Blue motion blur around objects? - AVS Forum | Home Theater Discussions And Reviews
Old 07-26-2013, 11:56 PM - Thread Starter
metallicaband's Avatar
Liked: 100
Hello all,
My friend recently got himself this Sony LED:
http://www.sony-asia.com/product/klv-60ex640
He noticed that when playing video games (PS3) in dark scenes, if you take a a quick look around there's a blue-ish blur around the edge of objects, is this a known issue in LEDs or in Sony HDTVs in particular? I'm more familiar with Plasmas so thought I'd ask for more info here, I tried disabling different settings like the one related to motion and even did a factory reset, but the issue was still there.
Any help would be appreciated.
KRP-500M | Kuro 9G 5020FD + e-lite mod | B&W 683 Fronts | B&W 685 Center | B&W DM601 S3 Rears | HSU VTF3 MK3 Sub | Yamaha RX-V663 AVR
metallicaband is offline
Old 07-27-2013, 05:34 PM - Thread Starter
Liked: 100
Anyone.. ?
Old 07-28-2013, 06:23 AM
johnfull's Avatar
Quoted: 367 Post(s)
Liked: 109
It is not normal, but you are not the first to report it.
Another has mentioned a Sharp set that has purple shadowing on the trailing side of motion.
He's been advised to contact the manufacturer...
johnfull is offline
Old 07-28-2013, 09:50 AM
PlasmaPZ80U's Avatar
Quoted: 1966 Post(s)
Liked: 560
I know the 60Hz Sharp panels used on some Samsung LED-LCDs (like the EH 5 series for example) have been known to have blue/purple motion blur around fast moving objects... 120Hz Sharp panels seem to fare better based on owner reports here
could the Sony be using a sharp panel or perhaps a similar panel tech as sharp?
UN46EH6030 Calibration/Settings
Samsung UN46EH6030; Yamaha HTR-3066, SVS Prime Bookshelf Mains and Prime Center, Cambridge S20 Surrounds, Rythmik LV12R; PS4, Xbox One, Xfinity X1 (CI CXD01ANI)
PlasmaPZ80U is online now
Old 07-28-2013, 02:05 PM - Thread Starter
Liked: 100
Thanks for replying guys, yeah it has that blue-ish trailing thing around edges of objects when taking a quick look to check your surroundings, it only happens in dark scenes if it makes any difference, raising the brightness will eliminate it but that of course will screw up the contrast.
Since it's only a few months old, I'll make sure that he contacts the place he got it from, hopefully they'll either fix it or replace it because it's a pretty annoying effect.
