Switching Cable Box between HD/SD - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 08-13-2013, 05:20 PM - Thread Starter
ffjxc's Avatar
UN60F7050 Running Firmware 1110
When I switch my cable box from HD to SD I get the following:
"check the device is connected properly then try turning on the device by selecting the button below"
Then there is the cable box and an ok box. If you click ok the dialogue box goes away. If you click the cable box. it turns the cable off. When goin
from SD/Hd everything works fine. There has to be a set-up or toggle I'm missing. Has anyone else encountered this and fixed it?
ffjxc is offline
Reply LCD Flat Panel Displays
Samsung Un60d7050
