Vizio 80" M801D-A3 owners thread - Page 43 - AVS Forum | Home Theater Discussions And Reviews
 240Likes
post #1261 of 2132 Old 07-31-2014, 01:16 PM
markiejones's Avatar
New purchase - questions on some issues
Hi all,
My set came on Monday, and I kind of love it. However, I've noticed a couple of issues. I did a search of this thread, and found some others with similar issues, but didn't find any resolutions.
  • Every 1-3 minutes the set will blink. For a single instant, the picture will dim, in a way that reminds me of a blinking your eyes. This issue scares me the most because it's not so bad as to warrant the hassle of replacement, but what if it's a sign of something worse.
  • Some of the "smart dimming" zones appear brighter than others. In an all black scene, with smart dimming off, about 5 of the 16 zones that appear brighter than the others (the 2 lowest ones on the right, the 4th lowest on the right, and 1 or 2 on the left). Again, a livable problem, since it only affects very dim scenes, but in those scenes it creates a blueish cast in that area. Is it leaking light in front of the set?
Just wondering if anyone else has chosen to live with these features, found a fix, or, especially, had the first issue get worse over time.
markiejones is offline
post #1262 of 2132 Old 07-31-2014, 01:26 PM
Citivas's Avatar
Quoted: 317 Post(s)
Liked: 191
Originally Posted by davdoc0011 View Post
Could someone please post the best setting for the 80 in model please!
thanks guys
Just do a search for playnice's settings further back in this topic.
Citivas is offline
post #1263 of 2132 Old 07-31-2014, 03:23 PM
Is it these settings?
ID:	190378   Click image for larger version
ID:	190386   Click image for larger version
Ragonzo likes this.
post #1264 of 2132 Old 07-31-2014, 03:34 PM
josephpearson's Avatar
Quoted: 21 Post(s)
Yes. But he has posted that he's gotten some new equipment and training and anticipates even better results from his next calibration. He has two M801ds, so there may be two different calibrations from him. Good luck. I'm very satisfied with my set's picture.
josephpearson is online now
post #1265 of 2132 Old 08-01-2014, 08:49 PM
PlayNice's Avatar
Quoted: 185 Post(s)
Liked: 174
Here is a fun fact about the M801d, it will accept and display a 4k signal. That's tried and true!
That darn fine print... It will still be 1080p guys.
PlayNice is offline
post #1266 of 2132 Old 08-01-2014, 09:13 PM
NODES's Avatar
Quoted: 652 Post(s)
Liked: 271
NODES is offline
post #1267 of 2132 Old 08-01-2014, 10:33 PM
PlayNice's Avatar
Quoted: 185 Post(s)
Liked: 174
Originally Posted by NODES View Post
I just picked up a new test pattern generator for 4K displays and I thought hey lets try it with some of my equipment. The M801d will accept the incoming signal and display 1080p, my TX NR636 of course will pass through 4K60 however my TX NR818 will not accept an incoming 4K signal but will output 4K. It's interesting to me that this Vizio will take the incoming signal and process it to 1080p.
Ragonzo likes this.
PlayNice is offline
post #1268 of 2132 Old 08-01-2014, 11:11 PM
NODES's Avatar
Quoted: 652 Post(s)
Liked: 271
Are you saying with a 4k capable receiver that passes 4k you get 4k on the vizio? or are you saying the tv takes 4k signal and downconverts into 1080P
NODES is offline
post #1269 of 2132 Old 08-02-2014, 09:29 AM
Stephen1254's Avatar
Hi all,
I had a similar issue with the flickering. Mine would be more frequent than you describe, but then get progressively better as the set was on. Vizio replaced the set, and the new one seems fine. I don't think it is a problem that will go away, and I was concerned it would get worse.
Stephen1254 is offline
post #1270 of 2132 Old 08-02-2014, 04:09 PM
PlayNice's Avatar
Quoted: 185 Post(s)
Liked: 174
I am saying the Vizio will take an I coming 4K signal and display 1080p "of course". But the key thing here is it displays something. Most sets will not respond to an incoming 4K signal at all.
I think this is partly because Vizio is planning to use the same firmware on the native 4K sets they will release shortly.
Ragonzo likes this.
PlayNice is offline
post #1271 of 2132 Old 08-02-2014, 04:17 PM
NODES's Avatar
Quoted: 652 Post(s)
Liked: 271
Thanks for the explanation. I am buying our set on Wed, I cannot wait.
