Old 07-18-2013, 01:21 PM
insoc's Avatar
Could it be possible that this display is just a good as any other big brand 4K display costing 10x more?
insoc is offline
post #28 of 454 Old 07-26-2013, 02:01 PM
mfs6278's Avatar
Quoted: 20 Post(s)
Here is the link to the newer version of the firmware.
https://www.dropbox.com/sh/kw6dxnnv58xzdnx/s70ubOTeSl
mfs6278 is offline
post #29 of 454 Old 07-26-2013, 02:03 PM
mfs6278's Avatar
Quoted: 20 Post(s)
mfs6278 is offline
post #30 of 454 Old 07-26-2013, 02:08 PM
mfs6278's Avatar
Quoted: 20 Post(s)
mfs6278 is offline
Reply LCD Flat Panel Displays
Seiki Digital Se50uy04 50 Inch 4k 120hz Led Hdtv
