Zapped by lightening (or not?) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 07-24-2013, 06:51 AM - Thread Starter
sgbroimp's Avatar
Quoted: 276 Post(s)
Liked: 36
Last night we had a nasty thunderstorm. Saw it coming so I shut entire system down. There was a bolt of lightening and a loud snap which sounded like it was inside the room near the TV, Sony 40XBR6 (You know--- the sound a loudpseaker makes when you fool with the connections with the amp on by mistake!) Power died at same time and was down for about 6 hours. When it came back I feared the worst: HTPC shot, TV shot, etc. etc. Turns out the PC is fine, the TV tunes channels fine, gets signal from the one component device I have, but the issue is this: TV is no longer sensing any HDMI signal from the DVD and PC which share a common cable to HDMI 1 input. Tried moving to HDMI 3, but no joy. Tried both of the devices independently, no joy. Recycled the TV's power by unplugging, no joy. Not easy to trouble shoot much more other than the back of the wall plates (will do tonight) as the cable is in wall and is about 25 feet as it has been for the past 2 years, all fine during that time. Anybody seen anything like this?
Assassin HTPC + Echo, Sony 49XBR850, McIntosh MX151, MC202, MC7104, MS300, B+W 803D2, CWM's, Janus 1W Sub
sgbroimp is offline
post #2 of 7 Old 07-24-2013, 10:00 AM
walford's Avatar
The HDMI receiver chip is the most power fluction sensitive chip in most TVs especially TV models which are several years old. Does your TV power line have a surge protector?
walford is offline
post #3 of 7 Old 07-24-2013, 12:39 PM - Thread Starter
sgbroimp's Avatar
Quoted: 276 Post(s)
Liked: 36
No but I guess it ought to. I am going to try some re-set tactics shown by Sony and others tonight before I throw in the towel. There was no off-on-off to this power outage (My McIntosh Processor is very sensitive to those and kicks out, but did not this time), so I am not sure there was a surge, but I should get the protector, no doubt.
sgbroimp is offline
post #4 of 7 Old 07-24-2013, 12:44 PM
JWagstaff's Avatar
Quoted: 28 Post(s)
Liked: 71
try a new hdmi cable
JWagstaff is offline
post #5 of 7 Old 07-24-2013, 08:25 PM - Thread Starter
sgbroimp's Avatar
Quoted: 276 Post(s)
Liked: 36
Have now done several things: Unplugged the panel and devices as Sony recommends, restarted and retried. No joy. Did master reset as per Sony, no joy. Brought in a PC with HDMI out, used new HDMI cable and tried in 3 of the HDMI ports, having first tested successfully PC with new cable in my other Sony panel. No joy. I am starting to suspect a main board issue. Anyone got another theory?
sgbroimp is offline
post #6 of 7 Old 07-25-2013, 06:57 AM
JWagstaff's Avatar
Quoted: 28 Post(s)
Liked: 71
hdmi board is dead most likely. contact sony they might be able to sell you a new hdmi board or tell you what you can do to fix it.
post #7 of 7 Old 07-25-2013, 11:03 AM
Latinoheat's Avatar
Quoted: 1101 Post(s)
Liked: 842
Same thing happened to a fellow avs member in the plasma section. Same thing a thunderstorm and now everything works but his HDMI inputs, we suggested the same things you have done but in conclusion we believe its his HDMI board as well. So this happened even when everything was unplugged or just shut down? Makes you kind of glad for us that have purchased a surge protector. It warranties against blackout damages.
Media room- LG 4K OLED EG9600, Pioneer Elite VSX-90, Samsung 4K K8500, Klipsch Gallery G28's, Klipsch Sub 12, Klipsch RS-52 II, Optik HD cable
Living room- Sony 4K 79XBRX900B, Onkyo RC-360,HTPC, Klipsch Reference R-62II, Rc52II,PS4
Gaming room -Panasonic ST60, PS3, Wii
Latinoheat is offline
Reply LCD Flat Panel Displays
