Do I need to turn on Real Cinema (LG) if both my BD player is set to 24 fps? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 07-14-2013, 06:13 PM - Thread Starter
CGBS's Avatar
I don't know if my TV actually supports 24 fps or if it can just display it
CGBS is offline
post #2 of 4 Old 07-14-2013, 06:25 PM
Otto Pylot's Avatar
Quoted: 1361 Post(s)
Liked: 854
Which LG? I have the LD520 and it fully supports 24p if the source sends it. I leave Real Cinema on. On the 120Hz models, "Real Cinema" takes 24p content and displays each frame 5 times, preserving the natural 24p film cadence.
Otto Pylot is online now
post #3 of 4 Old 07-14-2013, 06:34 PM - Thread Starter
CGBS's Avatar
CGBS is offline
post #4 of 4 Old 07-14-2013, 06:57 PM
Otto Pylot's Avatar
Liked: 854
What does the LG support say or the manual? I would think if it has the Real Cinema option it would support 24fps. Leaving Real Cinema on all of the time, in theory, has no effect on any other material other 24fps if the source is encoded that way. In fact, Real Cinema should be grayed out if you try to set it on any other type of source material. For blu-ray movies, TruMotion off and Real Cinema on.
Reply LCD Flat Panel Displays
