Wi-Fi or Ethernet - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 07-01-2013, 08:11 AM - Thread Starter
Thelzydog's Avatar
I'm getting ready to purchase the Sony W900A (as opposed to the Samsung F8000).
Do I need an Ethernet connection or does the build-in Wi-Fi allow for smooth streaming? My Roku works OK but sometimes does the buffering number on me.
Your help needed so I can make a decision about installing an Ethernet connection or not. Thanks.smile.gif
Thelzydog is offline
post #2 of 7 Old 07-01-2013, 10:57 AM
Steve S's Avatar
Liked: 46
hard-wired (Ethernet) connection is always better, all other things being equal.
Steve S.
Steve S is offline
post #3 of 7 Old 07-01-2013, 12:23 PM - Thread Starter
Thelzydog's Avatar
Thanks. I think so too, but running an Ethernet cable, about a hundred feet, is a chore. Was interested to see if anyone is using their W900A with just Wi-Fi and the results obtained.
post #4 of 7 Old 07-07-2013, 02:10 AM
CATYPH202's Avatar
I had issues with YouTube 1080p streaming through Wi-Fi mad.gif on my 55NX720. Switched to Ethernet and now everything's good. cool.gif
CATYPH202 is offline
post #5 of 7 Old 07-07-2013, 08:01 PM
tubetwister's Avatar
Location: The Outer Limits....Don't trust any air I can't see ☺
Quoted: 1384 Post(s)
Liked: 622
I had issues (buffering) with You Tube 1080 p buffering over Wifi . No issues at 720p though also none with Netflix HD. Not into a Sony set but rather a PC with HD video HDMI into a Toshiba.
The Sony PS3 on the big set streams Netflix HD over WiFi without buffering . As you probably know PS3 does not support You tube without a 3rd party app.
If your Roku buffers the TV might also ....... that sometimes depends on your internet connection speed ofc Ethernet is always better I would try the WiFi and see.
tubetwister is offline
post #6 of 7 Old 07-07-2013, 08:09 PM
jbug's Avatar
Quoted: 249 Post(s)
Liked: 127
I use Wi-Fi and never have any problems to speak of. My TV is in the basement and the router is upstairs. When I moved to Wi-Fi and first tried it I was amazed that it worked so well. My ISP is WOWWAY.
jbug is offline
post #7 of 7 Old 07-07-2013, 08:23 PM
yaomizzle's Avatar
Liked: 26
I have an asus ac66 and inside of my house I get the same speed whether I use wifi or hardwire
Sent from my SCH-I605 using Tapatalk 2
yaomizzle is offline
Reply LCD Flat Panel Displays
