Programming Samsung SmartTV remote for Direct TV channels - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 08-16-2013, 08:59 PM - Thread Starter
klehnerz's Avatar
We don't have an HD receiver, but picture quality OK with our new flat screen. Using both remotes because we can't get the universal programmed for the direct tv channels. HELP
klehnerz is offline
post #2 of 3 Old 08-16-2013, 09:17 PM
Kib
Kib's Avatar
Quoted: 13 Post(s)
I just purchased a Sammy Smart last week and I believe the channel selection is RF based, not IR, so a typical universal remote won't work.
(NOTE: As I said, I just got the thing and I might be completely wrong. I've not been able to train the the Vizio soundbar I also purchased to respond to the Sammy remote)
Good luck!
Kib is offline
post #3 of 3 Old 08-17-2013, 06:03 AM
foxeng's Avatar
Quoted: 183 Post(s)
Liked: 72
The Samsung smart TV I bought had a IR remote that you place IN FRONT of the device to control. The signal goes from the remote to the TV and the TV sends the correct IR signals to the devices, but they have to be setup so the IR transmitter from the TV gets to the devices to be controlled.
All opinions expressed (unless otherwise noted) are the posters and NOT the posters employers. The poster in NO WAY is/will speak for his employers. "Arguing with an engineer is like mud wrestling with a pig. After a couple of hours, you realize the pig likes it"
foxeng is offline
Reply LCD Flat Panel Displays
