Samsung TV – picture shaking with Atari XE or ZX Spectrum – the puzzle for a smart person - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 07-24-2013, 03:04 AM - Thread Starter
Pancho2006's Avatar
Hello,
I got a Samsung LE40M86BD TV set. I connect the set to old microcomputers like Atari 65XE or ZX Spectrum+ via Euro/Chinch/SVideo inputs by proper cables. The TV screen displays good picture but with a vertical shaking effect (constantly). I don't have this problem with Commodore 64, only with Atari 8-bit and ZX Spectrum. I checked other models of Atari and Spectrum and it was an identical symptom (so given model doesn't matter). I checked different cables with different inputs (composite video & S-Video) and this effect still existed. I checked Atari & Spectrum with other television sets (SONY Bravia KDL-32W55 and LG 32LD350) and no problems on these sets. I can't fix the issue with any settings from TV menu, switching sources etc. etc., I tried everything, I turn off every devices in close distance, I check different plugs (a suspicion of noises).
Problem probably is a kind of vertical synchronization issues or something similar. I have a service documentation to this TV set (from this forum) and I can entry into a service menu, but I'm afraid to experiment with settings without knowledge what I should to set (a risk of TV set damage). I would appreciate for any suggestions & help. Thanks in advance.
Firmware:
T-TLPPEUMD-2000
T-BDPMPEUS-1004
BORD2_CALLA_TR-1011
May 22 2007
13:04:57
Pancho2006 is offline
post #2 of 3 Old 07-24-2013, 09:09 AM
walford's Avatar
Is your power line frequency (50 or 60 cycle) match the frequency required by both the TV and the two game units?
walford is offline
post #3 of 3 Old 07-24-2013, 10:15 AM - Thread Starter
Pancho2006's Avatar
Yeah.
Samsung TV - AC 220 ~ 240 V, 50/60 Hz
Atari 65XE's power supply unit (it shakes) - INPUT: 240V ~ 50Hz, 24W, OUTPUT: 5V - 7.5VA
ZX Spectrum+'s power supply unit (it shakes) - INPUT: 220V, 50Hz, OUTPUT: 9V - 1,4A, 12,6W
Commodore 64's power supply unit (it doesn't shake) INPUT: 220V, 50Hz, OUTPUT: 5V - 1.7A, 9V ~ 1A, 18VA
Reply LCD Flat Panel Displays
