Sharp Aquos 857 Calibrations Settings Only Thread - Page 4 - AVS Forum | Home Theater Discussions And Reviews
 4Likes
post #91 of 91 Old 10-21-2015, 06:38 PM
HTCPBuff's Avatar
Calibrations
Originally Posted by VBB View Post
I would share my settings, but I never bothered to calibrate anything other than Movie mode. The reason being, all other modes will not let you select the Standard color gamut. Only Standard can be properly calibrated.
OK, thanks .. I understand,, it seems that most of the other adjustment I have do just don't look so good either,, I have looked around the other sites and have also found nothing ,, except for the movie mode,, and there are the same ones as on this site... But I'll keep on looking.. Its about time for a new tv anyway.. probably a 4k something or rather.. I have had a problem with Samsun in the past ( great picture but just don't last that long).. (pixel problems)
Thanks for the answer.
CUL
HTCPBuff is offline
Reply LCD Flat Panel Displays
Sharp He Lc 70le857u 70 Inch 3d Smart Led Tv
