Sony 65W850a reviews - Page 133 - AVS Forum | Home Theater Discussions And Reviews
 382Likes
post #3961 of 4854 Old 07-10-2014, 02:21 PM
msjkt's Avatar
TV turns on and off by itself
Hello, my son just called me at work saying the tv is turning on and off by itself. Said he did not touch the remotes.
Being away from home, I just instructed him to unplug the power, and also take the batteries out of remotes.
Has anyone else experienced the same thing ?
msjkt is offline
post #3962 of 4854 Old 07-10-2014, 02:35 PM
Fairfax-Franko's Avatar
Quoted: 13 Post(s)
Liked: 128
I haven't had that problem - but after unplugging the TV for a few minutes he should plug it back in and see if it's back to normal.
WhiteSands likes this.
Fairfax-Franko is offline
post #3963 of 4854 Old 07-10-2014, 02:46 PM
5145's Avatar
Originally Posted by WhiteSands View Post
Few new scenic shots from my TV.
WhiteSands can you please PM me your settings. Thanks in advance.
5145 is offline
post #3964 of 4854 Old 07-10-2014, 03:38 PM
5145's Avatar
Thumbs up
WhiteSands thank you for your settings. I am sure they would work great for me as they have for others. Your help / assistance in this regard is greatly appreciated.
Thanks again.
5145 is offline
post #3965 of 4854 Old 07-10-2014, 04:26 PM
MordredKLB's Avatar
TV arrived today. That box is so big and inviting. Must resist urge to open it until after I move....
MordredKLB is offline
post #3966 of 4854 Old 07-10-2014, 06:39 PM
WhiteSands's Avatar
Quoted: 103 Post(s)
Liked: 461
Here is one of my better scenic screen shots that I have posted in these forums over the last 8 months. This set makes a fantastic picture due to it's many Triluminos colors.
gogent and nedstark like this.
WhiteSands is offline
post #3967 of 4854 Old 07-10-2014, 07:43 PM
rsray's Avatar
Originally Posted by rsray View Post
I usually have mine set to off. I have played around with it set to clear, I don't care for any of the other modes. I can check for the judder on Pacific Rim later on today when I get home. I will let you know what how it looks.
Acermen, I watched that 10 second scene over and over. With it set to clear, sometimes I could see the judder then other times I didn't notice it. So it must have something to do with how the tv processes it. Are you noticing it consistently in that scene? I was setting it to clear using cinema settings. What setting were you using?
rsray is offline
post #3968 of 4854 Old 07-10-2014, 09:15 PM
acermen1212's Avatar
Quoted: 177 Post(s)
Liked: 44
Yes I notice the judder consistently on that scene and others. I am using standard with picture setting at 95, all noise reductions off, Motionflow clear and CineMotion on Auto. I see it a lot on movies on cable and Blu-ray.
I discovered an odd situation with my Comcast X1 cable box. I have a choice of resolutions on the box, 480, 720, 1080I, 1080P 30hz and 1080P 60 hz. When I select the 1080P 30hz the picture on the TV using clear or standard mode gets extremely jumpy like it is almost continuously pausing. Then switching to 1080P 60hz the picture does the same thing. When I go back to 1080I the picture stops the jumping/pausing mode. If I go direct from 1080I to 1080P 60hz the picture is similar to the 1080I except maybe a slight sharper (no jumping picture). It is like the motion flow circuit cannot take the 1080P 30hz signal. I know this is not normal since the previous W850A set that I had with a different problem had no problem handling the different resolutions from my Comcast X1 DVR box.
So my set appears to be defective and Sony has no more new sets to provide me so they offered me the KDL 65W950B but I am afraid I will not be happy with the black levels (TPS panel by LG known for low contrast and black levels). I saw this set in two locations and I got completely different impressions so I am concerned with going with it. The other choices are a repair or a refund but then what do I buy? The 4 K sets will cost a lot more not sure I want to go that route now with very little 4K content available. Thanks.
acermen1212 is offline
post #3969 of 4854 Old 07-11-2014, 07:39 AM
Raitzi's Avatar
Quoted: 47 Post(s)
Liked: 29
Just received this TV(european version 65w855a). Looks amazing so far. Also did some tests on uniformity. Gray uniformity looks ok but there are some darker places but they are really close to frame. Black uniformity is excellent.
