Sharp LC60LE650U/LC70LE650U PICTURE SETTINGS - AVS Forum | Home Theater Discussions And Reviews
post #1 of 35 Old 09-02-2013, 12:29 PM - Thread Starter
Willowgate's Avatar
Hi,
I would like to know the best picture settings for the LC-70LE650U. Is it the same as the 60 inches or the settings are differents for the 70 inches ?
I found 3 sites, but with very different settings, which one is good ?
- http://reviews.lcdtvbuyingguide.com/sharp- lcd-tv/sharp-le650u-picture-settings.html
- http://www.tweaktv.com/tweak-my-tv/ calibration-guide/sharp-lc60le650u.html
- http://forums.cnet.com/7723-19410_102-589931/ sharp-lc-60le650-picture-settings/
I await your response as soon as possible.
Best Regards,
Willow
Willowgate is offline
post #2 of 35 Old 09-11-2013, 02:38 PM
FeeFi's Avatar
I just purchased this TV anyone have an opinion on which one to use?
FeeFi is offline
post #3 of 35 Old 09-18-2013, 08:15 AM
FeeFi's Avatar
By my eyes the Cnet settings are the best for me.  I have not done a disney WOW disk yet though.
FeeFi is offline
post #4 of 35 Old 10-07-2013, 01:34 PM
Darith's Avatar
I have an LC70LE650U being delivered tomorrow from BestBuy as well as the Disney WOW Bluray Disc for calibration. I will keep you updated with my calibration settings.
Darith is offline
post #5 of 35 Old 10-07-2013, 07:04 PM
faibs's Avatar
would love to know too, keep us posted!
faibs is offline
post #6 of 35 Old 10-08-2013, 12:57 AM
SDRANGER619's Avatar
I have also tried all three calibration settings and the Cnet one works best for me. I did tweak the Backlight setting a little. Moved it more to the middle area vs. -6 (or +16 in the other calibration setting).
Can someone tell me what this Disney WOW disc is?
Good luck!
huh?
SDRANGER619 is offline
post #7 of 35 Old 10-14-2013, 05:49 AM
FeeFi's Avatar
It is a basic calibration disc that you can do at home without paying an ISF person to come out.  It won't be as good as an ISF tech but it works for the DIYer's.
FeeFi is offline
post #8 of 35 Old 11-26-2013, 08:14 PM
buckeyegolfer's Avatar
Where does one acquire a Disney wow disc?
buckeyegolfer is offline
post #9 of 35 Old 11-26-2013, 08:22 PM
mole351's Avatar
I'd be interested as well...having this tv (60" though) delivered friday
mole351 is offline
post #10 of 35 Old 11-27-2013, 05:21 AM
FeeFi's Avatar
I got mine from Amazon I assume Best Buy would have it also.
FeeFi is offline
post #11 of 35 Old 11-27-2013, 06:05 PM
ppopp's Avatar
Pixar and Star Wars movies have the THX settings on board in the disc menu. As does any movie with the THX logo.
Disney's Wow disc is more detailed in what it has the user do, but the results are not much different.
ppopp is offline
post #12 of 35 Old 11-27-2013, 07:03 PM
bfssed's Avatar
I did tweak the Backlight setting a little.ttHh8k
bfssed is offline
post #13 of 35 Old 11-29-2013, 07:51 PM
My picture seems grainy. I get weird grey and black pixelated squares during blacks and transitions.
Anyone know how to fix it. It almost seems like I 'm not watching in hd.
post #14 of 35 Old 01-03-2014, 01:32 AM
xjeffreyxnothing's Avatar
Got an update for that disney WoW disc? Any different from the cnet settings?
xjeffreyxnothing is offline
post #15 of 35 Old 01-06-2014, 07:01 AM
csjdmc720's Avatar
is there any update for the settings? I like the TV features but not completely happy with the picture anybody have any suggestions?
csjdmc720 is offline
post #16 of 35 Old 01-06-2014, 11:02 AM
nathan_h's Avatar
Quoted: 1007 Post(s)
Liked: 600
What settings are you using? What don't you like?
Keep in mind that very few will transfer well from set to set. Contrast, brightness often translate well. Color temp moderately. Gamma moderately.
That is why people use the free patterns available on AVS, on THX movie discs, etc, or spend a little on the Disney WOW disk, or better yet Spears and Munsil.
Each panel is different, and your room makes a difference.
____________________
Current theater & gear: "Nathan's Theater in Search of....".
nathan_h is offline
post #17 of 35 Old 01-06-2014, 11:17 AM
csjdmc720's Avatar
I am using the settings from Cnet on the movie av mode, and I am using the ones from Z mad on game mode.Z mads settings were for the 640 but I read where a couple people liked them on the 650.
post #18 of 35 Old 01-06-2014, 11:20 AM
csjdmc720's Avatar
what I don't like really changes from show to show some shows are too bright others too dark and others I can't get the skin tones correct I would really just like to find one setting that works for everything or at least to where I can switch the AV mode to suit the show.
post #19 of 35 Old 01-06-2014, 11:41 AM
nathan_h's Avatar
Liked: 600
To set your expectation correctly, no one mode works for all content because the content providers, especially TV stations, are inconsistent with how they set up things on THEIR end.
