Vizio 80" M801D-A3 owners thread - Page 42 - AVS Forum | Home Theater Discussions And Reviews
 240Likes
post #1231 of 2132 Old 07-25-2014, 07:33 AM
jjmpeters's Avatar
Originally Posted by phildaant View Post
Hi again!
I just noticed Direct-GE-VIZIOTV WAP on my 13" MacBook Pro. I assume this is from the 80" HDTV. Is anyone else seeing this too? If so, then what is it about? Is it acting like a WAP for network even though this HDTV is already connected to a wireless router?
Thank you in advance.
Mine says "DIRECT-WC-VIZIOTV". I can't figure how to turn it off. Anybody?
I attached a picture of my other Vizio TV which I have in wireless mode, while my M801D is in wired mode.
phildaant likes this.
jjmpeters is offline
post #1232 of 2132 Old 07-25-2014, 08:18 AM
phildaant's Avatar
Quoted: 857 Post(s)
Liked: 310
Finally, someone else notices it too. The one I saw was wirelessly connected to a router since it is far away.
phildaant is offline
post #1233 of 2132 Old 07-25-2014, 09:14 AM
Philharmonic's Avatar
Bluetooth headphones with Vizio 80 M series
I have a Vizio 80" M series. Can't figure out how to pair Bluetooth headphones. Is there a menu setting I am missing?
Philharmonic is offline
post #1234 of 2132 Old 07-25-2014, 09:55 AM
Citivas's Avatar
Quoted: 317 Post(s)
Liked: 191
Wow, I didn't even know that was a feature of the set. Sounds cool though.
Citivas is offline
post #1235 of 2132 Old 07-25-2014, 02:17 PM
Liked: 0
PlayNice, thanks for your settings, I really appreciate them.
However, I noticed that you did not post your advance settings, are they the same one from the previous one you posted?
Ragonzo is offline
post #1236 of 2132 Old 07-25-2014, 02:56 PM
PlayNice's Avatar
Quoted: 185 Post(s)
Liked: 174
I didn't post them cause when you calibrate according to ISF you turn off all advanced video processing modes, that way you calibrate a clean signal. Those are the freshly calibrated settings without any processing. You can add the others at your discretion to improve your picture.
I just finished the ISF cert course and I am getting the Kline K10 meter soon and will re calibrate the TV. That meter is more accurate and the meter used by studios in Hollywood for calibration. I will post those settings shortly after it gets delivered.
The settings I have posted are ok but now with the added knowledge I can do better so I will keep you posted.
josephpearson and Ragonzo like this.
PlayNice is offline
post #1237 of 2132 Old 07-26-2014, 09:46 AM
phildaant's Avatar
Quoted: 857 Post(s)
Liked: 310
Post Direct-...-VIZIOTV SSID
I got two/2 e-mails from Vizio's technical support about it: "This is a network that your remote uses to be used through WiFi Direct instead of regular IR." and "... http://store.vizio.com/documents/dow...UM_M801dA3.pdf. Pages 44-47 show how to pair your devices to the remote..."
Has anyone used this feature yet?
post #1238 of 2132 Old 07-26-2014, 01:14 PM
phildaant's Avatar
Quoted: 857 Post(s)
Liked: 310
post #1239 of 2132 Old 07-27-2014, 05:14 PM
rotohead's Avatar
Quoted: 103 Post(s)
Liked: 54
If you paired the remote to the tv then you are using it. My set up is such that I am glad the tv accepts both ir and the wifi signals. I also find the Vizio remote in paired mode works very well. My Harmony Ultimate remote needs to use IR to communicate to the tv. The Vizio remote does seem to eat through batteries though.
