LG FHD LCD 32LD420 Distorted Display - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 08-02-2013, 02:59 AM - Thread Starter
blestab's Avatar
I bought my LG LCD 32inch LD420 TV about 2 years ago and the other day when i switched it on the picture is all distorted and even the on screen display menu is distorted as well. Not too sure what to do and I'm out of warranty now.
Any suggestions will be highly appreciated.
See pictures attached
Pls help
blestab is offline
post #2 of 3 Old 09-13-2013, 12:13 AM
Vaduva Alex's Avatar
Hi Blestab,
Same problem here. I bought same LG model two years ago ( so is out of warranty) and last week suddenly the image became scrambled and after few seconds the image was distorted .
I turned it off, disconnected network cable and unplugged power cord for few minutes. When I turned it on the tv tuner won't pick up channels.
I updated firmware of the tv, no change. Restored factory settings, same problem.
I took it to a friend who works at a TV repair service and the problem was with the tuner. He had to weld again the tv tuner on the main board.
That solved half of the problem. Now I can watch analog tv channels but digital tuner doesn't work: the image is scrambled.
If you found other solution, let me know.
Cheers!
Vaduva Alex is offline
post #3 of 3 Old 09-13-2013, 12:21 AM - Thread Starter
blestab's Avatar
Thanks Alex,
Unfortunately i haven't found a solution yet but i will definitely try having someone knowledgeable look at the turner and see if it works for me.
I will let you know if i do come across another solution.
blestab is offline
Reply LCD Flat Panel Displays
