Vizio 80" M801D-A3 owners thread - Page 19 - AVS Forum | Home Theater Discussions And Reviews
 240Likes
Old 11-19-2013, 11:38 AM
hidaven's Avatar
Lol, most of the issues are with un uniformity with regards to lighting. Mine had a flickering backlight and 2 really bright areas that destroyed any moderate dark scene.
Most of these issues come from the fact that edge lit, high hz sets are plain crap. It is a bit better on smaller less than 50 inch sets but horrible for big screens. LCD was the dirty step child when compared to plasma way back. I think that the next step towards OLED will be the big game changer that we hoped for. Although less longevity, the colors, motion, blacks are equal tot he best plasma but with more deep and vibrant backlit color. My thinking that by the time an 80 inch hd4k OLED comes close to 4000.00 it will be at least a few years out. I talked to the Oppo tech and he said a hd4k blu ray player wouldn't hit the shelves until 2015. All things considered, sitting 11.5 feet from this set (assuming you have a decent one) is still a very enjoyable experience. Coming from a projector I am much more happy. I'd never go back to a projector after having this set. Heat, cost of bulbs, noise, LCD burn outs! You can keep it......
hidaven is offline
Old 11-19-2013, 11:48 AM
wmassie's Avatar
Even a projector that could adequately light up a 165 inch diagonal screen?
I plan to use the 80 inch as a secondary display but i still need bigger!
wmassie is offline
Old 11-19-2013, 03:40 PM
zman803's Avatar
Originally Posted by jbug View Post
That was a zombie movie.
LOL!!!
So it's not the TV. cool
iChristopher likes this.
zman803 is offline
Old 11-19-2013, 04:33 PM
iChristopher's Avatar
anyone else having issues with lip-syncing?? I'm having to adjust it every time I change the channel....
Note: This post may contain misspellings, grammatical errors, disorganized sentence structure, or may entirely lack a coherent theme but it will only add to the overall beauty of my message.
iChristopher is offline
Old 11-19-2013, 07:16 PM
rd7723's Avatar
Quoted: 17 Post(s)
I am debating between this set and several projectors. I will be witting approx 11 feet from the screen. What kind of projector did you have? how does the pic quality compare and do you miss the size? Thanks for any response.
rd7723 is online now
Old 11-19-2013, 10:41 PM
The Pup's Avatar
Originally Posted by The Pup View Post
I've waited a week for the update (currently at V1.08.15.0000)--this is truly a 1st world problem.
Originally Posted by phildaant View Post
LOL. I still want top know how Vizio does the serial number grouping for the latest firmwares since none of us figured out the patterns yet. :P
I contacted Vizio customer support and talked to the 2nd and 1st string (supervisor) techs and neither were sure of what methods, means, or procedural logic was used for pushing firmware to customers.  The supervisor stated that the firmware update check occurs upon start-up, however exactly when my set would receive v1.09 is a mystery to all.  I also had to explain the missing menu features with v1.08.
When, and if, my M801D-A3 updates, I am going to have to brace myself for this significant life-affirming event.
phildaant likes this.
The Pup is offline
Old 11-20-2013, 07:49 AM
jbug's Avatar
Quoted: 249 Post(s)
Liked: 127
Originally Posted by zman803 View Post
LOL!!!
I hope it's not the TV.
jbug is offline
Old 11-20-2013, 08:25 AM
mlgreen's Avatar
I'd like to know this as well.
mlgreen is offline
Old 11-20-2013, 11:37 AM
hidaven's Avatar
If your only 11 feet from the screen a projector is a bad choice. I'm 11 feet from the vizio and its more than enough.
Projectors are best used when you need over 100 inches and your sitting back 15 to 25 feet. I have several projectors including a Sanyo PLV 70
A Sony and JVC. They all were a PITA. You need to be careful of dust getting sucked into the unit, heat buildup, noise. Only reason why we all went that route
Is that no manufacturer made a plasma or LCD over 55 inches 10 years ago!
