Toshiba L1350U Series (2013) - Page 12 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #331 of 342 Old 06-06-2016, 04:14 PM
NintendoManiac64's Avatar
Quoted: 929 Post(s)
Liked: 386
Originally Posted by EJSLP View Post
So it "MAY" be the power board? The BL driver is integrated in the power board on these
Maybe, maybe not. No idea since I'm not exactly willing to open up my TV when I'm not even its primary user and it's been working perfectly ever since the board replacement years ago.
NintendoManiac64 is offline
post #332 of 342 Old 06-06-2016, 04:18 PM
EJSLP's Avatar
Quoted: 64 Post(s)
I see, well it would be a $60-75 gamble IF i wanted to give it a go?
Was going to get a 4K sony x810c to replace it,
http://www.rtings.com/tv/reviews/sony/x810c
EJSLP is offline
post #333 of 342 Old 06-06-2016, 04:23 PM
Quoted: 929 Post(s)
Liked: 386
Personally I'd crack open the TV first and take a look at how the LED backlight array connects to the power supply and the like.
And regarding TVs, for $1000 I myself would go with OLED or bust, even if it's only the "lowly" 55EG9100 model.
post #334 of 342 Old 06-06-2016, 04:30 PM
EJSLP's Avatar
Quoted: 64 Post(s)
I already did but that does not really tell the story? it is a real basic plastic module clip
that you unplug.
it may or may not be the board though, it could be just one or even two of the LED's which will cause ALL of them to fail!
and tracing a bad LED is not a easy task.
EJSLP is offline
post #335 of 342 Old 06-06-2016, 04:32 PM
EJSLP's Avatar
Quoted: 64 Post(s)
Budget is $1000 and there is no OLED tv's for that amount,
EJSLP is offline
post #336 of 342 Old 06-06-2016, 04:36 PM
Quoted: 929 Post(s)
Liked: 386
This forum section would disagree:
http://www.avsforum.com/forum/322-ol...t-found-deals/
People have gotten the 9100 for $1000 in recent months.
Oh, and contact Cleveland AV first - their pricing is a great baseline since you can usually only get cheaper pricing from Ebay sellers, though sometimes from Microcenter and/or Monoprice.
post #337 of 342 Old 06-26-2016, 01:10 PM
Quoted: 929 Post(s)
Liked: 386
I just did a bunch of pseudo-calibration tests with my own self-made test patterns (I wanted to make sure I knew exactly what was being used) testing for black & white level, black & white crush, and color clipping for a given backlight level. I would call this a high contrast preset (but not quite vivid - the colors aren't super-saturated or anything).
Note that I'm pretty sure that these settings don't give an accurate image - I believe the color temperature is too cool, the green might be too saturated, and the gamma is probably jacked up.
I first "calibrated" to maximize the black and white levels to maximize static contrast but without crushing or clipping the near-black or near-whites. After that, I configured things so that red, green, and blue were as saturated as possible without reducing the maximum white or crushing the near-whites nor clipping any colors. Contrary to what you'd think, this was all actually much more difficult on this TV than one would believe.
BTW, settings marked as [user choice] seem to have no effect on the result with regards to my above stated goals of maximizing contrast or the like.
High Contrast preset
Picture Mode: Standard
Backlight: [user choice]
Contrast: 88
Brightness: -3
Color: -1
Tint: [user choice]
Sharpness: [user choice; -25 for direct 1:1 pixel mapping without any "enhancement"]
Color Master: Off
Color Temperature: Cool
- Red: +1
- Green: +9
- Blue: +1
Static Gamma: +4
Auto Brightness Sensor: [user choice]
DynaLight: [user choice]
Dynamic Contrast: Off
Cinema Mode: [user choice]
Noise Reduction: [user choice]
Edge Enhancer: [user choice; Off for direct 1:1 pixel mapping without any "enhancement"]
EDIT: I've since made a minor tweak in an attempt to reduce any sort of "washed out" effect from the above settings; in particular I found that the above settings only really seem to work well in the real-world for darker content but the following tweaks make it work great for darned near anything.
Contrast: 74
Brightness: 0
Color: 0
Static Gamma: +2
Oh, and remember back when we were somewhat debating about the 120Hz on this TV? I can definitely confirm that the 120Hz is purely backlight strobing - this is most noticeable when you feed the TV a 50Hz (rather than 60Hz) signal - I'm am able to see that the display is flickering in quite a CRT-like manner (though this TV's backlight strobing at 100Hz is quite a bit more flickery than any CRT at 100Hz I know of, and I'm pretty sure it's not strobing at 50Hz either).
post #338 of 342 Old 07-29-2016, 06:13 PM
Quoted: 929 Post(s)
Liked: 386
Uhhh, I just discovered a really annoying issue - it seems that setting the 3.5mm audio input to HDMI1 simply does not work, but it works perfectly fine when it's set to "PC".
Anyone have such an issue?
Admittedly I'm running an old TV firmware because I didn't want to upgrade and possibly cause the same issues I had previously where the OTA audio would cut out since it's out of warranty, but maybe I should just bite the bullet and update the firmware...
post #339 of 342 Old 09-13-2016, 04:38 PM
Liked: 0
Thanks for posting those high vivid settings, should I use them over jbanks settings or stick to jbanks? Remember I game on ps3 and ps4 (and watch some cable tv) also, I haven't noticed that about hdmi because I haven't tried yet. Also,this tv supports "full" rgb right? I think I asked this before but can't find my post. Anyways, it supports it right?,and if I set it for the hdmi ports, than I want to set it in my ps3 and ps4 correct? Everything seems a bit darker but great color.
GoosePants is offline
post #340 of 342 Old 09-14-2016, 11:12 AM
Quoted: 929 Post(s)
Liked: 386
It's purely preference - I doubt the gamma is accurate at all with my settings. However I've since made a minor tweak in an attempt to reduce any sort of "washed out"; effect from the above settings; in particular I found that the above settings only really seem to work well in the real-world for darker content but the following tweaks make it work great for darned near anything.
Contrast: 74
Brightness: 0
Color: 0
Static Gamma: +2
Yes this TV supports full RGB, but you need to make sure the TV is manually set to "Full" and the device is manually set to "Full RGB" (or similar); do not use YUV or YBCBR if you want the full 0-255 color range (they only support the limited 16-235 color range).
post #341 of 342 Old 09-17-2016, 04:28 PM
Liked: 0
post #342 of 342 Old 09-26-2016, 01:14 PM
Quoted: 929 Post(s)
Liked: 386
Note that I've since made a farther tweak.
Contrast: 74
Brightness: 0
Color: 0
Static Gamma: +2
Unlike the previous settings tweak (which I used for all of a couple days), I've been running this for nearly a week now and feel that this is a better balance for a wide verity of content (dark, moderate, and bright).
Reply LCD Flat Panel Displays
Toshiba 39l1350u 39 Inch Led Hdtv , Toshiba 50l1350u 50 Inch Led Hdtv , Toshiba 29l1350u 29 Inch Led Hdtv , Toshiba 32l1350u 32 Inch Class Led Hdtv