Also on a seperate note, the Rhapsody app is no longer supported by Vizio.
rotohead is offline
post #1240 of 2132 Old 07-27-2014, 05:31 PM
phildaant's Avatar
Quoted: 857 Post(s)
Liked: 310
Question
Huh? I thought this RC uses IR. Wait, is that why it was so crappy with the older firmwares? It uses wireless network now for better interactions? Vizio also told me you can't use anything else for wireless devices with this HDTV? So, can't use HDTV as an extended WAP?
post #1241 of 2132 Old 07-27-2014, 05:44 PM
rotohead's Avatar
Quoted: 103 Post(s)
Liked: 54
The remote and tv create their own wifi network much like some cameras do and the Parrot drone RC toy that's controlled by a smart phone does the same thing. It's separate from your home network and can not be used as a access point. I believe it had issues at first (the ver before 1.34) but seems to work perfectly for me since I first plugged in the tv.
rotohead is offline
post #1242 of 2132 Old 07-27-2014, 05:47 PM
phildaant's Avatar
Quoted: 857 Post(s)
Liked: 310
Thumbs up
Interesting and thanks.
post #1243 of 2132 Old 07-27-2014, 06:59 PM
andy sullivan's Avatar
Quoted: 754 Post(s)
Liked: 403
If you had to do it all over again today would this still be your TV of choice?
andy sullivan is online now
post #1244 of 2132 Old 07-27-2014, 07:04 PM
PlayNice's Avatar
Quoted: 185 Post(s)
Liked: 174
Yes, the only thing wrong with the set technically is the the red is out of spec (rec 709) but only by a little bit. For the Price and size it's a steal! Full CMS, 2 and 11 point grey scale plus gamma options. This budget set have a ton of pro calibration features!
PlayNice is offline
post #1245 of 2132 Old 07-27-2014, 07:31 PM
Quoted: 754 Post(s)
Liked: 403
Thanks. Any actual PQ differences between this and the 2014 non 3d version? Has anybody experienced much of a problem with clouding or banding? Is there anybody here that has compered this set to the Sharp 80"? Sorry to ask such basic questions but my choosing decesion came upon me rather suddenly.
post #1246 of 2132 Old 07-27-2014, 07:36 PM
Citivas's Avatar
Quoted: 317 Post(s)
Liked: 191
I've had this set for about 45 days and will likely return it before the 90 day period is up. Main reasons:
1) Very frustrating lip-sync issue theta oddly didn't develop until I already owned it for several weeks. Keep in mind this is an issue even using the internal speakers, so it's not an AVR or sound bar sync problem, and it happens randomly across a variety of inputs, including the TV's own internal apps. So when the TV's own streaming apps using the TV's own speakers can't keep lip synced, that's a really annoying issue. It's possible they will fix it with a firmware update or that there is a consistent work-around (offsetting the audio doesn't work because the problem is intermittent so the off-set would just trade fixing the problem for causing it when it otherwise would have worked).
2) The remote is completely unstable. It frequently stops responding to any button until you do a battery pull.
Others have experienced both these issues leading me to believe mine is not a unique lemon. I have no idea why some people do and some don't have these issues.
3) I am picky. I really have the Soap Opera Effect and I feel like I have never quite gotten rid of it, even with motion processing off. And the color is just not quite right -- that may be fixable with a full calibration but I don't want to invest hundreds on it on the chance it helps given the above issues.
All that said, it's still a great value set. The UI is great, the CMS is nice. And it's less than $3K. Only the Sharp LE650 plays in the same value range and my big fear there is the panel lottery and so many people complain about being on second or third sets. Still, if I could only spend $3K I might take a second look at the Sharp given the issues above. Or, if I really couldn't spend more, I might be on the phone with customer service seeing if I could solve those issues…
Citivas is offline
post #1247 of 2132 Old 07-27-2014, 11:21 PM
Quoted: 754 Post(s)
Liked: 403
Does this lip sync problem continue on with the non 3d 2014 model? Regarding the panel does anybody know what type panel Vizio is using here? IPS, S-PVA,or who the manufacture is? I suppose the same question could be asked about the Sharps.
post #1248 of 2132 Old 07-29-2014, 05:57 AM
poop1's Avatar
Ok,need advice. Do you think $2200 is a good deal for a display model for this tv? It has been on display for a little over a month. Also I can get a 5 year extended warranty through square trade. What do you guys think?
poop1 is offline
post #1249 of 2132 Old 07-29-2014, 07:16 AM
Jasonn B's Avatar
Quoted: 303 Post(s)
Liked: 119
Yes. Get it.