That said, the best approach is to get the TV set correctly for an accurate incoming signal. This won't solve the problem of many stations sending you an incorrectly calibrated signal on their end. But you'll be seeing the right thing with quality sources like Blu-ray.
Try the CNET settings in Game Mode. Of the "using someone else's settings approach" these are the closest to correct that I have seen.
When I get my calibrator to visit (probably not until summer) I'll post the results.
nathan_h is offline
post #20 of 35 Old 01-06-2014, 11:52 AM
csjdmc720's Avatar
OK thanks for the information. can you direct me to where I might be able to get one of those calibration disc you were talking about preferably a brick and mortar store I don't really like ordering things off Amazon.
post #21 of 35 Old 01-06-2014, 01:33 PM
nathan_h's Avatar
Liked: 600
Not sure if any brick and mortar stores carry this, but it is the best disk (ie, highest quality) http://www.spearsandmunsil.com/
Here is a run down of others, which you can check for at a local store:
http://howto.cnet.com/8301-11310_39-20060847-285/reviewed-blu-ray-setup-discs-for-your-hdtv/
nathan_h is offline
post #22 of 35 Old 01-06-2014, 02:02 PM
csjdmc720's Avatar
post #23 of 35 Old 01-06-2014, 05:37 PM
csjdmc720's Avatar
is there an app that I can use for a keyboard on my s4 to use with the browser or YouTube
post #24 of 35 Old 02-04-2014, 09:37 AM
slypig6's Avatar
when you read or hear someone mention "Disney Wow" video all they are referring to is a Blue Ray video with LOTS of color. the movie Avatar will provide the same Wow affect . Again - just a high color digital enhanced movie / blue ray.
slypig6 is offline
post #25 of 35 Old 02-04-2014, 09:59 AM
FeeFi's Avatar
Slypig that is really incorrect the Disney Wow disc is a purchasable item that has calibration tools on it.
See: http://www.amazon.com/Disney-WOW-World-Wonder-n/dp/B0045ASBUC
In fact it has a whole thread here on AVSforum:
http://www.avsforum.com/t/1303667/disneys-wow-world-of-wonder-blu-ray-official-avsforum-review
nathan_h likes this.
FeeFi is offline
post #26 of 35 Old 03-04-2014, 08:37 AM
dmesser620's Avatar
I have had mine for 2 months now trying to fix the problem.  When I watch tv shows in HD from Time Warner like 'walking dead" the pixelated squares drive me crazy.  Some of the darker scenes are un-watchable.  When I watch sports or "bright" tv shows the picture is crystal clear I couldn't be happier.  But any programs on any channel from HBO-HD to Fox that have dark scenes all look like this or worse!  When there is a light source like say the moon and the sky is all black.. instead of a natural fade to black it is very blocky.  I took a couple of pictures of what I am seeing.
I did get a bigger TV when I purchased this one.  I sit about 6-8 ft from this 60" tv.  Am I just sitting to close?  My last TV was 55 inches and I never saw anything like this.
Dominic
dmesser620 is offline
post #27 of 35 Old 03-04-2014, 11:51 AM
nathan_h's Avatar
Liked: 600
Not sure how close you are sitting or what brightness and other settings you have configured.
But unless you have some strange settings or a very poor source signal, the TV may need replacement. Does BLU-RAY look like that, too? If not, then it's likely the source and not the TV.
dmesser620 likes this.
nathan_h is offline
post #28 of 35 Old 03-05-2014, 07:55 AM
dmesser620's Avatar
Ok this picture was taken up close to show what I am seeing from 10-12 feet away.  I got out the tape measure last night.  I don't think this a case of being too close as some of the seating in the room is 6-8 feet from TV.  However, I stood in my kitchen a full 22 feet from the tv and you can see all of these pixelated scenes without trying.  I don't believe it is the signal because there are many scenes from that episode that are beautiful but any dark scenes are bad.  I notice this issue on every channel and if I switch TV sets I don't see it, granted the other TV's are smaller 42 inches.
Settings: I have tried every setting posted that I could find from Cnet to tweaktv and some of my own preferences. These do not stop this dark/black object issue from happening.  I have noticed this issues on a Blue-ray DVD as well.  Here are some more examples of what I am seeing, notice the CNN pic is fine... Also look at the galaxy note shot and the way the "rings" of black fade from the light source...  Again if this is normal for this TV then just let me know so I can sell it and be done...
Dominic
post #29 of 35 Old 03-05-2014, 08:12 AM
nathan_h's Avatar
Liked: 600
What you describe sounds like a broken TV.
nathan_h is offline
post #30 of 35 Old 03-05-2014, 02:57 PM
dmesser620's Avatar
I am going to call Sharp support and see what happens.  I will post what ends up happening.
Dominic
Reply LCD Flat Panel Displays
Sharp Lc 60le650u 60 Inch Aquos Led Tv , Sharp He 6 Series Lc70le650u 70 Inch Led Smart Tv
