Sony 65W850a reviews - Page 126 - AVS Forum | Home Theater Discussions And Reviews
 385Likes
post #3751 of 4871 Old 06-24-2014, 09:34 PM
WhiteSands's Avatar
Quoted: 103 Post(s)
Liked: 462
Here are two older gray screens shots from my TV. I don't worry much about how this looks to me when using a gray test screen. As long as I don't see any problems when watching HDTV or a blu ray movie i'm ok with my set.
Could be some of these manually created gray or white test screen distortions may be caused by the triluminos filters although I have no proof of that.
Name:	Banding Test 005.jpg
ID:	134258   Click image for larger version
Name:	Banding Test 006.jpg
Waylo likes this.
WhiteSands is offline
post #3752 of 4871 Old 06-24-2014, 10:22 PM
Raitzi's Avatar
Quoted: 47 Post(s)
Liked: 29
Originally Posted by Dominant View Post
I have been debating for a while now to purchase the 65W850A. I stopped at Best Buy on the way home from work and had them check on the availability. Noticed that stock was getting extremely low so I pulled the trigger and purchased the 65W850A from Best Buy last Thursday. The Best Buy that I purchased the TV from had to have another store ship their last one over. I showed up at Best Buy today (Tuesday) to take delivery and found out the store that was shipping the TV pulled my name off the set and sold it. They tried searching other stores for stock but found nothing. To make up for the mess Best Buy offered me the 65W950B at cost. I hesitant at first but ended up taking the deal. I take delivery of the 65W950B on July 2nd. Hope I made the right decision.
950b has IPS panel with worse blacks, also I believe it does not have semi local dimming technology of 850a.
Raitzi is offline
post #3753 of 4871 Old 06-24-2014, 10:26 PM
Waylo's Avatar
@WhiteSands that is really interesting. Thank you for the post.
Your screen pics look very much like mine--rounded edges 1/4th of the way from the sides and a few slightly darker bands centrally.
I tend to agree with your rationale! i.e. go watch real video and not test screens!
Anyone else with this finding on their sets, or the ones they returned? I couldn't find many screen shots of this problem on this forum, though quite a few on the 70w850b thread (here's one from that thread--again, NOT a 65w850a http://www.avsforum.com/content/type/61/id/403055/)
Waylo is offline
post #3754 of 4871 Old 06-25-2014, 03:05 AM
WhiteSands's Avatar
Quoted: 103 Post(s)
Liked: 462
Screen shot from my TV.
post #3755 of 4871 Old 06-25-2014, 05:18 AM
guvadc's Avatar
Liked: 62
Mine looks just like WS's. I chose the 850a over the 850b beacasue of the Radial banding like in the link you provided.
If I have to guess these panels are from LG as this looks like its an LG thing. I rember having and returnig an local dimming LG set back in 2009 that had similar banding issues. That one had the "bullseye" patten that you see ppl complain about as well on the 850b.
WhiteSands likes this.
guvadc is offline
post #3756 of 4871 Old 06-25-2014, 07:38 AM
Liked: 2
Originally Posted by dealkb View Post
I got the TV last week from Frys, last one in the box for $1499. I set it up last Sunday. It could detect my home wifi SSID, but after I put in WEP 128 bit security key, it could not connect to wifi. Something worng with the wifi connection for this TV? Everything else works great, the picture is amazing. The wire connection is not really option for the TV where it sits. Can anyone give any suggestions?
Hopefully this isnt too late but if you dont mind me asking why do you still have use WEP encryption?
My suggestion is to change to WPA or WPA2 unless you have some legacy device that doesnt accept it (really shouldnt be the case at this point). To be honest if WEP is your only option it's so un-secure that you almost may as well just make the network Open anyway.
nmasi324 is offline
post #3757 of 4871 Old 06-25-2014, 10:31 AM
GarethKeenan01's Avatar
Originally Posted by Raitzi View Post
Also put motionflow to clear to get better resolution in pans.
Raitzi and others - I haven't tried this yet, but is there a theory (or proof?) that certain MotionFlow (or other) settings help improve the "Dirty Screen Effect" (vertical banding) that occurs when a camera pans across a solid color (like a light green soccer field, for example)? That would be great, if so.
I fear that the answer is "no." Thoughts?
P.S. I tried making my screen brighter per the suggestion of Andy Sullivan (and/or others), but that doesn't seem to diminish the banding issue... really not at all.
