NEED TO BUY 4-LED TV'S - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 05-29-2013, 04:15 PM - Thread Starter
udtsealeod's Avatar
I need to buy 4 LED Flat Panel TV's to complete my A/V system, what would you recommend and why??
Here are my elements:
1. I will have a theater room for 75% of the HDTV watching
2. No kids, just wife and me
3. Location-Kitchen, Master Bedroom, Office, Sun Room
4. about 50" LED wall mounted, rooms have a lot of light
5. All used with a Crestron, AVR, DVD/BD, DirecTV Genie, Apple TV rack
6. most likely external wall speakers
7. 3D not an issue
FREEDOM ISN'T FREE
USN, CDR, RET
UDT/SEAL-EOD 1971-2003
udtsealeod is offline
post #2 of 6 Old 05-29-2013, 04:42 PM
BoilerJim's Avatar
Quoted: 55 Post(s)
Liked: 118
What does no kids have to do with it?
BoilerJim is offline
post #3 of 6 Old 05-29-2013, 05:43 PM
Latinoheat's Avatar
Quoted: 1079 Post(s)
Liked: 826
7. 3D not an issue
Is your theater room the same as sun room? You want all 50" ? I would recommend getting 3 LCD' s and 1 plasma for the theatre room if its not the sunroom and bigger than 50" if you can afford, just because plasma will give you better picture quality but if your theater room is the sunroom than go LCD. I think going 50" in a kitchen and bedroom is overkill unless you live in a mansion with a huge open space. You can't go wrong with Sharp Aquos quatron/Samsung/Sony XBR. Plasma -Panasonic / Samsung.
Media room- LG 4K OLED EG9600, Pioneer Elite VSX-90, Samsung 4K K8500, Klipsch Gallery G28's, Klipsch Sub 12, Klipsch RS-52 II, Optik HD cable
Living room- Sony 4K 79XBRX900B, Onkyo RC-360,HTPC, Klipsch Reference R-62II, Rc52II,PS4
Gaming room -Panasonic ST60, PS3, Wii
Latinoheat is online now
post #4 of 6 Old 05-29-2013, 05:43 PM - Thread Starter
udtsealeod's Avatar
Nothing unless there are features they would ask for; 3D, smart TV, etc... I do not know that's why I'm asking.
FREEDOM ISN'T FREE
USN, CDR, RET
post #5 of 6 Old 05-29-2013, 06:08 PM - Thread Starter
udtsealeod's Avatar
[QUOTEIs your theater room the same as sun room? You want all 50" ? I would recommend getting 3 LCD' s and 1 plasma for the theatre room if its not the sunroom and bigger than 50" if you can afford, just because plasma will give you better picture quality but if your theater room is the sunroom than go LCD. I think going 50" in a kitchen and bedroom is overkill unless you live in a mansion with a huge open space. You can't go wrong with Sharp Aquos quatron/Samsung/Sony XBR. Plasma -Panasonic / Samsung.][/QUOTE]
Thank you for your feedback!!!
No, sun room is back porch closed in due to long winters. Theater room off kitchen, next to garage. Yes, we are old and our eye are bad!! Theater room will have projector/screen. I have a 50" plasma Panasonic now, it's going to the basement and the playroom. Bedroom is over the fireplace, no I not building a mansion. I'm looking for a good price point, based on TV not the bangs and whistles that come as selling points.
FREEDOM ISN'T FREE
USN, CDR, RET
post #6 of 6 Old 06-02-2013, 04:02 PM - Thread Starter
udtsealeod's Avatar
Is there any advantage buying a LED TV with RVU protocol vice getting the C31 Genie Mini?? Higher cost of a upgraded software package vice a less costly based on less add-ons??
FREEDOM ISN'T FREE
USN, CDR, RET
Reply LCD Flat Panel Displays