WhiteSands. Could you send your settings to me also
Edit: thank you for the settings!
Raitzi is offline
post #3970 of 4854 Old 07-11-2014, 03:16 PM
aktham's Avatar
Hey guys I just bought this TV directly from Sony a few days ago. I tweaked the picture using calibration discs and it looks great when I look at the screen directly. The problem is whenever I look at the TV from any other angle (even slightly off center), the colors look off like there's a purple hue (I thought this was an old LCD problem). Is my set defective or is this a common issue?
Edit: I'm used to Plasmas, but even my computer monitor looks great if I look at it from the left or right.
aktham is offline
post #3971 of 4854 Old 07-11-2014, 03:28 PM
Ph8te's Avatar
Quoted: 3994 Post(s)
Liked: 3184
Could be settings could be he set. All LCDs have a limited cone of "visibility" where picture quality will start to drop off.
Sent from my Flip Phone using DOS
Ph8te is offline
post #3972 of 4854 Old 07-12-2014, 09:05 AM
Liked: 1
Hey, I was wondering if you could PM me your settings whitesands, I just picked this up and it seems that everyone has loved your settings.
Thanks so much in advanced, I appreciate all the help you've been giving!
doublej235 is offline
post #3973 of 4854 Old 07-12-2014, 11:32 AM
bigdaikon's Avatar
The last TV I had ( a phillips) had a small batch of TVs with that same problem. I switched out the set and the next one was fine....for five or six years.
I would switch it out if you still can as I believe it is a control board issue.
-D
bigdaikon is offline
post #3974 of 4854 Old 07-12-2014, 11:34 AM
bigdaikon's Avatar
Whitesands,
Like so many before me, I too, have sent you a PM requesting your legendary settings. Thank you in advance!
- D
post #3975 of 4854 Old 07-12-2014, 11:57 AM
Raitzi's Avatar
Quoted: 47 Post(s)
Liked: 29
Played PS3 today for the first time with this set. Picture quality is great. TV input lag is not bad even with general scene setting with motionflow. At least I was perfectly happy to play Dark Souls 2 with general mode and motionflow in smooth setting. Motionflow really improves the 30fps titles look better almost as fluid as 60fps games. Also there is noticeable picture quality improvement from using general mode instead of "laser fast" game mode.
65 inches F... yeah!!!
Raitzi is offline
post #3976 of 4854 Old 07-12-2014, 02:06 PM
bodean's Avatar
Quoted: 158 Post(s)
Liked: 40
where are these laser fast game mode settings at?
Sony KDL65W850A 65" LED HDTV  || Bose Soundtouch 130 soundbar || Synology DS716+ NAS || XBOX One ||
Xbox Live : BoDEAN
bodean is offline
post #3977 of 4854 Old 07-12-2014, 10:23 PM
Raitzi's Avatar
Quoted: 47 Post(s)
Liked: 29
Game mode in scene selection (input lag is only about 17ms with game mode)
Raitzi is offline
post #3978 of 4854 Old 07-13-2014, 08:11 AM
bodean's Avatar
Quoted: 158 Post(s)
Liked: 40
Thanks. I'll try to figure out how i can have it automatically enable with my harmony ultimate remote, so when I hit "gaming" activity it goes on, and when I hit "watch tv" it turns off.
