Vizio vw42l looks like strobe light sounds like helicopter - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 08-06-2013, 08:15 AM - Thread Starter
cpranulis's Avatar
I have a Vizio vw42l that flashes like a stobe light. When this happens there is a flashing blue light on the master backlight inverter and a clicking noise in the center of the power supply. Pwr supply voltages all check out. Also there are two 35Volt 470 uF caps on the master and slave B L inverters that look bulged. If you touch the top of the lower cap on the master the strobing stops. I originally thought there was a cold solder joint so I resoldered the caps. This worked temporarily. I powered off after 2 hrs and powered on just to check. It was right back to where I started. What should I look for next?
cpranulis is offline
post #2 of 3 Old 08-06-2013, 08:40 AM
olyteddy's Avatar
Quoted: 523 Post(s)
Liked: 912
Did you replace those caps? Probably less than a buck apiece.
🔥🔥🔥 Sent from my Samsung Note 7 Using Ove Glove™ 🔥🔥🔥
olyteddy is offline
post #3 of 3 Old 08-06-2013, 09:35 AM
SAM64's Avatar
Liked: 78
is this an LED or is it actually arcing over?
SAM64 is offline
Reply LCD Flat Panel Displays
Vizio , Vizio Inc , Vizio Tv , Vizio Brand