GarethKeenan01 is offline
post #3758 of 4871 Old 06-25-2014, 10:39 AM
JOHNNY672003's Avatar
Kdl 65w850a
Opinions please, I am considering buying this set but was wondering how it compares to Samsuung 65F7100 and 65H7150 pic quality wise since those are 240hz and this is 120hz, I had the 65f7100 it had a bad panel and they had no more models so I tried the 7150 series and had freezing and clouding issues so I am going to stay away from Samsung, I was an LG consumer before trying Samsung, would you recommend this over the previous I mentioned? Thanks for your opinions in advance.
JOHNNY672003 is offline
post #3759 of 4871 Old 06-25-2014, 11:15 AM
Waylo's Avatar
Same here...
Waylo is offline
post #3760 of 4871 Old 06-25-2014, 12:22 PM
Stoneguy's Avatar
In my opinion I don't feel any of the motionflow settings will alleviate screen uniformity issues or banding if you will. There is no setting that will make it go away. It is just less evident with a multi-colored background than with a solid medium to light colored background. I would bet every W850A out there has some degree of banding. Some worse than others. It's a question of your tolerance level for this stuff. Coming from TV's that had no uniformity issues has made this hard for me but I am starting to get used to it. Or go buy a plasma while I still can. You can see the uniformity issues on White Sands screen shots. He understands the limitations of the edge-lit design and enjoys his TV as we all know. The positives outweigh the negatives.
Stoneguy is offline
post #3761 of 4871 Old 06-25-2014, 12:23 PM
Raitzi's Avatar
Quoted: 47 Post(s)
Liked: 29
I cannot speak for DSE but generally uniformity can be optimised with gray picture and using brighness and backlight controls.
You can use this to do that : http://s2.postimg.org/sjn23zrfd/gray.jpg
So start with minimum backlight. Put +1 to backlight .You should then see backlight leakage from left and right sides with edge BL TV. Then see what happens with using brightness control when you again increase backlight closer to the setting you might actually use. In short I think there is optimum brightness setting for each backlight setting for uniformity point of view. So play with the two settings until you get uniform picture of gray.
Raitzi is offline
post #3762 of 4871 Old 06-25-2014, 12:38 PM
Liked: 2
Originally Posted by devo96 View Post
It does say that as part of their price assurance but they gave me the adjustment. It might have to do with the fact that I provided a screen capture with the product already in my cart and showing the discounted price.
Thanks Devo! Finally pulled the trigger. I called the sony store today and just after I finished saying Fry's, the representative started laughing and asked if I need a price match. I bet she is getting that all day this week The entire process is smooth as silk: placed order online, gave my cc info and bang! the new TV is coming to me in 5-7 days with a price tag of $1499 excl tax. I got the feeling that the stock is getting low so anyone who's still debating will need to do it quick!!!
W.Z.Y is offline
post #3763 of 4871 Old 06-25-2014, 01:46 PM
WhiteSands's Avatar
Quoted: 103 Post(s)
Liked: 462
You might try these settings as they worked for me. Vivid would be a good choice to see if this helps. These settings also gets rid of the SOE, or soap opera effect.
Turn these to Off below on each of the 3 Picture Modes - Vivid, Standard and Custom.
Noise Reduction,
MPEG Noise Reduction,
DOT Noise Reduction,
Video Area Detect,
Smooth Gradation.
Leave Cine Motion set to Auto which is default.
It's important to leave Reality Creation set to Auto and 'Motionflow to Standard' which is default and works great, especially during pro football games.
Doing this got rid of some banding I was seeing on fast camera panning of the ice rink during hockey games.
post #3764 of 4871 Old 06-25-2014, 02:39 PM
JBrown2292's Avatar
Liked: 2
You're in for a treat!
JBrown2292 is offline
post #3765 of 4871 Old 06-25-2014, 02:44 PM
Liked: 2
Noise Reduction,
Video Area Detect,
Smooth Gradation.
How does the banding look during football (NFL) games? That's what I'll be spending a lot of time doing, are the banding issues noticeable?
nmasi324 is offline
post #3766 of 4871 Old 06-25-2014, 03:51 PM
guvadc's Avatar
Liked: 62
In my experience, I do think certain settings help minimize the DSE effect from the banding.
If I play Forza 5 in game mode with motionflow set to impulse, I notice the banding more. If I turn the motionflow off, the banding becomes less noticeable due the picture being much brighter as the impulse setting dims the picture.
If I use another scene setting other than game mode, it becomes even less noticible.
