LED TV SANSUI - AVS Forum | Home Theater Discussions And Reviews
Old 08-22-2013, 11:41 PM - Thread Starter
amitdx's Avatar
i have recently purchased my sansui SJJ24FK led tv. initially for a month, i used it only for my pc via vga...... but yesterday, as i finally got my set top box connected, i am now using both pc (vga) and tv (via av)..... the screen has started slightly shivering ....i dont know how to describe it actually..but...it is something like a few transparent faint lines moving downwards
amitdx is offline
Old 08-23-2013, 04:06 AM
chunon's Avatar
Quoted: 2044 Post(s)
Liked: 1797
Try the led forum
65C6 OLED
Time Warner Cable/Panasonic UB900/ Roku Premiere +/Sony S780 Soundbar/Harmony 650
Calman Enthusiast/Chromapure Standard with Auto Cal
chunon is online now
Old 08-26-2013, 08:13 AM
tubetwister's Avatar
Location: The Outer Limits....Don't trust any air I can't see ☺
Quoted: 1384 Post(s)
Liked: 622
There is no separate LED forum here LCD and LCD/LED are the same except for the backlight and diffuser panels depending if edge lit or back light both operate electrically same same both use LCD panels You are in the correct sub forum don't pay attention to the last post he is in the wrong forum he has a plasma.biggrin.gif. nice one though .
I've also repaired many types of TV's and computers .
and lots of other electronics.
Advertisers and a lot of folks call LCD/LED sets just LED that is incorrect
all LED type sets are LCD panels also . the older LCD sets are actually LCD/CCFL panels The newer LED type are LCD /LED . CCFL and LED only describes the backlight not the panel. both are in fact LCD
That being said are you getting the symptoms on the Both sources The TV input and the PC or is it one and not the other .
Which AV input do you refer to if you are using composite av old style like VCR then you will not get HD picture
Do you have HD cable or Satellite service in which case they should provide a set top box with HDMI cable.
Sounds like you maybe need to contact your provider and upgrade your service and or box to HD and get an HDMI cable .
Only other way to get HD is Over the air antenna or Blue Ray Player or broadband internet streaming via PC or something else
like a roku box If using PC you will need an HD capable PC or video card with HDMI output from PC to TV to do it right VGA is analog .
HD LCD/LED panels do not like std def (old style ) 480i signals and don't play nice with them .
You may be getting R/F interference from STB through composite AV connection also if it is an older one .
In any event your set should be connected to an HD STB with an HDMI cable not an AV cable
check all this stuff out take an advill and call me in the morning biggrin.gif
tubetwister is offline