Just received my wall mount today from Amazon so I will get that sucker mounted.
NODES is offline
post #1272 of 2132 Old 08-02-2014, 05:38 PM
bubba1972's Avatar
I am starting to see the tv quickly flicker to all black and come back. It seems to have started since I adjusted the color tuner settings. Has anyone else ran across this and come up with a fix? I already replaced one of these TVs because of a dead row of pixels...
bubba1972 is offline
post #1273 of 2132 Old 08-03-2014, 12:30 AM
NODES's Avatar
Quoted: 652 Post(s)
Liked: 271
do a factory reset and see if it returns?
NODES is offline
post #1274 of 2132 Old 08-03-2014, 07:44 AM
lower latency without Game mode
Game mode is very effective for gaming (duh) - I've tested it and found that both audio sync and input sync are practically instantaneous. I've created nice custom modes for other viewing (starting with "Calibrated"). They look great, but I have to adjust my receiver to delay the audio by 200ms. I'm not sure why the images are that far behind, since I've shut off all fancy features (tru-motion, smart dimming, everything on the Advanced page). What is the "magic" behind the game mode? Is it the fact that uses the Computer color temperature?
The reason it's an issue is that I have to set the audio lag to 30ms for gaming and 200ms for everything else, and it's annoying to go back and forth (it's a slow menu on the receiver). I'd prefer to have the same latency for all sources (all are going through a receiver first).
post #1275 of 2132 Old 08-03-2014, 11:41 AM
PlayNice's Avatar
Quoted: 185 Post(s)
Liked: 174
http://www.cnet.com/news/what-is-game-mode/
Vizio 80" 3D LED M801D-A3 ISF Calibrated | Onkyo TX-NR818 w/ Polk Monitor 50 (Fronts), Onkyo SK-520 (Surronds), SKW-770 (Sub) | Win 8.1 PC i7 3930k, 2 SLI GeForce 770's, 32GB RAM | Mac Mini 2011 i5 2.3Ghz, 16 GB RAM w/ PLEX | Roku 3 | Oppo BDP-103D | Xbox One, PS4, Wii U, Xbox 360 S, PS3 Slim | Harmony Touch
PlayNice is offline
post #1276 of 2132 Old 08-03-2014, 12:53 PM
Thanks for the link! Useful info. Conclusion? I should get used to adjusting lipsync.
Ragonzo likes this.
post #1277 of 2132 Old 08-03-2014, 01:48 PM
PlayNice's Avatar
Quoted: 185 Post(s)
Liked: 174
Get used to? You should only have to do that once. I like the added processing to improve PQ and I have everything running through my AVR so I set it A/V sync once for each input and it's more of a set it and forget it deal.
Ragonzo likes this.
PlayNice is offline
post #1278 of 2132 Old 08-03-2014, 01:55 PM
Sadly, my av receiver (Yamaha RX-V375) has a universal LipSync setting for all inputs. It's not a big deal, but it updates in 1ms increments (rather than 10), so it's a drag, albeit a minor one. I'm going to choose to be happy I have that setting at all .
post #1279 of 2132 Old 08-04-2014, 08:35 AM
blackssr's Avatar
Quoted: 1158 Post(s)
Liked: 578
I believe Sharps also can take a 4K native signal and will down convert to 1080P on some of their sets.
blackssr is online now
post #1280 of 2132 Old 08-04-2014, 04:51 PM
xbones's Avatar
Quoted: 26 Post(s)
I have a Yamaha RX-V371 and notice no lag at all.. I have all my inputs from DirecTV to the gaming systems running to the yamaha and out to the Vizio. I use the yamaha remote to change inputs when I want to switch.
I have no lag for TV or gaming.. I'm wondering if you have your HDMI inputs running to the TV then to the Stereo? If so, did you try changing the digital audio out settings from PCM to Bitstream? There is also a LipSync feature on the TV itself rather than changing the yamaha.
Also how are you able to tell you have lag from regular TV, is it that bad you notice the lips outta sync from the speech?
xbones is offline
post #1281 of 2132 Old 08-04-2014, 10:59 PM
Jasonn B's Avatar
Quoted: 303 Post(s)
Liked: 119
Originally Posted by blackssr View Post
I believe Sharps also can take a 4K native signal and will down convert to 1080P on some of theirs sets.
ANy tv will do this. I had a 720P tv for years and any 1080P would play on it. It's automatic.