Xbox Live : BoDEAN
bodean is offline
post #3979 of 4854 Old 07-13-2014, 08:17 AM
cccp simian's Avatar
Liked: 1
The more time I spend with this television, the more impressed I am. Whether exposing the poorest satellite channels, blazing through brilliant blu rays (both 2 and 3D), perfect performance connected to my HTPC, or gorgeous gaming with no perceptible lag and stunning visuals via PS4 and Xbox One... I'm so glad I stepped up to this Sony set.
cccp simian is offline
post #3980 of 4854 Old 07-13-2014, 09:45 AM
Raitzi's Avatar
Quoted: 47 Post(s)
Liked: 29
I think TV should automatically go to game mode if scene selection is Auto and you have HDMI device control enabled. Then TV sees that you have gaming console. At least this works with PS3.
Raitzi is offline
post #3981 of 4854 Old 07-13-2014, 11:54 AM
Liked: 1
Hi Whitesands, Thanks for sharing the settings with me. they really made a difference on my set.
nedstark is offline
post #3982 of 4854 Old 07-13-2014, 12:04 PM
Quoted: 13 Post(s)
Liked: 128
WhiteSands is a legend around here - his settings have contributed to hundreds of finely tuned KDL-65W850A TV's and has in my opinion - achieved the highest Atta-Boy status you can get!
Atta-Boy WhiteSands!
post #3983 of 4854 Old 07-13-2014, 02:47 PM
Liked: 0
Hello WhiteSands,
Our Family just bought the Sony 65W850A at Fry's this afternoon based on the positive comments I found in this forum.
Like so many others...would you send me the settings?
Thank You in advance - Blake
blake4517 is offline
post #3984 of 4854 Old 07-13-2014, 03:30 PM
andy sullivan's Avatar
Quoted: 712 Post(s)
Liked: 386
I hate to sound like a bad guy here, and whitesands is a great guy and friend to all on this thread. But, if you want him to PM his settings to you why don't you just PM him yourself instead of using this thread to do lt?
andy sullivan is offline
post #3985 of 4854 Old 07-13-2014, 04:16 PM
Cayloe's Avatar
I have had this set since March and this is the first time my set is not turning on either by remote or by the button on the set. I have unplugged it for more than the time needed stated in the instructions and still nothing. Does the set not turn on if overheated? Thoughts?
Cayloe is offline
post #3986 of 4854 Old 07-13-2014, 04:19 PM
Quoted: 13 Post(s)
Liked: 128
That's odd - I've never heard of that before. I'm retired and have had my TV on all day and it has never overheated. How long has your TV been on?
post #3987 of 4854 Old 07-13-2014, 04:25 PM
Cayloe's Avatar
Only 5-6 hours straight. It's been on longer at times.
Cayloe is offline
post #3988 of 4854 Old 07-13-2014, 05:05 PM
Quoted: 712 Post(s)
Liked: 386
Try unplugging everything connected to the TV, all hdmi cables etc, including unplugging the TV from the wll socket itself. This will make sure there is no residual electricty reaching the TV. Before you turn everything back on make sure your other equipment is recieving power (ruling out a bad plug or cord). Then just be certain, try a different hdmi input. That's about as cold a reboot possible.
post #3989 of 4854 Old 07-13-2014, 05:48 PM
Cayloe's Avatar
I managed to speak to Sony through there after hours line (239) 768-7604 and was about to be connected with someone that would get me set up with a new set as a replacement but when they went to transfer me they had already closed for the evening. The rep i spoke with did state that they still have the 850As in stock at Sony. Luckily I have an Event # for tomorrow's phone call.
I tried what you suggested and still nothing. Very strange, no red led error flashing light either. Used the set this afternoon for gaming and watched a movie and now it's a brick. I guess this is what can happen when TVs become more complicated with their capabilities.
Thanks for the reply.
Cayloe is offline
post #3990 of 4854 Old 07-13-2014, 06:08 PM
Cayloe's Avatar
Forgot to mention that earlier in the week the set reset back to its factory setting all on its own. I turned it on and it was if I turned it on for the first time.
Cayloe is offline
Reply LCD Flat Panel Displays
Sony Xbr65x850a 65 Inch 4k Ultra Hd 3d Led
