Tv with no optical out but with headphone jack and spidf out (coaxial) - AVS Forum | Home Theater Discussions And Reviews
Old 07-11-2013, 01:50 AM - Thread Starter
antitheist69's Avatar
I own a TCL LE48FHDF3310TA led tv that does not have an optical out but does have a headphone jack and spidf out (coaxial). I recently purchased the Panasonic SC-HTB20 speakers which require either hdmi arc (the tv also does not support this) or an hdmi in and an optical out. Is there anyway to get the speakers to work with my tv through the two aforementioned jacks? If there is a way, will there be a degradation of sound quality?
antitheist69 is offline
Old 07-11-2013, 05:37 AM
schlick's Avatar
schlick is offline
Old 07-11-2013, 08:21 AM
Ratman's Avatar
Quoted: 1289 Post(s)
Liked: 1028
Ratman is offline
Old 07-11-2013, 09:50 AM - Thread Starter
Also, according to the speaker manual p 19 I need either hdmi or optical out or both (I'm not sure which of the two) to hookup my blu ray player. The problem is that my blu ray player also only has digital coaxial. Does this mean I need to purchase another converter? Do I have to hookup all of my devices to the subwoofer in order to use the speakers?
Old 07-11-2013, 12:32 PM
Rudy1's Avatar
Quoted: 966 Post(s)
Liked: 1280
Connect your Blu-ray player to the Panasonic SC-HTB20 speaker system's AV IN jack using an HDMI cable, then run another HDMI cable from the AV OUT jack to one of the HDMI inputs on the TV. This, along with the Toslink to Coaxial Digital converter for the TV, will give you the best sound possible from both the TCL LE48FHDF3310TA as well as from your Blu-ray player.
ASKHOLE: (n.) A person who constantly asks for your advice, yet always does the opposite of what you told them.
Rudy1 is offline
Old 07-11-2013, 12:55 PM - Thread Starter
After doing this, will I not be able to use other non optical out devices with the speakers, since the subwoofer only has one hdmi in?
Old 07-11-2013, 02:27 PM
Rudy1's Avatar
Quoted: 966 Post(s)
Liked: 1280
True, but devices with optical outputs are more prevalent (at least here in the USA) so you shouldn't have a problem. smile.gif
Rudy1 is offline
