looking for new tv - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 08-28-2013, 08:27 PM - Thread Starter
newc33's Avatar
Quoted: 742 Post(s)
Liked: 917
IV been looking around at TVs lately and I think I'm rdy to upgrade.
I'm looking in the 65inch ballpark and would like to spend under 2k
3d would be nice
Also I'd like 240hz.
My current TV is a 47inch LCD vizio. I actually really like my vizio because I belive it was a fantastic value for the price. I'd rather sacrafice a little quality for a little bigger screen I think.
I have been looking into the vizio e series 70 inch razor led 3d TV, however I heard that sharp and some others are superior for only a few hundred more.
Brands like Samsung and Sony and those seem a little out of my price range. There great performers but I'm looking to go for something a little more in the bang for your Buck catagory.
I'd say I'm above average when it comes to TV knowledge but I'm far from an expert so don't get too technical on me hahh
That being said I'm open to all suggestion and any info would be appreciated.
1600 cubic foot sealed room! Samsung 8500 curved 4k
denon x4100
JTR noesis 228s LCR
Ascend acoustics cmt 340se side ss.
ascend acoustics cbm170se rear ss
Quad PSA T18s!!!!!!
newc33 is online now
post #2 of 4 Old 08-30-2013, 07:12 AM - Thread Starter
newc33's Avatar
Quoted: 742 Post(s)
Liked: 917
No one?
denon x4100
JTR noesis 228s LCR
Quad PSA T18s!!!!!!
post #3 of 4 Old 08-30-2013, 07:13 PM
fritzi93's Avatar
Liked: 41
You don't state a preference for active vs passive 3D. Perhaps you should read a few threads on the subject to help you decide. Anyway, I'd suggest passive. The glasses don't need charging and RealD glasses from the theater will work. I own an LG 65" passive and the 3D is very good with no crosstalk. I have a couple dozen 3D Blu-Rays now, but obviously I don't watch them all the time, so just consider that the vast bulk of your viewing will be 2D. Forget cable 3D, it stinks. That said, a 3D Blu-Ray is a nice treat occasionally. You'd need a 3D Blu-Ray standalone player.
If you go passive, you're looking at Vizio in the size you want for under $2,000 bucks. The latest 70" Sony 120 Hz passive 3D model is a little over your budget, as is the Vizio 70" 3D 240 Hz model. Sharp uses active, and while it has a nice picture for the money (I have a non-3D Sharp 70"), it's likely Vizio is using the same panel for its 70" TV. Some will tell you to steer away from Vizio, but their reliability is comparable to the other makers. The Vizio 65" panel likely is still sourced from LG.
I'm not going to recommend LG because my panel developed a tab bond problem (vertical line). I reported it just at the end of warranty, but they jerked me around so much I decided to try to fix it myself. Which I did, successfully. I think Vizio's build quality is just as good anyway, without paying a premium to LG. Anyway, when I bought it, it was one of the very first passive 3D TVs. Out of your budget anyway.
I wouldn't hesitate to go with either the 65" or 70" Vizio. Personally, I'd go 70". I can tell you my 70" vs my 65" is a worthwhile step up in size. You may not think so, but there you are. Also, I wouldn't let 240 Hz be a deal breaker. To me, the advantage is marginal, but others will disagree.
http://www.amazon.com/Sony-KDL-70R550A-70-Inch-120Hz-Internet/dp/B00AWKBZKC/ref=sr_1_1?s=tv&ie=UTF8&qid=1377910234&sr=1-1
http://www.amazon.com/VIZIO-M701d-A3R-70-Inch-1080p-240Hz/dp/B00CHKPYM0/ref=sr_1_2?s=tv&ie=UTF8&qid=1377910234&sr=1-2
In your budget:
http://www.amazon.com/VIZIO-M651d-A2R-65-Inch-1080p-240Hz/dp/B00CBQNB7K/ref=sr_1_2?s=tv&ie=UTF8&qid=1377910592&sr=1-2
Non 3D Vizio 70":
http://www.amazon.com/VIZIO-E701i-A3-70-inch-1080p-120Hz/dp/B009SJNTIY/ref=sr_1_1?s=tv&ie=UTF8&qid=1377910666&sr=1-1
Good luck whatever you get.
fritzi93 is offline
post #4 of 4 Old 08-30-2013, 10:02 PM - Thread Starter
newc33's Avatar
Quoted: 742 Post(s)
Liked: 917
Wow thanks that was a ton of info!
Ill read some posts as recommended, also didn't know there was a difference in the 3d.
denon x4100
JTR noesis 228s LCR
Quad PSA T18s!!!!!!
Reply LCD Flat Panel Displays
Vizio 47 Inch Lcd Hdtv
