Samsung Power Cord Replacement - Where? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 21 Old 07-29-2013, 08:13 AM - Thread Starter
Closet Geek's Avatar
Quoted: 164 Post(s)
Liked: 170
I need a replacement power cord for our Samsung flat panel and would prefer not to go the mail order route due to expediency. Are there any box stores that carry this cord?
Closet Geek is offline
post #2 of 21 Old 07-29-2013, 08:58 AM
Ratman's Avatar
Quoted: 1271 Post(s)
Liked: 1022
Without knowing the type of power cord or the model number of the TV, I'd suggest Home Depot, Lowes or your local hardware store. Take the old power cord with you to match.
Ratman is online now
post #3 of 21 Old 07-29-2013, 09:10 AM - Thread Starter
Quoted: 164 Post(s)
Liked: 170
I thought all Samsung tv's use the same cord. Am I wrong about this? The cord was lost/misplaced during a move over the weekend.
post #4 of 21 Old 07-29-2013, 01:44 PM
Ratman's Avatar
Liked: 1022
A power cord is a power cord. They are not brand specific. They follow a type and standard on each end.
For expediency, can you provide the make/model number of your TV? A replacement power cord should be around $5......... if we knew the type of connector on each end (which is probably something I have in my junk cable box in my basement).
Does it look like this?
https://www.andovercg.com/store/Cables/Power-Cords/New-US-Computer-LCD-Monitor-IEC320-C-13-to-NEMA-5-15P-6-Power-Cord-p4367.html
post #5 of 21 Old 07-29-2013, 01:50 PM
waylo88's Avatar
Quoted: 76 Post(s)
Liked: 61
Odds are it's just a basic power cable like Ratman mentioned.
It could also be something like this (this is what my current Vizio is):
500x1000px-LL-6f6cfdd3_DSC_1504.jpeg.
Either way, you could walk into most stores and get what you need for a few bucks.
waylo88 is offline
post #6 of 21 Old 07-29-2013, 02:38 PM - Thread Starter
Quoted: 164 Post(s)
Liked: 170
I appreciate that but its a three slot plug. I know what the cord looks like, I just can't seem to find any retailers that carry it locally. It seems I can only order it, which seems odd to me considering Samsung is a pretty popular brand, especially in the early goings of flat panel displays. Just seems weird to me.
post #7 of 21 Old 07-29-2013, 02:53 PM
GatorJZ's Avatar
Quoted: 54 Post(s)
Liked: 61
For a three prong plug try any computer store.
Samsung UN50HU8550, Vizio P602ui-B3 & Vizio M43‑C1.
GatorJZ is offline
post #8 of 21 Old 07-30-2013, 12:29 AM
alanajqwv's Avatar
alanajqwv is offline
post #9 of 21 Old 07-30-2013, 05:59 AM
Ratman's Avatar
Liked: 1022
Please provide the MODEL number of your TV. Also, why not post the link or a picture of the cord you can only find online.
post #10 of 21 Old 07-30-2013, 07:02 AM
calearne's Avatar
This type of behavior really pisses me off.
People have been trying to help you but your not providing any useful information.
What a waste of time.
calearne is offline
post #11 of 21 Old 07-30-2013, 08:22 AM - Thread Starter
Quoted: 164 Post(s)
Liked: 170
post #12 of 21 Old 07-30-2013, 08:23 AM - Thread Starter
Quoted: 164 Post(s)
Liked: 170
cord.jpg 10k .jpg file
post #13 of 21 Old 07-30-2013, 08:31 AM - Thread Starter
Quoted: 164 Post(s)
Liked: 170
Considering my son has a 19 inch Samsung in his room and the same cord works for both tv's (tried and proven) I was assuming that Samsung power cords were universal. I also assumed that someone out here would have had to replace one for one reason or another by now and would know the type of connector. I appreciate any help anyone has to offer, thanks.
post #14 of 21 Old 07-30-2013, 08:52 AM
Ratman's Avatar
Liked: 1022
http://www.radioshack.com/product/index.jsp?productId=3875423
You shouldn't have to worry about the right angle plug.
post #15 of 21 Old 07-30-2013, 09:00 AM
jjeff's Avatar
Quoted: 687 Post(s)
Liked: 245
It also makes things easier if you provide your location(or nearest large city) in your profile, then we know what stores to suggest.
In my city I'd send you to Microcenter, they have tons of cables with ends like that. You may or may not need the right angle end, depending on how close to the wall your TV is. I think what upset calearne was if you had noted the model number in your OP and maybe even location it could have saved 12 posts.....
As others have noted TVs can have several different ends, the one you have is one of the most common but there are others smile.gif
http://www.microcenter.com/search/search_results.aspx?Ntt=right+angle+computer+power+cord&N=
jjeff is online now
post #16 of 21 Old 07-30-2013, 09:56 AM
waylo88's Avatar
Quoted: 76 Post(s)
Liked: 61
Seriously. Not only that, he's looking for the cord we've been talking about THE ENTIRE TIME! It's a basic power cable dude, not some obscure cable that is exclusive to Samsung. Radioshack, Walmart, Best Buy, etc... You can find one at any of those places. How are you unable to find one locally?
waylo88 is offline
post #17 of 21 Old 07-30-2013, 12:46 PM - Thread Starter
Quoted: 164 Post(s)
Liked: 170
Well I won't further any discussion about my apparent broach of etiquette on this particular thread so I'll leave it at your suggestions are appreciated and useful for me. Thank you.
post #18 of 21 Old 07-30-2013, 12:59 PM
Tulpa's Avatar
Liked: 61
They changed it.
My circa 2006 Sammy DLP uses the older cord like his, while my just purchased (literally last night) Sammy LED uses the newer two pronged one.
OP, you can have my old power cord, but you need to buy my DLP that goes with it. biggrin.gif
Don't believe everything on the Interwebz! A duck's quack DOES echo!
Tulpa is offline
post #19 of 21 Old 07-30-2013, 02:08 PM - Thread Starter
Quoted: 164 Post(s)
Liked: 170
Originally Posted by Tulpa View Post
They changed it.
post #20 of 21 Old 07-30-2013, 02:14 PM
Ratman's Avatar
Liked: 1022
For the time you spent trying to get an answer here, you could have bought one online and had it delivered already. biggrin.gif
post #21 of 21 Old 07-30-2013, 02:21 PM
Colm's Avatar
Liked: 94
Radio Shack, Best Buy, Walmart...
Colm is offline
Reply LCD Flat Panel Displays