Please note that I'm saying its less noticible and not eliminated. Really by less noticible I should be saying less distracting.
guvadc is offline
post #3767 of 4871 Old 06-25-2014, 06:20 PM
aguilafan's Avatar
Hi my set just arrived and it is every bit as awesome as it was hyped up to be! One quick question, as I was placing it on the stand I put a finger print at the corner of the screen. What is the safest way to clean the screen for smudges and dust as it is inevitably going to get dirty over time?
I have various screen cleaning products at my disposal, including iKlear which I use on my Apple touch screen products and computers but I'm not sure if that would be appropriate to use here.
aguilafan is offline
post #3768 of 4871 Old 06-25-2014, 06:46 PM
Ph8te's Avatar
Quoted: 4477 Post(s)
Liked: 3896
With the TV off I would recommend distilled water and a microfiber cloth. This is her really the safest way to clean FP TVs.
Ph8te is offline
post #3769 of 4871 Old 06-25-2014, 07:06 PM
kyle76092's Avatar
Originally Posted by kyle76092 View Post
I too just joined the Sony 65W850a club today.
While I do believe the future is 4k, the technology is just too expensive right now with too little viable content to warrant going that route. I'll likely have the opportunity to add another display in 1-2 years and hopefully the 4k options will be more compelling.
BB is holding my unit at the warehouse for another 4-6 weeks until our new house is finished. There are now only 34 units left in the Dallas-Ft Worth region and I was worried if I didn't reserve one now, they might be gone forever.
Look forward to sharing the experience! Thanks for all the suggestions and advice.
Went back to Best Buy today and got the Fry's Electronics price mach. No hassle. Took less than 10 minutes. BB definitely earned my repeat business.
There may be better displays out there. But, for the money, I think this is about as smokin' a deal as you'll ever find. It will be a long wait until our house is ready and I can take delivery.
kyle76092 is offline
post #3770 of 4871 Old 06-25-2014, 07:24 PM
Liked: 0
I ran across this thread in a search today, and decided to finally take the plunge and get a new tv. I ordered it from Fry's for in store pickup, so hopefully I'll be able to go grab it tonight. Will be quite the surprise for the bf.
Sony should give Whitesands a commendation for clearing out their remaining stock. If you could PM me those settings that everyone is raving about, I'd appreciate it greatly.
Nista is offline
post #3771 of 4871 Old 06-25-2014, 08:39 PM
retro124's Avatar
Quoted: 1037 Post(s)
Liked: 751
TV's KDL65W850A are sold out on Sony web also. I have been offered refurbished do you guys have any experience with those? Are they like new or coming with defects? Thanks for responses.
Denon X6200W
Klipsch RF-7II's, RC-64II, RB-81II's, RS-62II's, RS-52II's
SVS 2x PC12-Pluses
Sony XBR65X850B, Oppo 203 (on the way)
Emotiva XPA-200
Apple Mac mini, Sony PS3, Panasonic DMP-UB900
retro124 is online now
post #3772 of 4871 Old 06-25-2014, 09:37 PM
<><'s Avatar
The only setting that got rid of the Soap Opera Effect (or some weird effects while watching Blu-ray) was to set "Motion Flow" to "Off".
My Settings are as follows, very simple:
Scene Select: General
Setting Memory: Common
Picture Mode: Standard
The only Settings I changed from the default are:
Motion Flow: Off
Display Area: Full Pixel
Dynamic Range: Limited
Light Sensor: Off (Basically Eco all off except Auto Shut-off)
Take Care
<>< is offline
post #3773 of 4871 Old 06-25-2014, 09:54 PM
WhiteSands's Avatar
Quoted: 103 Post(s)
Liked: 462
I don't see any banding at all during the live football games. I have seen a touch of motion blur but I overlook it. Like some say, they haven'e made us a perfect set yet.
I did have some motion blur and pixelation back till mid November. I was using my outdoor TV antenna to get the games from El Paso. I did this as the picture was a touch better then when watching the Networks using the Dish Network. I drove myself crazy for a few months trying each of the motionflow settings including Off. Nothing helped and I was ready to swap for another set.
During the first quarter of a game I was watching on Fox from El Paso, I decided to try the dish network FOX channel. Man right off no more pixelation on the fast plays and the motion blur was gone. Man all that stress and all the time it was coming from those El Paso stations including ABC, NBC and CBS.
I do need to tell you anytime you see a replay during a game you will see motion blur and sometimes pixelation. Not to worry that's from the network and is only seen on a quick replay like during a fumble or touchdown.