Jasonn B is offline
post #1250 of 2132 Old 07-29-2014, 12:37 PM
Liked: 1
So I am about ready to pull the trigger!! Want to make sure this 80" is the best bang for the buck! I see the referbished at walmart and best buy for under $3000 and the new for $3200.. I have found one on ebay for $2399 thats refurbished . what would you do?
davdoc0011 is offline
post #1251 of 2132 Old 07-29-2014, 01:08 PM
Jasonn B's Avatar
Quoted: 303 Post(s)
Liked: 119
Costco, new, pick it up today, $2,949
http://www.costco.com/Vizio-80%22-10...100055150.html
80" Vizio LED - (60" Vizio plasma - retired)
Harmony 890 Remote
X10 Commander Iphone App = full control of lights, fireplace, pool, shades, from Iphone
X10 IR543 controller
Hunter Douglas motorized shades
Jasonn B is offline
post #1252 of 2132 Old 07-29-2014, 01:14 PM
Citivas's Avatar
Quoted: 317 Post(s)
Liked: 191
David, just to confuse you further, some of the things you are seeing are the 2014 model and some are the "new" 2014 model. The $3,200 is the MSRP for the 2014 version. The $2,950 is the Costco price of the still in-stock 2013 model. Probably the refurbs are mostly 2013 but just guessing.
Now here's the thing... The 2014 model is basically the 2013 model without 3D. That's right, it's basically the same TV but they removed the 3D functionality. They allegedly put some better software in it but that hasn't been proven by any review or post I have seen. Physically it's basically the same TV. Which makes the Costco price for last year's model a better deal.
BTW, you can order it online from Costco without being a member, though they charge a fee for that. But you can instantly sign up for membership and but the TV and get free delivery and a 90-day no-fault return window (they would pick it up free). Yo can also by a 3 year extension on the warranty (and Costco automatically extends it one year over the manufacture anyway so that means 5 years total) for $89. Compare that to probably $300-400 at BB.
Citivas is offline
post #1253 of 2132 Old 07-29-2014, 01:29 PM
Jasonn B's Avatar
Quoted: 303 Post(s)
Liked: 119
By the way, the newer one without 3D is $50 more.
Harmony 890 Remote
Jasonn B is offline
post #1254 of 2132 Old 07-29-2014, 01:53 PM
Liked: 1
Im in Destin Florida 32541... Dont know of on thats close..
post #1255 of 2132 Old 07-29-2014, 01:54 PM
Liked: 1
Would anyone go with this model on ebay ? http://www.ebay.com/itm/Vizio-80-M80...item540a115867
$2399 Delivered no tax
Showed a 60 day warranty then I can purchase a 2 year extended for $149.95 $2549 with 2 year warranty
post #1256 of 2132 Old 07-29-2014, 02:42 PM
Citivas's Avatar
Quoted: 317 Post(s)
Liked: 191
You don't need to be close to order online. They use the same large item couriers as Amazon and most of the online retailers.
Citivas is offline
post #1257 of 2132 Old 07-30-2014, 06:41 AM
Liked: 1
If i go the refurb route whats the best warranty?
post #1258 of 2132 Old 07-30-2014, 09:09 AM
blackssr's Avatar
Quoted: 1158 Post(s)
Liked: 578
I wouldn't feel comfortable buying a TV off an eBay seller. For less than $ 3k you grab a new unit off Amazon/Costco and have the ability to return if not happy.
blackssr is online now
post #1259 of 2132 Old 07-30-2014, 10:34 PM
NODES's Avatar
Quoted: 652 Post(s)
Liked: 271
I looked at that one as well, go new from Costco. These will not be here much longer.
I am hoping I can still grab one in Oregon when I head there next week.
NODES is offline
post #1260 of 2132 Old 07-31-2014, 07:07 AM
Liked: 1
Could someone please post the best setting for the 80 in model please!
thanks guys
Reply LCD Flat Panel Displays
Vizio M801d A3 80 Inch 3d Led Hdtv