You had no choice but to get a projector. Now if you were 20 feet away and wanted 120 plus inches for a screen then you still have no options other than a projector.
But trust me, the ease of a big LCD panel combined with the MUCH better back lighting and vivid color is a clear choice if sitting within 15 feet. Also, consider that you need a battery backup/ surge supply fort he projector as well. If you loose power while watching a movie you need that bulb and LCD panels to cool off in the projector before powering off. If you go to complete shutdown with no cool off you will burn out a LCD panel. You have 3 I believe. Those panels are 500.00 plus to replace and are not warranted if its from a power outage. They can tell, don't ask how I know this......
Lastly, the power consumption is almost 4 times as much than the current big panels. As far as viewing distance, if you go too big a screen sitting too close, you will suffer eye fatigue and possible headaches. Why? Sitting too close to a big screen makes you scan the screen to get the full picture. This is why they recommend 1.5 times the diagonal or 2 times the height of the screen for the minimum viewing distance. This is also why hd4k is a joke as 1080p is just as clear at 12 feet viewing an 80 inch screen. OLED is a different story but my money will be on the 80 inch OleD 1080P offering. Besides, the cable companies can't even offer true HD to us anyway. 1080i and its compressed like crap, so how are they going to offer a quality signal using 4 times the bandwidth? Fiber optic source to set is the only way and that's a decade away at least.
Oh, and one more for you, don't even think of using that projector unless your in a dark room. Most current projectors are 1500 ANSI lumens and once calibrated your around 1200 or so. Not very bright, plus light will totally wash out the picture if you have ambient or reflections in the room. I had a 2200 ANSI lumen projector and it just did the job in a moderately dark room. My vizio has soooooooo much more pop as its back lit. Almost 3d like compared to a projectors picture. That semi clear glass in front of these LCD/ plasmas really make the image pop compared to the flat, matte projector image.m and be prepared to get a quality screen for that projector as well, I used a Da Lite screen fire hawk 1.0 grey to add some contrast.
These panels are rated at over 50k hours. Get one and start enjoying your favorite content. I sold over 8000.00 worth of projector/ screen equipment and got about 1000.00 for it from someone who needed it as a portable meeting solution. That's where projectors belong. Quality control issues aside, this is he best HD experience I've had in the last 10 years. If you gave me the best HD projector out there for free, I wouldn't swap it for a large LCD panel. Kinda like going back to a manual trans vs. the newer automatics. : ). Again, all of the above is just my own opinion.
hidaven is offline
Old 11-20-2013, 12:10 PM
wmassie's Avatar
Post this in any of the projector threads -should make for a lively conversation.
wmassie is offline
Old 11-20-2013, 01:08 PM
hidaven's Avatar
Lol, they will attack me like a pack of wolves. Facts are facts though, my dislike is my opinion of course.
Projectors are going to go the way of 8 track tape unless someone is looking for a very big application.
VegasSmitty likes this.
hidaven is offline
Old 11-21-2013, 01:55 PM
phildaant's Avatar
Quoted: 857 Post(s)
Liked: 312
I just got a re(ply/sponse) from Vizio's e-mail support about their firmware upgrades:
"... Here is a suggestion to try to get the update to go through a little
faster for you. As long as your device is connected to the internet you
will receive the update. Typically the update request is sent by your TV
to our server as soon as connection to the internet is established,
however it is not downloaded to your TV until the TV is powered off.
I would recommend that you leave the TV on for 15 minutes (after
connecting it to the internet) to ensure that the request for update is
sent from your TV and also received by the server, then turn the TV off
and leave it off for 15 minutes. If you turn the TV back on and you do not
receive a message informing you that your TV is updating, then you*ll need
to leave it on for another 15 minutes then off again for 15 and so on.
I do want to add that I've seen best results with a hardwire connection to
your modem/router, so if at all possible I would advise that you hardwire
your TV to your modem/router when attempting the steps I've advised above.
If you can't received your update within 48 hours, then we would need you
to call in to further troubleshoot the issue if necessary..."
