Connected Vizio m420sl to wifi, updated now picture seems milky. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 07-11-2013, 11:43 PM - Thread Starter
ErickJ's Avatar
Well, I thought I just had to connect my tv to my wifi, I've had it for 1year and two weeks, and never even wanted or needed to connect it. I am kicking myself in the butt.
It updated every time I turned it on after I connected it. Now my picture quality seems milky, almost washed out and not sharp. The black level seems great, but the grays seem to almost blend too much. Then I put a game in that I play once a day and the picture looked terrible. Almost undefined and cartoon like. ( I use my tv as a computer moniter. )
I called Vizio, they assured that updating my tv would not effect the picture in ANY way. I explained that it did indeed mess up my picture.
Then they told me I was two weeks too late to have them fix it, or I could hire a company called ITI, to come look at it and attempt a fix for 300$. I only paid 500$. And I paid cash, so no credit card warranty extension.
I reset all the picture and color setting. But it did nothing for me.
Now I come to you guys as a last resort to give me any tips on how to fix my problem. Vizio had no tips other than to have the company come out for 300$.
ErickJ is offline
post #2 of 6 Old 07-12-2013, 02:54 PM - Thread Starter
ErickJ's Avatar
Does anybody have any idea on what I can do?
ErickJ is offline
post #3 of 6 Old 07-12-2013, 03:02 PM
Otto Pylot's Avatar
Quoted: 1363 Post(s)
Liked: 854
Unfortunately this is typical of some Vizios and Vizio support. That's why the general recommendation is to buy a Vizio with an extended warranty. Is there a way to do a hard reset on the Vizio other than resetting everything back to default? I'd disable the WiFi while you're troubleshooting in case the tv thinks it needs to update again.
ErickJ likes this.
Otto Pylot is offline
post #4 of 6 Old 07-12-2013, 03:36 PM - Thread Starter
ErickJ's Avatar
Lesson learned...
So this is pretty common of a vizio? After a update it messes with the picture?
When I do get a lager TV is WILL spring for a extended warranty.
Does anyone have any tips on how to hard reset a vizio?
ErickJ is offline
post #5 of 6 Old 07-12-2013, 05:45 PM - Thread Starter
ErickJ's Avatar
Well, shoot! I was digging in my receipt bin and found the original receipt, But the lady was 100% correct. Sold on 6/30/12 hahaha...
ErickJ is offline
post #6 of 6 Old 07-12-2013, 07:04 PM
Otto Pylot's Avatar
Liked: 854
Lesson learned. In the future, I'd look at other mfrs first, and Vizio last.
Reply LCD Flat Panel Displays
