LG 47LM8600 Pausing? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 07-11-2013, 02:12 PM - Thread Starter
Jazz6060's Avatar
Hello:
I have a LG 47LM8600 Television. I've had it since December of '12 and have found it to be delightful and got it for a very reasonable price from Amazon.
I have noticed something recently and was wondering if anyone has any ideas as to what it is and if there is as way to mitigate this issue. I use Comcast cable with a HD DVR and record just about all the programs we like to watch. This doesn't seem to happen all the time and it may be more prevalent on certain channels. The issue is when the camera pans a landscape or a view of a citiscape or something like that, the pan seems to pause or stutters accross as the camera pans the view. I have read through the LGLM8600 owner's thread here and was not really able to find any one discussing this type of issue. Anyway, anyone have any ideas?
Thx.
Jazz6060 is offline
post #2 of 5 Old 07-11-2013, 05:12 PM
mmunro2003's Avatar
Have you try adjusting the trumotion settings?
mmunro2003 is offline
post #3 of 5 Old 07-12-2013, 11:37 AM - Thread Starter
Jazz6060's Avatar
Hi Mmunro2003:
Thank you.
Actually I had no idea about that and much less how to do it. But, after reading through a number of forums and LG website yesterday, I found instructions on this and I have made an adjustment hoping that will fix it. After doing so, I looked throught a number of stations and did not find any pausing or juddering, but I am wondering if it may have been isolated to one channel or program. I will know for sure, because this prgram I record each week from PBS, was where I found this juddering to be most noticable. It will be interesting to see if this adjustment makes any difference for this. I am begining to think this problem may only be with this one channel or program.
Is that possible and why would that be? Well, I will see if the adjustment works for this program this weekend and let you know.
Thank you, Jazz.
Jazz6060 is offline
post #4 of 5 Old 07-16-2013, 03:07 PM - Thread Starter
Jazz6060's Avatar
To All:
I tried the setting corrections and over all, it has enhanced the viewing. I have discovered however, this "judder" seems to be isolated only to our PBS affiliate's HD output. I have no pausing or judder on any other channel, video source, web video, DVD/BluRay, anywhere, except this one station. I am not sure why, but it's tolarable so I will live with it. I do not consider this a problem with the LG.
Thx.
Jazz6060 is offline
post #5 of 5 Old 07-06-2015, 09:22 PM
alexoren's Avatar
Hello,
I have a the same TV and whenever I connect a laptop to it via HDMI and try to stream a movie, the motion on the TV is extremely jerky -- as if it lags and then skips frames to catch up, while at the same time the motion on the laptop's screen (1376x768) is smooth.
If this is the same problem that you are seeing, can you please share your solution?
Thank you!
alexoren is offline
Reply LCD Flat Panel Displays
Lg 47lm8600 Led Lcd Hdtv
