Showroom "Calibrations" - Page 4 - AVS Forum | Home Theater Discussions And Reviews
post #91 of 215 Old 07-09-2013, 10:55 PM - Thread Starter
showroomcali's Avatar
Liked: 32
Originally Posted by accordn2ryan View Post
Glad I found this thread, great work and dedication btw showroomcali, the forum community definitely appreciates it! Anyway you can do calibration settings for the UN55F7100? Preferably in Standard, and/or Movie Mode. Thanks in advance, and no rush!
See my other post, the calibration for the F7100 will be coming tomorrow, and it'll be done in 'Movie' mode with a full 10-point grayscale calibration.
Cheers!
DISCLAIMER: This thread is in no way intended to replace a professional calibration. Merely intended for showroom evaluation & as a starting point for home viewing. For optimal results, please consider a calibration suited for your viewing environment & performed by a professional of your choosing.
showroomcali is offline
post #92 of 215 Old 07-09-2013, 10:56 PM - Thread Starter
Liked: 32
Originally Posted by migdlp View Post
It will be great if you can look at it,
thanks
I'm doing both the F7100 and your requested F6900 tomorrow. Stay tuned for results on both. They should be posted tomorrow evening!
Cheers!
post #93 of 215 Old 07-09-2013, 10:56 PM
Leonheart's Avatar
Quoted: 86 Post(s)
Liked: 25
Originally Posted by showroomcali View Post
Here's the results. The LA6200 does lack a little in the black levels and contrast ratio departments, however color accuracy was spot on with this display. All primary and secondary colors measured under 1 dE. I don't have any screen shots from the calibration itself, but all the info should be in the word doc. Cheers! smile.gif
47LA6200.docx 14k .docx file
Thanks, going to try them soon.........Will these work with a LM6200? what abou t the other picture options like color gamut, real cinema, etc?
55EG9100
PS4
Leonheart is offline
post #94 of 215 Old 07-09-2013, 10:59 PM
dpiantino's Avatar
Id like to see the vizio e701-a3. I think the new firmware messed with black levels
dpiantino is offline
post #95 of 215 Old 07-09-2013, 11:01 PM - Thread Starter
Liked: 32
All unnecessary extras were turned off. 'Black levels' was set to 'Low' and Real Cinema was left on because of the video playback handling on films. 'Color Gamut' on the LA6200 was set to 'BT709,' which is the set standard for all content today.
Will they work the with LM6200? Not necessarily, for best results I'd recommend other options, but try the settings. It certainly won't harm the display.
post #96 of 215 Old 07-09-2013, 11:03 PM - Thread Starter
Liked: 32
What firmware is the latest so I can ensure that the Vizio I work on has that same software installed?
I believe a local store has the e701 on display, so I'll verify tomorrow, and if indeed that's the case, then I'll add that to the bill as well. My day off tomorrow is certainly filling up smile.gif which is much appreciated!
post #97 of 215 Old 07-10-2013, 12:51 AM
jayy11284's Avatar
Not able to open doc. Also were you able to get calibration in movie mode
jayy11284 is offline
post #98 of 215 Old 07-10-2013, 12:52 AM
jayy11284's Avatar
Samsung UN60ES7500 Edge OFFICIAL 2.doc 14k .doc file
post #99 of 215 Old 07-10-2013, 01:11 AM
muri's Avatar
Thanks showroomcali!!
Can someone help me please?
the 20 point grayscale - which settings do you use or how does it work?
It goes from 10 to 100, not sure which settings to input?
muri is offline
post #100 of 215 Old 07-10-2013, 01:12 AM
muri's Avatar
Sorry forgot to mention it was for the 47la6200 calibration done earlier
muri is offline
post #101 of 215 Old 07-10-2013, 01:52 AM - Thread Starter
Liked: 32
What problems are you having? You should be able to choose a 'Method' and you'll choose 20 Point IRE rather than 2 Point (though IRE is inaccurate for digital displays biggrin.gif)
Choose 20 Point IRE and plug the settings in. I put in my settings for each interval of 5, so go to the given interval, and plug in the settings. Done and done.
post #102 of 215 Old 07-10-2013, 01:53 AM - Thread Starter
Liked: 32
Not sure why you weren't able to open the doc. Should've been fine. I can post the settings in a response if necessary. Let me know!
post #103 of 215 Old 07-10-2013, 02:22 AM
muri's Avatar
Got it, wasnt sure if i was supposed to enter all the settings for each interval of 5 or just enter only one of the intervals with settings
thanks, will try this out and report back!!
muri is offline
post #104 of 215 Old 07-10-2013, 03:18 AM
muri's Avatar
Howcome the the 20 point grayscale starts at 10 and not 0?
