Entry Level Sammy 75 VS. Sharp 80 (240hz) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 08-21-2013, 11:52 PM - Thread Starter
nikunjbhakta's Avatar
Which one has better picture quality.
Viewing with sports and regular cable.
nikunjbhakta is offline
post #2 of 5 Old 08-22-2013, 04:26 PM - Thread Starter
Hopefully I can clarify this.
I would like to know which has the best picture of the two.
Samsung 75" UN75F6300 (Price roughly $2800)
or
Sharp 80" LC80LE757U (Price Roughly $3400)
One is a 120hz (Samsung) vs 240hz (Sharp)
Is it worth the extra $600 bucks to get the five inches and 240?
Essentially which one will have a better picture.
post #3 of 5 Old 09-03-2013, 10:05 AM
garface's Avatar
I'm in the same boat as you. Hope somebody posts their thoughts.
garface is offline
post #4 of 5 Old 09-03-2013, 10:24 AM
PlasmaPZ80U's Avatar
Quoted: 2236 Post(s)
Liked: 685
I think in general Samsung makes a better TV in terms of overall PQ than Sharp but in this specific comparison it's hard to say on specs alone. If you can get an actual Samsung (S-PVA) panel on that 75" F6300 and it doesn't suffer from significant clouding or flashlighting it could be the better buy.
120Hz usually is quite a bit better than 60Hz with motion but the difference between 120Hz and 240Hz is less significant (in general)
Also, if the Sharp uses a Sharp panel and the Samsung uses a Samsung panel, the Samsung panels are the better ones (this is based on comparing Samsungs with Sharp panels to Samsungs with Samsung panels).
One more thing is to check these in store if possible (ideally in a store with dimmer lighting) and using the picture mode/settings you might at home
Current Setup REW FR measures
UN46EH6030 Calibration/Settings
Samsung UN46EH6030; Yamaha RX-A2070, SVS Prime Bookshelf Mains and Prime Center, Sony SS-CS5 Surrounds, Cambridge S20 Rear Surrounds, Rythmik LV12R; PS4 Slim, Xbox One, Xfinity X1
PlasmaPZ80U is online now
post #5 of 5 Old 09-03-2013, 10:25 AM
Liked: 685
also five inches isn't much once you get to the 65"+ sizes
Reply LCD Flat Panel Displays
Samsung 75 Inch Led Smart 3d Hdtv Un75es9000 , Sharp 80 Inch Full Hd Aquos Led Smart Tv