80" Vizio LED - (60" Vizio plasma - retired)
Harmony 890 Remote
X10 Commander Iphone App = full control of lights, fireplace, pool, shades, from Iphone
X10 IR543 controller
Hunter Douglas motorized shades
Jasonn B is offline
post #1282 of 2132 Old 08-05-2014, 06:20 AM
Nope - from devices to receiver, then hdmi out from receiver to tv
All devices set to bitstream
I don't think this is in play, since the tv is not part of the audio-loop.
I haven't been watching any of the tv-based sources (such as over-the-air, and apps) yet, so I can't compare. I've been trying to figure out ARC and haven't been able to get it to work. Might need a different HDMI cable. Was thinking of optical link, but I think it won't send bitstream from the apps.
post #1283 of 2132 Old 08-05-2014, 06:27 AM
I'm not sure this is true. Some devices are capable of accepting, then down-scaling higher resolutions, but not all. I've had three 720p sets (two were 1366x768 and one was native 1280x720). The newer ones accepted 1080p, but the older one, circa 2006, didn't ("signal out of range" error).
post #1284 of 2132 Old 08-05-2014, 05:16 PM
mpestrada74's Avatar
Looking for discrete codes for flipping 3D on and off. Do any exist? Tried searching and Googling but no luck. If not, how are you guys switching? I'm trying to make it super simple for my kids to watch 3D all while using a single remote (Harmony 1100).
phildaant likes this.
"my credenza allows me to conceal tech geekiness...while giving a euro cabinet furniture impression... " - jaybrubin
mpestrada74 is offline
post #1285 of 2132 Old 08-05-2014, 06:40 PM
rotohead's Avatar
Quoted: 103 Post(s)
Liked: 54
Only way I can display 3D is using the Netflix app with VIA. Don't have a BR 3D player. Seems to me the 801d auto detects 3D. Netflix asks if you want it in 3D but I think the tv software auto detects the signal. There is a '3D' button in the menu on the tv but it seems only to change other screen viewing options and it doesn't matter if it's 2D or 3D. I am not a big fan of 3D so if this tv didn't have it I would still make the purchase. And I did a quick search on my Harmony acct but didn't see a discrete code for 3D. It may be included with other Vizio model numbers and you could temporarily load those devices in MyHarmony and look for a discrete code. I've found many commands in the more expensive Denon 4308 receiver that weren't showing in my 3808 Harmony profile but were part of my receiver.
rotohead is offline
post #1286 of 2132 Old 08-06-2014, 02:16 PM
Tested the auto-detecting and I couldn't get it to work with movies played via XBMC. I'll try adding other TV models for kicks.
post #1287 of 2132 Old 08-06-2014, 08:32 PM
rougebear's Avatar
Quoted: 24 Post(s)
Here are Calibration setting for the M80. These settings fix the Red error from my previous settings.
The software I was using received an update to fix errors in the readings that were causing me to get incorrect results. Please disregard my previous settings.
Thank you.
So no corrections to greyscale with these settings? Did these work with both TV's? Thanks for taking the time to help out
rougebear is offline
post #1288 of 2132 Old 08-06-2014, 09:02 PM
PlayNice's Avatar
Quoted: 185 Post(s)
Liked: 174
I have actually refined my settings on my main TV the other fine since I don't use it often enough to warrant time to refine I will post my new settings shortly.
PlayNice is offline
post #1289 of 2132 Old 08-06-2014, 09:32 PM
LowBoost's Avatar
Liked: 1
Still debating wether or not should I bite the bullet on this TV set, but the issues that many are experiencing have me worried.
Anyone knows how a Sharp 80" LC650 would compare to this TV?
Recommendations?
LowBoost is offline
post #1290 of 2132 Old 08-06-2014, 11:53 PM
xbones's Avatar
Quoted: 26 Post(s)
I had trouble with Arc as well. So here's what I did and it works..
Under the Yamaha HDMI settings, turn "OFF" ARC, but turn "Control" to "Auto". The TV detects the stereo and turns it on and off and changes audio when using the Smart TV Apps.. However one thing that I can't fix and appears to be a bug with Yamaha receivers is that when the Stereo turns on it defaults to HDMI.. Then after about 5 seconds it changes to AV4.. I couldn't get that to stop, so I just got a Optical cable and plugged it into AV4..
Hope this helps.
xbones is offline
Reply LCD Flat Panel Displays
Vizio M801d A3 80 Inch 3d Led Hdtv
