Sharp Elite pro 70 x5FD - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 08-10-2013, 10:41 PM - Thread Starter
Rivercitylad's Avatar
I can not get my Sharp Elite to turn on. Whan I try to power it up, I only get a BLINKING blue light. The solid blue light will not come on. Need help?
Rivercitylad is offline
post #2 of 3 Old 08-11-2013, 07:51 AM
Sound & Vision's Avatar
Quoted: 147 Post(s)
Liked: 48
It sounds like a Bad Capacitor in the main board. There is nothing you can do about it. I would unplug it and Give Elite Service a call.
This Video kinda explains it?!?
http://youtu.be/RbZncfiOXQA
Sound & Vision is offline
post #3 of 3 Old 08-11-2013, 05:42 PM
pinktri's Avatar
is there a pattern to the blinking blue light? Does it blink fast 4-5 and 2 slower blinks? When this happened to me I could see a looping pattern with the blinking light and relayed this to sharp. They said the pattern of blinks was caused by a handshake issue with my cable box to the elite. I unplugged both units, then turned the TV on then the cable box and it came back up. I have this issue periodically, maybe 2 times every 6 months. Hope this helps
PRO-60X5FD
PRO-70X5FD
pinktri is offline
Reply LCD Flat Panel Displays
Sharp Elite Pro 60x5fd 3d Led Hdtv , Sharp Elite Black 70inch Pro 70x5fd Flat Panel 3d Led Hdtv
