Sharp led - pioneer avr - HD cablebox issue - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 06-16-2013, 07:29 PM - Thread Starter
aisokc's Avatar
When going from high definition channels back to analog channels the screen goes black for short period of time but you can still hear the audio it appears that either the TV or the audio receiver can't keep up with the resolution or process it correctly is this a common problem has anyone else had an issue with this
60" sharp led
Pioneer vsx-1022
Scientific Atlanta explorer 8240hdc
All connected hdmi
aisokc is offline
post #2 of 5 Old 06-17-2013, 03:58 AM
Ratman's Avatar
Quoted: 1487 Post(s)
Liked: 1191
Check the video output settings in the cable box. Set to always display 1080i.
If you can’t explain it simply, you don’t understand it well enough – Albert Einstein
Ratman is offline
post #3 of 5 Old 06-17-2013, 08:18 AM - Thread Starter
aisokc's Avatar
I thought about that too but it didn't make a difference. I also tried some of the hdmi settings in the pioneer as well but no results
aisokc is offline
post #4 of 5 Old 06-17-2013, 01:57 PM
Ratman's Avatar
Liked: 1191
Bypass the Pioneer and go directly from the cable box to the TV to test. If problem persists... revisit the cable box settings. If problem stops.... then the AVR may be the problem.
Ratman is offline
post #5 of 5 Old 06-17-2013, 02:20 PM - Thread Starter
aisokc's Avatar
ok will try that in a few minutes. there doesn't ever seem to be any issues with the blu ray. and I just had to get my cable box replaced because the hd failed. also this pioneer isn't my first choice of avr but I got a crazy deal on it so I couldn't pass it up.
I have messed with the cable box resolution settings and the video parameter settings in the avr and also the upcoversion settings but it still gives me a black screen. on some of the other settings its a longer black screen too
aisokc is offline
Reply LCD Flat Panel Displays
