Toshiba L1350U Series (2013) - Page 11 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #301 of 323 Old 12-05-2014, 10:20 PM
NintendoManiac64's Avatar
Quoted: 487 Post(s)
Liked: 187
Renaming the input shouldn't do anything on this TV, that applies to other brands from what I can tell. Did you try the different picture modes, specifically "Game" and "PC"?
As for 60fps, nah, I don't think it's related to that because I can watch and play constant silky-smooth 60fps content perfectly fine without issue (though admittedly it's not as "silky" as my Trinitron CRT monitor ).
You may have been confusing it with what I said about using SVP to interpolate sub-60fps content up to 60fps where I reported weird juddering, but I found out a few months back that it was actually the fault of the PC's crappy Intel 965GMA graphics, not the TV - setting MPC-HC to use "D3D Fullscreen" fixed the weird judder (it was due to a lack of DirectDraw performance or something - I noticed that it wasn't as bad at 720p compared to 1080p).
The white glow actually could be a sharpness artifact of sorts - make sure dynamic contrast is off, the sharpness enhancement is off, both noise reduction options are off, and the sharpness is set to -25 like I stated.
NintendoManiac64 is offline
post #302 of 323 Old 12-22-2014, 10:04 AM
Rawe's Avatar
Thanks for replying, and sorry for the late response. I'll be trying this tonight and let you know.
Rawe is offline
post #303 of 323 Old 01-13-2015, 11:57 PM
Rawe's Avatar
Hey sorry for not getting back sooner. I have tried all those options and unfortunately no luck. Wonder why it seems to have a larger amount of blur from other displays. Really appreciate the help you've given me, not just for this question but all of them so far
Rawe is offline
post #304 of 323 Old 01-14-2015, 03:34 PM
Quoted: 487 Post(s)
Liked: 187
You are running at a 60hz refresh rate, right? I noticed that even 64hz is more blurry than 60hz, probably because it no longer is an equal multiple to the 120hz stobing backlight.
post #305 of 323 Old 01-15-2015, 10:03 PM
Rawe's Avatar
Correct. It is at 60HZ.
Rawe is offline
post #306 of 323 Old 01-21-2015, 09:57 PM
EJSLP's Avatar
I was wondering, i use the L1350U 50" for my pc monitor and have a EVGA gtx780ti gpu
do i set the refresh rate to 60hz or 120hz for this TV?
I see that this TV is said to be 120hz some places and others it is 60hz??? very confusing!
EJSLP is offline
post #307 of 323 Old 01-21-2015, 10:51 PM
Quoted: 487 Post(s)
Liked: 187
Ok...next thing, are you sure you're getting a full 4:4:4 chroma signal? Here's a test image (I recommend opening it in MSpaint to avoid DPI scaling issues):
http://forum.doom9.org/showthread.ph...99#post1640299
If it's anything like the 39", the 120hz applies only to the strobing backlight and not the actual LCD display. The 39" model for example maxes out at a 77hz input refresh rate.
In other words, if the TV cannot accept a 120hz signal then your GPU shouldn't even make the option available. If the option is available, then I would say try some 120fps videos (60fps running at 2x speed would work) and see if you can see a difference between 120hz and 60hz.
post #308 of 323 Old 01-21-2015, 11:28 PM
EJSLP's Avatar
Thanks for the help
and BTW i tried the 4.4.4 test and on my toshiba the screen is all one color(magneta) and i can see both 422 and 444 writtin on the screen?
is my TV 4.4.4 chroma?
EJSLP is offline
post #309 of 323 Old 01-22-2015, 12:14 AM
Quoted: 487 Post(s)
Liked: 187
Thanks for the help
Err, are you outputting to the TV's native resolution and are using MSpaint? Because the numbers in the test image should look like the attached image in the following post:
Official 4:4:4 / Chroma Subsampling Thread
(note that, while it's a smaller 720p-friendly image, the actual numbers are exactly the same)
post #310 of 323 Old 01-22-2015, 12:45 AM
EJSLP's Avatar
No i didnt use MSpaint? I just clicked on the image
There were several places i read that the L1350U 50" has 4.4.4 chroma support?,
I play a lot of AAA graphic intensive games like watch dogs,battlefield 4,COD advanced warfare, splinter cell blacklist, Metal Gear solid V
all of which have really good graphics and they look insanely good on this toshiba.
so even if i don't have the 4.4.4. i only paid $600 new for the TV so you wont hear me complaining any time soon
EJSLP is offline
post #311 of 323 Old 01-22-2015, 01:14 AM
Quoted: 487 Post(s)
Liked: 187
Oh come on, it's super-duper easy. MSpaint is the "Paint" or "Paint Brush" program that comes with all versions of Windows - all you have to do is open the image in said program.
