Help With Larger Gaming Display - AVS Forum | Home Theater Discussions And Reviews
Old 06-08-2013, 06:21 AM - Thread Starter
JlgLaw's Avatar
Quoted: 77 Post(s)
Liked: 128
I would appreciate any comments or opinions on which larger sized display(s) (65" and above) are considered to be the best for gaming. I would prefer a screen in the 70"-85" range, assuming any in that range are actually good gaming displays. I do not plan to use front projection (but could), because I already have a FP based theatre. The room is large enough to sit at proper distances for any size below 110", and lighting is not a factor, this is actually my children's game/media room. I'm not concerned about cost and would even consider the new Samsung 85S9, or Sony 84" 4K, but, not unexpectedly, cannot find any user comments/reviews, or spec's discussing "lag" or other factors that affect gaming performance in these newer displays. That said, it does not have to be a 4K display. Thanks!
Jim
JlgLaw is offline
