Will Samsung UE40B7020 wall bracket fit Sony KDL-47W805 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 08-11-2013, 03:14 AM - Thread Starter
Fergie79's Avatar
Can anyone tell me if the Samsung made wall bracket I have been using will fit on a Sony TV. The Samsung is four years old and came with the tv bracket which is the style of two small round bits you attach to wall which you hang the wire over when attached to tv. My old tv hasn't come back from engineers yet and had part of bracket on it. I already have the Sony off the warranty. I'm not sure if old tv is vesa compliant.
Fergie79 is offline
post #2 of 3 Old 08-11-2013, 03:38 AM
olyteddy's Avatar
Quoted: 523 Post(s)
Liked: 912
does this help:
http://www.avforums.com/forums/tv-projector-brackets-mounts/1062180-samsung-ue40b7020-swing-arm-wall-mount.html
🔥🔥🔥 Sent from my Samsung Note 7 Using Ove Glove™ 🔥🔥🔥
olyteddy is offline
post #3 of 3 Old 08-11-2013, 03:59 AM - Thread Starter
Fergie79's Avatar
Thanks. Sounds like it shoulf fit. I won't buy another bracket just yet and wait for mine to come back.
Fergie79 is offline
Reply LCD Flat Panel Displays
Samsung
