Sony XBR65X900A 4K Flashing red power indicator - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 06-03-2013, 02:34 PM - Thread Starter
Rebelpirate's Avatar
I have a Sony XBR65X900A that I love but it went down on me today. The TV won't respond to remote demands or on the TV demands. It also shuts down on it's on and the power indicator light flashes red 8 times. Has anybody had this issue yet?
Rebelpirate is offline
post #2 of 11 Old 06-03-2013, 02:43 PM
CaptinCrunch's Avatar
Quoted: 29 Post(s)
Liked: 43
It's either the panel or the power supply that has gone bad.....sorry to hear it.
Sony 55W900A
Sony S5100 Blu-ray
Yamaha Aventage A1030
Klipsch RF-82 II
Klipsch RC-62 II
Klipsch RS-52 II
Klipsch RB-51 II (Front Preference)
SVS PB-2000
CaptinCrunch is offline
post #3 of 11 Old 06-03-2013, 02:58 PM
SonyListens's Avatar
Good afternoon Rebelpirate!
This is Kevin Krause from Sony Support USA. I am very sorry to hear about the problems that you have experienced with your new TV. We will certainly help you out with any issues you are having. Please email us at Sonylistens@am.sony.com and we will be happy to help you out. Please be sure to include a brief description of the issues your TV is displaying and in the subject of the email please refer to the event ID number E57810825.
Thank you,
Kevin Krause
Sony Support USA
SonyListens is offline
post #4 of 11 Old 06-03-2013, 04:45 PM
anthonymoody's Avatar
Quoted: 428 Post(s)
Liked: 274
Pretty cool. Hopefully this (presumably sanctioned) participation will encourage more mfrs to do this type of customer engagement.
CaptinCrunch likes this.
Stuck up, half witted, scruffy looking, nerf herder.
Double True!
anthonymoody is online now
post #5 of 11 Old 06-05-2013, 02:39 PM
LeeSoFl's Avatar
Quoted: 256 Post(s)
Liked: 277
Your problem is discouraging, but good to see that a Sony rep frequents these forums.
Let us know what it turns out to be and how it was rectified.
I have one being shipped to my home and I would have loved to hear only positive user stories.
Good luck!
LeeSoFl is offline
post #6 of 11 Old 06-10-2013, 03:00 PM - Thread Starter
was taken care of for
me by Sony! Power supply was bad! Other than that TV is AWESOME!!!!
post #7 of 11 Old 06-10-2013, 05:09 PM
LeeSoFl's Avatar
Quoted: 256 Post(s)
Liked: 277
I'm glad it was repaired quickly.
Delivery company is due to bring my new set tomorrow, between 7 AM and 10 AM.
LeeSoFl is offline
post #8 of 11 Old 06-11-2013, 08:42 PM
Hodog16's Avatar
Thank you for making this post. We just got this tv yesterday and we have the exact same issue tonight. It will turn on and the video will work, and then it will cut out on its own. It repeats this process three times before finally turning off and then the red LED blinks 8 times.
I spoke with Sony customer support and their theory was that the 8 blinking lights means the tv needs a software update. The power supply issue makes much more sense as I can't fathom an engineer/programmer making a product that cuts out when a software update is needed.
Will have to make a few more phone calls tomorrow during business hours to figure out the solution. Did they repair or replace your unit?
Hodog16 is offline
post #9 of 11 Old 07-03-2013, 06:34 AM
flinchn's Avatar
Quoted: 138 Post(s)
Liked: 202
There may be something to the software update information. My 65 was experiencing the same thing except 4 blinks instead of 8. This happened on Sat after I got the set on Thurs and applied the update available. Sun/Mon a new update came out, and my set has worked just fine since.
flinchn is offline
post #10 of 11 Old 11-06-2014, 08:41 PM
planetommy's Avatar
Liked: 0
I just purchased this $4,000.00 XBR-65X900B and I am having the exact same issue - TV does not turn on red flashing light.......Called Sony three days ago no call back from Sony yet.......I have called 3 times
planetommy is offline
post #11 of 11 Old 12-10-2014, 06:28 AM
Liked: 0
I had same problem with my 55X9606B, tv only showed "SONY" logo and started flashing THE red light 8 times. I solved problem unplugging power cord for 5 minutes and then i plugged back in. After that tv has worked smoothly. Keep the tv power cord from the wall power outlet ONLY. Try avoid extension cords etc. Some cords can repeat the problem again.
Pitkanen is offline
Reply LCD Flat Panel Displays
Sony Xbr 65x900a 65 Inch 1080p 120hz 3d Led 4k Ultra Hdtv
