another Panasonic Blink question (12 blinks) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 17 Old 07-06-2013, 10:26 PM - Thread Starter
NorthOfDallas's Avatar
Howdy!
I've been searching extensively and have found little (nothing, really) that mentions a 12 blink problem on a Panasonic LCD. I've found extensive info on the Plasma's but not on my little TC-L42U25 that was given to me. I can't seem to find anything on 12 blinks, but seeing as how it only has 2 boards, I'm fairly certain its one of 'em. The power board is the MPF2941, if there's any known problems with it.
I found a number of guides on http://tsn.pstc.panasonic.com/ by searching Google, but nothing that references my model specifically. All fo the info I've gleaned so far was close, but not nearly the same, so I have no leads to follow.
The only other indicator I have of the problem is that after a moment that it starts to boot, there's a high pitch whine from the power board, then the blinks start. There's not been a picture since this issue began.
Any assistance would be most appreciated!
Corey
NorthOfDallas is offline
post #2 of 17 Old 07-09-2013, 12:56 PM - Thread Starter
C'mon folks, someone's got an answer... Don't be shy...
post #3 of 17 Old 07-11-2013, 12:59 PM - Thread Starter
post #4 of 17 Old 07-20-2013, 01:02 PM - Thread Starter
Can someone at least point me in a direction to find the answer? Thanks in advance.
post #5 of 17 Old 07-20-2013, 01:49 PM
llabine1's Avatar
http://www.electronica-pt.com/images/fbfiles/files/Panasonic_TC_L42D2_TC_L37D2_TC_L42U25_TC_L37U22_TC_L32U22_TC_L37X2_TC_L32X2_TC_L22X2_TC_L37C22_TC_L32C22_2010_LCD_Training_Guide__TM_.pdf
That is a link to the technical repair guide to your tv..you are right I googled till I could google no more but still did not find a twelve blink answer. it probably is the power supply but that is just an educated guess.
llabine1 is offline
post #6 of 17 Old 07-22-2013, 04:47 PM
mpeter86's Avatar
I have the exact TV and the exact same problem. I recently bought a new power board on ebay...didn't help...just put in an A board I bought off ebay today...didn't help. I turn on the tv and a black screen appears, then about 10 seconds later I hear a high pitched noise, the tv shuts off and the light blinks 12 times. Does anyone know what could be causing this???????
NorthOfDallas likes this.
mpeter86 is offline
post #7 of 17 Old 07-22-2013, 04:50 PM - Thread Starter
llabine1, thanks for the info. Unfortunately, as you said, it didnt tell us much about the probelm.
Mpeter86 - that is EXACTLY my tv's problem. I forgot to mention the squeal. It seems to come from the power board on mine - is that your experience on yours?
As soon as i get the chance, I will probably try to apply this fix...but I'd sure like to be closer to an answer and not just poking around with my iron hoping for good luck:
http://www.youtube.com/watch?v=qQ_iLxx3Fj4
post #8 of 17 Old 07-22-2013, 05:13 PM
mpeter86's Avatar
The sound comes directly from the power board.
I was watching the tv one day and then it just shut off and has been unusable ever since. I replaced the power board but it still makes the noise and nothing changed. Not sure what to do now that I have 125 dollars of replacement boards in the tv and it still doesn't work. I still am unable to find anywhere what 12 blinks means...which is quite strange in my opinion.
mpeter86 is offline
post #9 of 17 Old 07-24-2013, 07:06 AM
mpeter86's Avatar
Anyone know a solution to this issue or should the TV be thrown away????
mpeter86 is offline
post #10 of 17 Old 07-27-2013, 02:30 PM
mpeter86's Avatar
North,
Did u try what was shown on YouTube?
mpeter86 is offline
post #11 of 17 Old 07-31-2013, 07:20 AM - Thread Starter
I havent yet had the time. I am graduating college next week (as an adult with two kids) and my time has been pulled in all directions. Ill report once I have. Sorry for the delay
post #12 of 17 Old 08-16-2013, 11:06 AM
mpeter86's Avatar
Dallas,
I recently brought my TV to a repair place and had them try to diagnose what the issue was. They said that the T-CON board had a couple of blow resistors that was causing the problem. They wanted 150 dollars to repair the resistors. If you go on ebay you can buy the board for 10 dollars and that includes shipping. My board should be here Monday so I will let you know if that solves the problem. Hopefully someone is willing to buy back the other boards that are unneeded.
mpeter86 is offline
post #13 of 17 Old 10-27-2013, 07:26 PM
Holly Hill's Avatar
MPeter did the Tcon board work on it? I have this same issue for my TV
Holly Hill is offline
post #14 of 17 Old 01-11-2017, 03:11 PM
opy01's Avatar
Has anyone had any luck with this? Mine had 12 blinks before but now it just has a high pitch squeal and never shuts off and the screen is always black. I messaged a couple of people selling parts and they do not want to sell to me because there is no way to tell what the real issue is.
opy01 is offline
post #15 of 17 Old 01-13-2017, 08:52 AM
opy01's Avatar
Well I ordered the T-Con board and will post my findings. If that does not work I'll order the power supply. That will put me $54 down so if they both fail, not a huge loss.
opy01 is offline
post #16 of 17 Old 01-15-2017, 02:43 PM
opy01's Avatar
T-con board did not help. I ordered the power supply and will see what happens.
opy01 is offline
post #17 of 17 Old 01-31-2017, 11:46 AM
opy01's Avatar
The power supply did not fix it so I ordered the backlight inverters. I should have ordered those first since the squealing stopped when I unplugged the left inverter. That was the problem and the TV works like new again. I hope this helps someone else out there.
opy01 is offline
Reply LCD Flat Panel Displays
Panasonic Tc L42u25 42 Inch 1080p 120 Hz Lcd Hdtv
