NEW LG 60LM7200 Setup - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 09-04-2013, 10:14 AM - Thread Starter
chevytwonova's Avatar
Hi i am new to the AVS Forum but i would appreciate if anyone had any input on my current setup.
LG 60LM7200
Pioneer VSK-1021-K
Sony 3D ready blueray
Verizon fios multi room DVR
Definative Audio BI-Amp Front speakers
Definative Audio Center Not sure the model
Definative Audio Pro 1000 sub
Definative audio Pro 800 surround speakers.
In the past i have always just hooked all my components up to the receiver and 1 out the the TV for video.
The new TV i just purchased has me wanting to change this to have the Fios box, and blueray player to directly to the tv so i can use this as a input selector.
Ideally i would like to use the magic remote to control volume on receiver, fios for channels, and dvr functions to make it simple for my wife.
I don't want to loose video quality or sound quality Everything is using HDMI.
If someone could put me in the right direction i would greatly appreciate it.
chevytwonova is offline
post #2 of 3 Old 09-06-2013, 06:46 AM - Thread Starter
Anyone have any suggestions?
post #3 of 3 Old 09-06-2013, 07:19 AM
Ratman's Avatar
Quoted: 1462 Post(s)
Liked: 1159
If the Pioneer doesn't support ARC (Audio Return Channel), then it's best to hook everything up to the receiver as you had before.
If you can’t explain it simply, you don’t understand it well enough – Albert Einstein
Ratman is offline
Reply LCD Flat Panel Displays
Lg 60lm7200 60lm7200 60 1080p Led 3d Tv