I have my motion flow set to standard which works great for the games. I do see sometimes the score ticker at the bottom of the screen will jerk some when it first comes on the it smooths out. I can live with that just to have the great flawless game to watch.
You say you spend a lot of time watching the pro games. I don't miss many starting with the rookie games all the way to the the super bowl. My favorites is the championship games then the super bowl.. So enjoy the football season.
nmasi324 likes this.
post #3774 of 4871 Old 06-25-2014, 10:00 PM
WhiteSands's Avatar
Quoted: 103 Post(s)
Liked: 462
I was told by a Amazon customer service that the refurbished sets are sets that have never been sold. They have a scratched or dented cabinet or cover on the back of the set. This defective parts are replaced and the set is completely tested out. The set is then discounted for sale.
Any used set means it had been sold and returned for a exchange or perhaps the customer bought some other set. These set are also fully tested before being sold. With the discounted price it might be a good time to negotiate a extended warranty usually $10 of the TV's sale price.
post #3775 of 4871 Old 06-25-2014, 10:11 PM
WhiteSands's Avatar
Quoted: 103 Post(s)
Liked: 462
Motion Flow: Off
The 'soap opera effect' setting I didn't name on the Cnets list of noise filters was, smooth gradation. Setting that to off was said to get rid of the SOE problem. Some has said it was not enough, so they found by turning off the motionflow fixed the SOE problem.
My worry then would be any motion blur problems during the live pro games.
I did turn mine off months ago when testing and could not clear up the motion blur till I went back to the motionflow, standard setting.
post #3776 of 4871 Old 06-25-2014, 10:36 PM
retro124's Avatar
Liked: 751
I was told by a Amazon customer service that a refurbished sets are sets that have never been sold. They have a scratched or dented cabinet or cover on the back of the set. This defective parts are replaced and the set is completely tested out Then discounted for sale with a full warranty.
Any used set means it had been sold and returned for a exchange or perhaps the customer bought some other set. These set are also fully tested and I would think should have a full years warranty on them.
Thanks for response Sony offer with those only 90 days and then I can buy from 2 to 5 years extended warranty for $120 -$240. So you think it is good deal they are $1320 with tax!!! + free shipping.
Denon X6200W
SVS 2x PC12-Pluses
Emotiva XPA-200
post #3777 of 4871 Old 06-25-2014, 10:50 PM
WhiteSands's Avatar
Quoted: 103 Post(s)
Liked: 462
If they don't have a new set to send out then the refurbished set should be a good choice. After all you have the 90 day return or exchange if needed. One problem is i'm not sure if Sony will be making another shipment of these sets. I would hope so but i'm sure it's hurting their 2014 sales.
You might ask Sony more details like what is a refurbished set. See if it matches what Amazon told me. You might also ask about their return policy but so far I don't remember anyone returning this set for a refund. Some places charges return shipping and maybe a restocking fee.
Sony may cut you a better price if you go with their longest extended warranty.
Good luck on your purchase.
steve1971 likes this.
post #3778 of 4871 Old 06-25-2014, 11:01 PM
retro124's Avatar
Liked: 751
Yes I will thanks for fast response. Let me ask you one question about setting of this tv, are you able to send me those I find it you are real Pro at least what people talking about tv setting,thanks.
Denon X6200W
SVS 2x PC12-Pluses
Emotiva XPA-200
post #3779 of 4871 Old 06-26-2014, 07:39 AM
pdwalg's Avatar
An update: had my 850a a couple of months ago, am using WhiteSands settings. I have never seen such deep blacks in a tv, and the colors just pop.
I am so very pleased with this one! Thanks to everyone who contributes to this forum. You're am awesome bunch.
pdwalg is offline
post #3780 of 4871 Old 06-26-2014, 07:48 AM
Jaysin0901's Avatar
My TV is scheduled to be delivered on Wednesday and I was wondering if a current owner could help me out. I have a pair of Bluetooth headphones that I use with my iPad for when I Netflix a movie late at night. Does this TV have the capability of streaming audio to them? Or do I need to purchase a separate Bluetooth transmitter to plug into the headphone jack of the 65W850A for this to work?
I was unable to connect my bluetooth headphones to this set. I believe the BT connectivity is for keyboards, remotes, etc.
Jaysin0901 is offline
Reply LCD Flat Panel Displays
Sony Xbr65x850a 65 Inch 4k Ultra Hd 3d Led
