How do you watch movies from an External Drive on the LG GA6400 G3? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 09-11-2013, 07:34 AM - Thread Starter
Milew23's Avatar
I have the LG GA6400 G3 smart tv. I bought an external WD my passport drive. When I plug it into the port, the TV sees it but will not play anyting. What do I need to do to be able to view the movies I have on my drive on my TV?
Milew23 is offline
post #2 of 3 Old 09-11-2013, 07:38 AM - Thread Starter
Milew23's Avatar
My friend has one, and he has it plugged into his PC and shares it, I do not have a router so I cannot share persay. Why is there USB ports if you cannot access items on the drive!!!!
Milew23 is offline
post #3 of 3 Old 09-14-2013, 05:02 AM
gilesjp's Avatar
When you plug in the HD go to the home screen, you will will have a notification that the drive is being scanned. Next pan over to the Smartshare area on the far left of the home page. There you will see thumbnails of all your media, select one to play.
gilesjp is offline
Reply LCD Flat Panel Displays
Lg 55 Inch 3d Google Tv Dual Core Edge Led 55ga6400 , Lg Electronics 55ga6400 55 Inch Cinema 3d Led Lcd Hdtv , Lg Electronics 47ga6400 47 Inch Cinema 3d Led Lcd Hdtv With Google Tv And Four Pairs Of 3d Glasses , Lg Electronics 50ga6400 50 Inch Cinema 3d Led Lcd Hdtv With Google Tv And Four Pairs Of 3d Glasses , Lg Electronics 42ga6400 42 Inch Cinema 3d Led Lcd Hdtv With Google Tv And Four Pairs Of 3d Glasses
