w802a and mkv question - AVS Forum | Home Theater Discussions And Reviews
Old 06-19-2013, 04:13 PM - Thread Starter
Dymblos's Avatar
this led can play mkv over 4gb/8gb trough usb device? (WD My Passport)
in my country we have the w805a.. same spec, just with other name
Dymblos is offline
Old 06-20-2013, 08:25 PM
Fenrir7's Avatar
Nope. It can't. This was supposed to be the TV that I would be buying but it had no support for plug-and-play USB with MKV files. You will need to have a media server to transcode it before it plays on the tv. in my experience, that option will cause buffering and you cannot skip to parts that you want to because of the buffering issue. Sucks.
Fenrir7 is offline
Old 06-21-2013, 08:47 PM - Thread Starter
Dymblos's Avatar
and others W models? or all them are trough DNLA ?
Dymblos is offline
Old 06-21-2013, 08:54 PM
Fenrir7's Avatar
Yes all Sony tvs all through DLNA
Sent from Galaxy Note using Tapatalk 2
Fenrir7 is offline
