Firmware question Emerson 32" LCD - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 07-18-2013, 04:24 PM - Thread Starter
smokngunslinger's Avatar
I have a 32" Emerson LCD and I need to upgrade the firmware. Model# LC320EM2A
the problem is that i cannot find the firmware anywhere. i can find firmware for LC320EM2 and LC320EM2F but not one ending in A
It asks for the 1st 3 digits of the serial number (ME6) and none of the choices are even close to that serial number.
I toyed with the idea of just downloading the LC320EM2 version but I don't want to brick my TV. Any suggestions? Thanks!!
smokngunslinger is offline
post #2 of 4 Old 07-18-2013, 04:25 PM - Thread Starter
On a side note, all the Firmware selections are all the same file size.
post #3 of 4 Old 07-18-2013, 07:19 PM
Otto Pylot's Avatar
Quoted: 1625 Post(s)
Liked: 1021
Typically firmware updates are region and model specific. The mfrs site should list which models can be updated with what ever firmware version they are posting. If your exact model is not listed, then the update is probably not for you.
Otto Pylot is offline
post #4 of 4 Old 07-19-2013, 01:17 PM - Thread Starter
Bummer. Makes sense though. The reason why I wanted a firmware update is because when I press the source button on the tv or remote, and it cycles through tv, hdmi1, hdmi2, video, and pc, when i select 'pc' the label remains stuck in the upper right hand corner and i have to press the info button to get rid of it. not a big deal really. Just hoped that an update might correct this. Thanks for your help!
Reply LCD Flat Panel Displays
