Off Angle Viewing Samsung or Panasonic - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 06-02-2013, 10:53 PM - Thread Starter
murphy_r's Avatar
Hi folks,
I am looking to pick up a 50" TV for our kitchen / family room to be mounted with a swivel arm. Wondering about off angle viewing. I am looking at the Samsung EH6000 or ES7100 or Panasonic LE64. For me I don't care about 3D or any smart tv features as I will feed an apple TV into it. Really I just want decent viewing angles and 2D quality in a well lit room.
Cheers!
murphy_r is offline
post #2 of 4 Old 06-02-2013, 10:58 PM
Otto Pylot's Avatar
Quoted: 1361 Post(s)
Liked: 853
I would suggest viewing each tv at the angle you want, if you can, at BB or where ever. The specs for off-axis viewing, imo, are a bit confusing. I've seen specs that were the same (178 degrees) on two different mfrs but the pq for the off-axis viewing was noticeably different. Possibly due to the panel type used.
Otto Pylot is offline
post #3 of 4 Old 06-03-2013, 09:10 AM - Thread Starter
murphy_r's Avatar
Good feedback. I will head into a few stores and test. Given the high amount of fluorescent light in stores that should also help as a worst case.
murphy_r is offline
post #4 of 4 Old 06-03-2013, 12:22 PM
tylerSC's Avatar
Quoted: 721 Post(s)
Liked: 166
The Panasonic models appear to have better off angle viewing from what I have seen, and they use an IPS panel which is known for better side viewing. The ES7100 does fade badly from side angle viewing. The EH6000 is better in that regard, possibly because of the direct backlighting. Also now their is a FH6030 at a similar price point.
tylerSC is offline
Reply LCD Flat Panel Displays
Samsung 50 Inch Led Hdtv Un50eh6000 , Samsung Un60es7100 Led Hdtv , Samsung Un55fh6030 55 Inch Slim Led Hdtv