The problem with this is that I cannot guarantee that the image won't be zoomed. Even if the program says 100% zoom, it's very possible that it isn't high-DPI aware and therefore the entire program could be zoomed. Using MSpaint is a fool-proof way to avoid the issue.
post #312 of 323 Old 02-03-2015, 10:50 AM
Rawe's Avatar
Hi EJSLP, are you getting a lot of blur when moving get around your camera when using as a pc monitor.?
Rawe is offline
post #313 of 323 Old 02-04-2015, 12:30 AM
Quoted: 487 Post(s)
Liked: 187
Forgive my fuzzy memory, but did you ever confirm that you were running with 4:4:4 chroma...?
post #314 of 323 Old 02-07-2015, 06:51 AM
Rawe's Avatar
I believe so. the screen fits perfectly when on the TV. I have now another question. I've fallen asleep a lot over the past year and as a result my TV was left on idle for a few hours with a movie paused. I don't think any burn in was done, but is there a way to get the screen saver (where the bar sas no signal) to show up on the screen.
Rawe is offline
post #315 of 323 Old 05-01-2015, 01:32 PM
Rawe's Avatar
Does anyone use this for their Xbox? I find it works great for my PS3 but my Xbox is too dark.
Rawe is offline
post #316 of 323 Old 05-01-2015, 01:47 PM
Quoted: 487 Post(s)
Liked: 187
Which Xbox are we talking about: original, 360, or One? Also how is it being hooked up to said TV?
If it's a 360 or One and it's being connected via HDMI, you may have to manually change the color range settings on the TV - the "Auto" setting can be wrong at times. However, I personally would recommend to set the color range on both the TV and the console itself to "Expanded 0-255" since that is technically better.
post #317 of 323 Old 05-01-2015, 01:59 PM
Rawe's Avatar
I set it to "FULL" on the TV and Expanded and RGB on the 360. I am using jbanks settings.
It is setup thru HDMI
Rawe is offline
post #318 of 323 Old 05-01-2015, 08:42 PM
Quoted: 487 Post(s)
Liked: 187
Oddly enough I didn't get email notification even though I have instant email notification enabled...
You said you're comparing it to the PS3 - perhaps it's actually that the PS3 is outputting too bright? It would probably be wise to check the color range settings on the PS3 and the according TV input as well...
post #319 of 323 Old 06-27-2015, 08:41 PM
Rawe's Avatar
After watching TV, I noticed the colors look washed out. I was wondering if there are some settings youd recommend so that it looks more saturated maybe?
Rawe is offline
post #320 of 323 Old 08-06-2015, 09:31 PM
Rawe's Avatar
Anyone?
Rawe is offline
post #321 of 323 Old 08-16-2015, 09:02 PM
Quoted: 487 Post(s)
Liked: 187
Sorry, I'm not getting notification of replies again for some reason...
Regarding saturation, usually you would just want to increase the "Color" setting or maybe even the "Backlight" setting some.
post #322 of 323 Old 01-15-2016, 06:35 PM
Liked: 0
Thanks. Does anyone here own a ps4 and use this TV? When watching a Blu Ray, when I exit it back to the ps4 menu there's a flash and it looks like it glitches out instead of smoothly returning to the menu.
GoosePants is offline
post #323 of 323 Old 01-15-2016, 08:28 PM
Quoted: 487 Post(s)
Liked: 187
Does the info display on the TV come up when you do that?
Reply LCD Flat Panel Displays
Toshiba 39l1350u 39 Inch Led Hdtv , Toshiba 50l1350u 50 Inch Led Hdtv , Toshiba 29l1350u 29 Inch Led Hdtv , Toshiba 32l1350u 32 Inch Class Led Hdtv
