What are the built-in memory and cpu speed of LG xxLA8600? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 07-07-2013, 09:49 PM - Thread Starter
abc2013's Avatar
Hello everyone,
I have spent a lot of time to find out the built-in memory and cpu speed of LG xxLA8600 3D Smart TV before I make a decision to buy, but can't find any information about that. If you owned this TV, you can find out the built-in memory of LG xxLA8600 by clicking the HOME button on the remote control, then click the link "My Apps". A new screen will show the total amount of built-in memory on the top right corner of the screen. I appreciate for any information about this TV.
abc2013 is offline
post #2 of 5 Old 07-07-2013, 09:59 PM
Otto Pylot's Avatar
Quoted: 1373 Post(s)
Liked: 858
Can't you find one in a store and do the same?
Otto Pylot is online now
post #3 of 5 Old 07-07-2013, 11:05 PM - Thread Starter
abc2013's Avatar
Thank you for your response. Right now, Futureshop.ca and Bestbuy.ca don't have this model in their stores. However, I just found out from one website said that LG xxLA8600 has 4GB of memory, but I would like to know the ACTUAL amount of memory left for web browsing. I would be great if I can find out the speed of the cpu of this model.
abc2013 is offline
post #4 of 5 Old 07-08-2013, 09:15 AM
Otto Pylot's Avatar
Liked: 858
LG spec sheet? LG Support?
post #5 of 5 Old 07-08-2013, 10:57 PM - Thread Starter
abc2013's Avatar
I couldn't find any information about RAM or CPU speed from the specification sheet. I already chatted with LG Tech Support of Canada. I just waste my time to chat with her.
abc2013 is offline
Reply LCD Flat Panel Displays
