Showroom "Calibrations" - Page 8 - AVS Forum | Home Theater Discussions And Reviews
Old 06-05-2014, 09:52 AM
Otto Pylot's Avatar
Quoted: 1360 Post(s)
Liked: 853
Originally Posted by colinssc View Post
Would you be able to post some calibration settings for UA50F5000?
See post #209.
Otto Pylot is online now
Old 06-05-2014, 06:17 PM
colinssc's Avatar
Ah...sorry I read through the first 6 pages and posted...thanks!
colinssc is offline
Old 06-05-2014, 06:23 PM
Otto Pylot's Avatar
Liked: 853
Just grab yourself the free AVS HD709 cal disk or a commercial one like WoW, Spears & Munsil, etc and adjust what you can. It may be all you need to improve pq. You won't be calibrating your tv but you might be pleasantly surprised at what a little "accurate" tweaking can do.
Old 06-05-2014, 06:25 PM
colinssc's Avatar
I actually have the AVS HD709. However my tv does not have much settings to play around with. I am quite happy at the moment with the settings I have but was hoping to compare to see what else I can do.
I played the HD709 thru my pc though...have read somewhere that the GPU might affect the colour a tad bit...
Thanks anyway :)
colinssc is offline
Old 06-05-2014, 09:08 PM
Otto Pylot's Avatar
Liked: 853
It's probably best if you use any cal disk thru a blu-ray player with all video processing off or disabled, and the same for your tv, all video processing off. Using a PC can have some definite issues.
Samsung Un60es7500 60 Inch 3d Slim Led Hdtv , Lg 55la7400 55 Inch Cinema 3d Led Smarttv
