Best LCD tv between 55"-65" for living room? (budget is $2000ish or less) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 13 Old 07-20-2013, 02:16 PM - Thread Starter
CJ$AS's Avatar
Quoted: 22 Post(s)
Debating still between plasma and LCD but if I go LCD what tv would you recommend that is a good quality tv for my living room that gets some natural light (nothing direct, 4 windows and windows go to covered porch) with seating 15'-17' away. Budget is $2000ish and size I'm guessing 55"-65". Thanks in advance
CJ$AS is offline
post #2 of 13 Old 07-20-2013, 05:44 PM
inky blacks's Avatar
Hi.
I too am interested in a new LED-LCD HDTV. I have a 5 year old 52" LG LCD that stills works great, but the new LED sets look better and are so inexpensive I thought of upgrading. I paid $1,650 for my then top of the line LG on sale, but now you can get a better basic 55" for $800, and even basic models have more features than the best TV 5 years ago.
LG seems to be making new sets with "Google TV" installed, which I was originally interested in until someone posted that every time you fire up the TV you have to sign in to a Google account. If that is true, that is a deal breaker for me.
I have my TV hooked up to my 6 core computer, so what do I need a "Smart" TV for?
I also would appreciate anyone posting news about the latest sets from LG and Samsung. I get over-the-air TV and low speed Internet TV via DLS and have no cable TV or sat box. I am interested in the 55" size. I am more interested in LG and Samsung because they are both known for making better quality tuner chips, which is vital for me. OTA TV looks better than cable digital, and it is free.
inky blacks is offline
post #3 of 13 Old 07-22-2013, 08:11 AM
ivision's Avatar
you may consider Sony KDL-55W802A (LED LCD) or Panasonic TC-P55ST60 (Plasma). Some useful specs comparison can be found, http://www.zimbio.com/High-Definition+Television/articles/7ywxSmq-lte/KDL+55W802A+vs+TC+P55ST60
ivision is offline
post #4 of 13 Old 07-22-2013, 08:40 AM
Artemicon's Avatar
Size is king when shopping for TVs its best to get the biggest TV your living space will comfortable allow without going over and staying within your budget.
You should consider the new LED edge lit Vizio Razor M series. There is a very large thread here regarding the set and it is easily one of the best buys this year for the amount of money per inch you can get. Right now its 1798 on amazon 1649.99 through costco, however you can get it for cheaper if you wait/shop around. I bought my 65" m651d-a2r for 1698 through amazon and while it does have its quirks its by far a fantastic value.
http://www.amazon.com/VIZIO-M651d-A2R-65-Inch-1080p-240Hz/dp/B00CBQNB7K/ref=sr_1_1?ie=UTF8&qid=1374502928&sr=8-1&keywords=vizio+m651d-a2r
A plasma like a TC-P60ST60 will give you the best picture quality you can buy sub 2k priceline in the size you want, however its a plasma and not made for brighter rooms. Long wait for this baby on amazon but other places have it in stock.
http://www.amazon.com/Panasonic-TC-P60ST60-60-Inch-Includes-Glasses/dp/B00AVRJK4Y/ref=sr_1_1?ie=UTF8&qid=1374504256&sr=8-1&keywords=tc-p60st60
There are samsung models in your pricepoint with great quality and features but be warned there are alot of issues with the 7100 series.
http://www.amazon.com/Samsung-UN55F7100-55-Inch-1080p-240Hz/dp/B00BCGROJG/ref=sr_1_1?s=electronics&ie=UTF8&qid=1374504394&sr=1-1&keywords=f7100
When I was shopping for an LCD I ruled LG out because its offerings were not up to par for the price when compared to this years Samsung, Panasonic, Vizio offerings so I don't have any info for you on them.
Artemicon is offline
post #5 of 13 Old 07-22-2013, 09:14 AM
vestaviascott's Avatar
Quoted: 44 Post(s)
Liked: 71
I'll second that. I have the 70" version of this set (Vizio M701d-A3) and its hands down this year's best price/performance champ. Stunning PQ on Blu-ray and very lifelike on Directv HD programming.
In addition to that, until 4k sets become the norm, Its passive 3D performance is among the best available right now.
If you are sitting any further than 9 feet from the set, you should go no lower than 70" if you want the maintain the "WOW" factor and field of view that you get in an actual theater.
My Tech: 70" Vizio M-Series | Apple TV 4 | Harmony Smart Control | Sonos Play1s in Stereo Pair | Echo Dot | Nest Thermostat & Protects | SkyBell HD | Simplisafe
vestaviascott is offline
post #6 of 13 Old 07-22-2013, 12:33 PM
Does anyone have experience with Google TV offered on the LG and other sets?
post #7 of 13 Old 07-28-2013, 12:16 PM - Thread Starter
CJ$AS's Avatar
Quoted: 22 Post(s)
So the best LED-LCD for the $2000ish price range is that Vizio M series?
CJ$AS is offline
post #8 of 13 Old 07-28-2013, 12:18 PM - Thread Starter
CJ$AS's Avatar
Quoted: 22 Post(s)
From the research I've done (as an amateur still learning) how does that Vizio mentioned above compare to these?
Samsung UN60F8000 ($2000) 60 inch
Sony KDL-60R550A ($1498) 60 inch
Samsung UN60F6300 ($1499) 60 inches
CJ$AS is offline
post #9 of 13 Old 07-28-2013, 12:21 PM - Thread Starter
CJ$AS's Avatar
Quoted: 22 Post(s)
CJ$AS is offline
post #10 of 13 Old 07-28-2013, 12:24 PM - Thread Starter
CJ$AS's Avatar
Quoted: 22 Post(s)
How does that Vizio compare to this Samsung that is comparable in price?
http://www.amazon.com/Samsung-UN60F6300-60-Inch-1080p-120Hz/dp/B00BCGRVN0
CJ$AS is offline
post #11 of 13 Old 07-28-2013, 07:05 PM
adgrimes's Avatar
Liked: 27
Only because of your budget and length from tv would I push you away from the UN60F8000 (I have one at 14.5' and absolutely love it). Size REALLY does make a difference more than the "best" screen when at such lengths of 17' IMO. I would focus on 65" as a smaller set to be looking at. Problem is you can find the samsung 65f7100 for almost 2100. The 70" razor does have a pretty good price to it.
adgrimes is offline
post #12 of 13 Old 07-29-2013, 07:48 AM
fritzi93's Avatar
Liked: 41
The OP never explicitly stated that 3D was an important consideration. If it is, the Vizio is an obvious contender. I strongly feel that passive 3D is better, all things considered, than active.
fritzi93 is offline
post #13 of 13 Old 07-29-2013, 10:37 AM
GatorJZ's Avatar
Quoted: 54 Post(s)
Liked: 61
It should be, they license it from LG, the inventor of passive 3D technology.
Samsung UN50HU8550, Vizio P602ui-B3 & Vizio M43‑C1.
GatorJZ is offline
Reply LCD Flat Panel Displays
Sony Kdl 55w802a 55 Inch Led Hdtv , Panasonic Tc P55st60 55 Inch 1080p 600hz 3d Smart Plasma Hdtv , Panasonic Tc P60st60 60 Inch 3d Smart Plasma Hdtv , Vizio M701d A3r 70 Inch 3d Smart Led Hdtv