Sorry if its a dumb question
muri is offline
post #105 of 215 Old 07-10-2013, 03:24 AM
GatorJZ's Avatar
Quoted: 54 Post(s)
Liked: 61
Thank you VERY much for these. I just dialed these in and, other than making some adjustments for a dark bedroom, the set looks great.
Two small corrections:
1: the 47LA6200 is direct lit, not edge lit.
2: you omitted 75 and its values for the 10/20 grayscale.
Also, what color temperature setting did you use? In most of the professional calibrations of LGs I've seen, Warm 2 was used, but I don't want to assume anything.
Would it be OK to include your settings in my review of this TV on Amazon?
Again, thank you very much for going to all of this trouble...it really is very nice (and helpful) of you.
Shunzzie likes this.
Samsung UN50HU8550, Vizio P602ui-B3 & Vizio M43‑C1.
GatorJZ is offline
post #106 of 215 Old 07-10-2013, 04:06 AM
eric3316's Avatar
Quoted: 842 Post(s)
Liked: 959
Thanks for this! I dialed these in quickly last night so didn't have much time to actually observe it. Immediately I noticed a heavy red push so I lowered the red gain which seemed to of helped. Will be able to really give it a look later tonight.
Do you think you got better results with the levels this time around then the last one you did?
eric3316 is offline
post #107 of 215 Old 07-10-2013, 01:02 PM
Leonheart's Avatar
Quoted: 86 Post(s)
Liked: 25
I tried them on the lm6200, looks ok except the backlight though.....
55EG9100
PS4
post #108 of 215 Old 07-10-2013, 01:54 PM
dpiantino's Avatar
2.0.21
2.0.21
post #109 of 215 Old 07-10-2013, 02:02 PM - Thread Starter
Liked: 32
The values for 75 are -26, -16, 10. I used 'Warm 2' for the color temperature setting. Feel free to share these settings on Amazon and any where else you would like. No problem at all, it's my pleasure smile.gif
post #110 of 215 Old 07-10-2013, 02:05 PM - Thread Starter
Liked: 32
I feel as though this time around the results were better, yes. As far as the red push, that's not something I experienced what so ever. There was actually quite the opposite effect, with a heavy blue push at the top of the grayscale, hence why the R and G Gain's are so high and the B Gain is so low. Overall though, I was impressed with the displays performance.
eric3316 likes this.
post #111 of 215 Old 07-10-2013, 02:07 PM - Thread Starter
Liked: 32
Depending on your viewing environment, you'll want to adjust the 'Backlight' up or down accordingly.
post #112 of 215 Old 07-11-2013, 12:47 PM - Thread Starter
Liked: 32
Results for the Vizio E701I-A3 should be posted later this evening, and the F7100 should be done tomorrow evening.
post #113 of 215 Old 07-11-2013, 03:02 PM
accordn2ryan's Avatar
Thanks for the update on the F7100!
accordn2ryan is offline
post #114 of 215 Old 07-11-2013, 06:14 PM
dpiantino's Avatar
Cant wait!
post #115 of 215 Old 07-11-2013, 07:24 PM - Thread Starter
Liked: 32
Cant wait!
Here's the results. I was actually pleasantly surprised with the Vizio after the calibration. Colors were extremely accurate, blacks weren't inky, but still sufficed. Contrast gave the image a nice punch and the overall image was smooth and pleasant.
Vizio E701i Calibration Results.doc 14k .doc file
post #116 of 215 Old 07-11-2013, 07:38 PM
dpiantino's Avatar
I like it. I had the same contrast, brightness, color, and tint, but much lower color values. Im liking it. I appreciate all your effort
post #117 of 215 Old 07-12-2013, 04:38 AM
Big C's Avatar
Quoted: 62 Post(s)
Liked: 38
Originally Posted by samsvoc View Post
Eagerly awaiting the LA6200 calibrations. Thanks Showroomcali
When measured in CD/M or Nits, what is the minimum black level and maximum luminance level this TV can do? Right now, I am interested in a few Samsungs which can go from 0.07 to 350. Yet if the LA6200 can go above 350, then I'll set my heart on the LG because everyone who I watch movies with prefers to let in the glorious light a mild, sunny day provides.
Big C is offline
post #118 of 215 Old 07-12-2013, 12:06 PM - Thread Starter
Liked: 32
I can measure that this evening and let you know! Stay tuned!
post #119 of 215 Old 07-12-2013, 12:06 PM - Thread Starter
Liked: 32
post #120 of 215 Old 07-12-2013, 12:06 PM - Thread Starter
Liked: 32
Reply LCD Flat Panel Displays
Samsung Un60es7500 60 Inch 3d Slim Led Hdtv , Lg 55la7400 55 Inch Cinema 3d Led Smarttv
