Converting or updating lcd TV from USA To australian format - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 09-10-2013, 10:02 PM - Thread Starter
ianlgv's Avatar
Hi can anyone advise if and or how to convert my USa Vizio 32" lcd flat screen TV to Australian Format.?
ianlgv is offline
post #2 of 7 Old 09-12-2013, 09:50 AM
DeltaRaven's Avatar
Hi there,
That is simply not possible, you will need a step down transformer 240v-110v if the TV voltage is 120v only, for that refer to the manual and for the TV channels you'll need a HD Digital Set Top Box, must be HD or else there will be issue with the aspect ratio.
DeltaRaven is offline
post #3 of 7 Old 09-14-2013, 04:20 AM
Ted99's Avatar
Quoted: 444 Post(s)
Liked: 142
I have a 240/110 transformer that I used for this purpose when I was in Australia. It has the proper plugs. PM me if you are interested.
Samsung UN75HU8550FXZA, SEK 3500 OCB in den, Sony XBR79X900B in LR, JVC RS600, Grandview 120" 1.3g curved screen in Batcave Mancave
Polk LSiM703 fronts, RTi-12 rears, LsiC and LSiM 706 centers, T-15 RH, Monitor 60 FW, CSiA1 FH, AT DA-44 TM, ED A6t sides
Two Emotiva XPA-5's for the Beds and TC, BasX-7 for the tops, Marantz AV7702MKII in Mancave until consumer-grade 9.2.6(or better) Pre-pro is available.
Ted99 is offline
post #4 of 7 Old 10-11-2013, 06:32 PM - Thread Starter
ianlgv's Avatar
Hi sorry for long delay replying, I have 110 power supply on my boat already.
All I need is to convert the signal from the TV to display and Australian picture. I get confused between PAL and the other source but as it is an American TV I believe it will be the wrong format for Australia, but I am not sure. I have a digital TV antenna as well.
ianlgv is offline
post #5 of 7 Old 10-12-2013, 08:41 AM
Ratman's Avatar
Quoted: 1276 Post(s)
Liked: 1024
U.S. TV's use NTSC for analog (SD) and ATSC (8VSB) for digital (HD).
Australia uses PAL and DVB-T (COFDM).
Maybe something like these would work:
http://www.world-import.com/samar.htm
EDITED for clarity.
Ratman is online now
post #6 of 7 Old 10-12-2013, 08:56 AM
Steve S's Avatar
Liked: 46
Originally Posted by Ratman View Post
U.S. TV's use NTSC for analog (SD) and 8VSB for digital (HD).
Australia uses PAL and DVB-T.
That's ATSC for US ota, not 8VSB.
Steve S.
Steve S is offline
post #7 of 7 Old 10-12-2013, 09:08 AM
jjeff's Avatar
Quoted: 688 Post(s)
Liked: 245
Most of those are line input PAL to NTSC converters, not the tuner he would need in AUS. Your link does list a few analog PAL tuners to NTSC but my guess is AUS may use all digital like everyone is converting to.
My suggestion is to take your Vizio(which are know for supporting 50hz even though they don't say so) and purchase a digital OTA tuner(or if using cable or satellite their STB).
Again Vizios(and both the ones I have) display 50hz(sometimes referred to as PAL) just fine, they just don't have the DVB-T tuner you might need.
Steve, 8VSB is the type of modulation used in our OTA ATSC standard, QAM is one type of modulation used in ATSC for cable operators.
http://en.wikipedia.org/wiki/ATSC
jjeff is online now
Reply LCD Flat Panel Displays
Vizio 32 Inch Lcd Hdtv E320ar
