Vizio M551d-A2R vs E550i-A0 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 08-31-2013, 06:19 PM - Thread Starter
Padinn's Avatar
Quoted: 26 Post(s)
Hey folks,
I'm very near buying a TV and have basically narrowed it down to these two, though I'm open to other suggestions in the $700-800 range. I really like the look of the M-series and its currently $979 at BJs.
My primary use will be for gaming and netflix, with blu-ray movies and TV following. I do like to watch sports - but its rare, so not a huge deal. 3D isn't really a necessity. I would like a native 120hz panel (which I believe only the M-series is) but the main concern is low input lag for gaming. Smart features are not essential either - I have a Wii U and will pick up a PS4 in November.
Any thoughts? Cheaper is better - I'm basically wondering if the ~$280 is worth it for the m-series.
Padinn is offline
post #2 of 6 Old 09-01-2013, 09:29 AM
Basscadet's Avatar
Hey there - I am also looking at these exact two TV's.
According to CNET, the M551d-A2R has significantly lower input lag than the E-series Vizio. If you go to the CNET site and look at reviews for both TVs, there is a spec sheet that gives the exact input lag times for the two.
I am looking for a TV for gaming only - I don't really care about picture quality that much, I think any TV I could buy in 2013 will fit my needs. I already have a higher end Samsung for my movie watching.
Basscadet is offline
post #3 of 6 Old 09-01-2013, 05:25 PM - Thread Starter
Padinn's Avatar
Quoted: 26 Post(s)
I went with the M series. I'll post thoughts when I get it from Amazon next week.
ivision likes this.
Padinn is offline
post #4 of 6 Old 09-02-2013, 10:12 AM
ivision's Avatar
M series with 240Hz should be better choice for gaming. other side by side spec comparison can be found at http://www.zimbio.com/High-Definition+Television/articles/tFx9VA2qFPM/M551d+A2R+vs+E550i+A0?add=True
ivision is offline
post #5 of 6 Old 02-21-2014, 09:57 AM
drameddie's Avatar
Quoted: 23 Post(s)
How about with the new E550i-B2?
I own the Vizio M602i-B3.
drameddie is offline
post #6 of 6 Old 02-21-2014, 10:29 AM
slyguy10's Avatar
I have the M55 i use it for gaming and TV watching and i love it, input lag is fine and PQ is great to me when gaming. The only gripe i have with the TV (mine) is i have a lot of flash lighting on this set. I am going to bring it back for the M60 but as with any LCD/LED TV its the luck of the draw on how much screen issues you will have
slyguy10 is offline
Reply LCD Flat Panel Displays
Vizio E550i A0 55 Inch Smart Hdtv , Vizio M551d A2r 55 Inch 3d Smart Led Hdtv
