Optimal Viewing Range for Vizio 60" and 70" TV - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 05-23-2013, 04:12 PM - Thread Starter
Charlieinaz's Avatar
Does anyone have some input on the best viewing distance? Right now we have a 47" Vizio and our typical distance from the TV is 6-7 feet. I don't want to spend the extra for the 70" if we are sitting too close. Thanks for any comments.
Charlieinaz is offline
post #2 of 3 Old 05-23-2013, 04:30 PM
bucknuts07's Avatar
Quoted: 100 Post(s)
Liked: 51
Probably 60 would be big as u would want to go from 6ft
Xbox Live- bucknuts07
PSN-bucknuts07
bucknuts07 is offline
post #3 of 3 Old 05-23-2013, 05:16 PM
Mad Norseman's Avatar
Liked: 101
Check this out for a good 'rule of thumb':
http://hdguru.com/wp-content/uploads/2009/02/hd-guru-viewing-distance-chart.pdf
For a 60" or 70" (with my 65" right between there!), I'd recommend 7' to 9' as probably ideal...
The Insane Pink Care Bear's Home Theater Set Up:
Marantz AV 8801 Processor, Emotiva XPR-5 Amplifier, Panasonic 65" ST30 Plasma, Yamaha BD-S2900 Blu-ray, Yamaha CDC-697 CD Player, Yamaha TT-500U Turntable, w/Signet TK5e, JBL ES100 Fronts, JBL LC2 Center, JBL ES30 Surrounds & 2 JBL ES250P Subwoofers
Mad Norseman is offline
Reply LCD Flat Panel Displays
Vizio 47 Class Lcd Hdtv