Hmm, the HDTV is on more than 15 minutes almost daily. I am not going to force it on and off. That would kill the new HDTV! However, it is on wireless and its signal strength is yellow color (not green) due to the distance of the place. That should be OK?
What about you guys?
phildaant is offline
Old 11-21-2013, 04:41 PM
Jasonn B's Avatar
Quoted: 303 Post(s)
Liked: 119
I'm on wifi and got my update a week ago. Why am I the only one with the update?
80" Vizio LED - (60" Vizio plasma - retired)
Harmony 890 Remote
X10 Commander Iphone App = full control of lights, fireplace, pool, shades, from Iphone
X10 IR543 controller
Hunter Douglas motorized shades
Jasonn B is offline
Old 11-21-2013, 04:45 PM
phildaant's Avatar
Quoted: 857 Post(s)
Liked: 312
Old 11-21-2013, 05:55 PM
bigcat's Avatar
Quoted: 93 Post(s)
Liked: 26
My TV is on a wired connection and it's off all day except during the evening when I get home from work. It hasn't picked up any updates.
BenQ W1070/Silver Ticket 120"/Denon X4200W/Infinity Primus | Vizio 80" 3D LED M801D-A3 w/ Denon X3200W/Infinity Primus | Sony Bravia XBR-60LX900 w/ Sony HTCT550W 3D Sound Bar | Sony SXRD KDS-R70XBR2 w/ Onkyo HT-S770 | Sony PS3 (Slim) | DIRECTV Genie HR44-500, C41s | Harmony 700
bigcat is online now
Old 11-21-2013, 06:18 PM
hidaven's Avatar
No update here either........
hidaven is offline
Old 11-21-2013, 07:14 PM
laserjock II's Avatar
Quoted: 704 Post(s)
Liked: 381
Any of the owners of this set unhappy or wish they had something different?
laserjock II is online now
Old 11-21-2013, 11:16 PM
hidaven's Avatar
Question.......Every so often my TV is going off for a few seconds then comes back on?? It did this with the last set too.
Im def. loosing power to the set for when it comes back on im getting the info window with the internet connection etc. on top.
Any idea as to what can be causing this?? Im hooked up HDMI and its happening with the set top box, the blu ray player AND the PS3....
All components going through an Onkyo RX. Oh, and the Onkyo doesn't loose power when the TV goes down for a few seconds..... Thanks.
hidaven is offline
Old 11-21-2013, 11:28 PM
netkrazed's Avatar
No regrets here with 80, and have had it for a few months. It replaced a mits 62" dlp...
laserjock II likes this.
netkrazed is offline
Old 11-21-2013, 11:39 PM
PlayNice's Avatar
Quoted: 185 Post(s)
Liked: 174
Mine did that with my old HDMI cables connected to to then I ordered new HDMI cables (from Amazon) cheap and they worked with no issues. I don't know if that was the issue but I haven't seen it do that again since I replaced the cables. Hopefully the firmware update will fix this, I feel it's a software issue not hardware.
Vizio 80" 3D LED M801D-A3 ISF Calibrated | Onkyo TX-NR818 w/ Polk Monitor 50 (Fronts), Onkyo SK-520 (Surronds), SKW-770 (Sub) | Win 8.1 PC i7 3930k, 2 SLI GeForce 770's, 32GB RAM | Mac Mini 2011 i5 2.3Ghz, 16 GB RAM w/ PLEX | Roku 3 | Oppo BDP-103D | Xbox One, PS4, Wii U, Xbox 360 S, PS3 Slim | Harmony Touch
PlayNice is offline
Old 11-22-2013, 12:44 AM
PDDUFRENE's Avatar
Liked: 50
It could be your receiver, Onkyo has a bad history of hdmi problems.
PDDUFRENE is offline
Old 11-22-2013, 01:43 AM
dad1153's Avatar
Quoted: 1816 Post(s)
Liked: 1137
Send a message via Yahoo to dad1153
I asked my father today (it's his 65th birthday smile.gif). Jokingly, he said he should have gone with the Panny plasma Antonio Banderas is gawking at in Almadovar's "The Skin I Live In."
dad1153 is offline
Old 11-22-2013, 08:58 AM
Jasonn B's Avatar
Quoted: 303 Post(s)
Liked: 119
Pretty cool. This tv beats most out for input lag!
http://www.displaylag.com/display-database/#participants-list
Harmony 890 Remote
Jasonn B is offline
Old 11-22-2013, 10:37 AM
renegaderon's Avatar
I got my 80 inch Saturday and I love it, I have  had no problems with it. No update here either.
renegaderon is offline
Old 11-22-2013, 11:41 AM
windsurf3d's Avatar
OK, some interesting things to add to the remote issue.  I have the M801D-A3.  LOVE IT.  Great tv, great picture.  No bluetooth which is a bit odd, but I'll figure a workaround.
So on to the remote.  The issue I face is the TV turns on, and then it stops responding to the remote.  No button works.  I assumed it was the remote or IR sensor.  It isn't.  After playing around for a while I've figured out two important things (like someone to verify if possible)
1.  If the input isn't sending a signal, this locks the sensor input. In other words, the remote won't make anything change on the TV.  Sometimes the power button will work, but that's it.  I noticed this because my remote issues seemed very intermittent.  Thought at first it was my Popbox since it happened most often on it.  Got a clue when my DirecTV receiver had the same issue.  I played around with setting the TV to different inputs, powering down, then powering up with the device on that input on or off.  Off caused issues most of the time.
2.  The problem eventually goes away.  If I'm patient (not very often...) it will figure it all out after 5 minutes or so.
Once again, if someone else with an 80 would check this out I'd appreciate it.  You can contact me at david@manoroaks.net directly.
Finally to the folks who are looking for mounts...  The mount I used us a U shaped piece of metal that hooks into the upper bracket.  You're supposed to screw in some bolts to fix it to the lower.  I didn't bother.  I'm able to swing it forward and gain access to the connections very easily.  I'm only swinging it forward 4" or so, so if its recessed into a wall there may be issues.
windsurf3d is offline
Old 11-22-2013, 01:13 PM
netkrazed's Avatar
Are we talking about when you use the vizio remote? No probs here with my Harmony One.
Old 11-22-2013, 01:19 PM
Otto Pylot's Avatar
Quoted: 1368 Post(s)
Liked: 854
I don't have a Vizio but I highly recommend a Harmony remote. They can be pricey and a tad bit difficult to setup (there's lots of help in that regards) but it's a rarity to find a HTS component that they won't work with (unless it is really old). I have an old Harmony 880 that is a solid performer and the Harmony One is nice upgrade to that.
netkrazed likes this.
Otto Pylot is offline
Old 11-22-2013, 02:53 PM
tsakuta's Avatar
I've been looking for a good 80" led to replace a Mitsubishi 73" dlp. I really like what I've seen and read regarding the Vizio. I was in Sam's club the other day and they had the display for sale. As I walked up to take a look, they were marking it down again. I was blown away at the price. I picked it up for $1918, with the remote, 4 pair of glasses and the manual.
So far I am impressed with both 2D and 3D performance. Details on a good quality Hd program are excellent, with very minimal motion blur. At times it will almost look 3d. I haven't calibrated the settings yet. The remote is a little touchy, but not bad. Viewing angle is pretty good. I would highly recommend even at the $3000+ price, which is what I planned on originally spending.
tsakuta is offline
Old 11-22-2013, 03:42 PM
Jasonn B's Avatar
Quoted: 303 Post(s)
Liked: 119
Post a picture of that receipt for the 80" for $1,900. That's crazy.
Harmony 890 Remote
Jasonn B is offline
Old 11-22-2013, 08:36 PM
rd7723's Avatar
Quoted: 17 Post(s)
Hey thank you for the response, it gives me something to think about.
Vizio M801d A3 80 Inch 3d Led Hdtv
