Sony 65W850a reviews - Page 139 - AVS Forum | Home Theater Discussions And Reviews
 385Likes
post #4141 of 4872 Old 07-22-2014, 03:43 PM
squidget's Avatar
looks like I missed out on getting this TV (pretty much sold out everywhere) is there anything comparable to this to get next? I feel at this point I should wait till next year.
squidget is offline
post #4142 of 4872 Old 07-22-2014, 04:12 PM
Ph8te's Avatar
Quoted: 4543 Post(s)
Liked: 3972
If you are in no rush and have a TV that will last you till next year I would wait. That way you can see what's being released at CES and make a decision then.
Sent from my Flip Phone using DOS
Ph8te is online now
post #4143 of 4872 Old 07-22-2014, 04:38 PM
andy sullivan's Avatar
Quoted: 754 Post(s)
Liked: 403
Unless it's Vizio then you can't count on them releasing what they say.
andy sullivan is online now
post #4144 of 4872 Old 07-22-2014, 06:50 PM
squidget's Avatar
I have a sammy plasma from 2009. Picture wise its decent the only issue is the HDMI ports seem to be dying. I get the "no signal from source" message at least once a week where I have to unplug the everything and the TV for 15 minutes then plug back in and it magically works again. Annoying as hell but technically manageable. Right now seems to be a weird time for TVs, we are in between tech and the Sony tvs that have come out this year 850b are worst then their previous (so odd).
squidget is offline
post #4145 of 4872 Old 07-22-2014, 07:44 PM
JacobC1983's Avatar
I seem to have some clouding on the sides of my screen.
And I notice it during dark scenes in movies.
Is this normal?
My Home Theater
JacobC1983 is offline
post #4146 of 4872 Old 07-22-2014, 07:47 PM
Philharmonic's Avatar
To change topic a bit: I need some advise:
I need another 65-70" set. I have a 65w850a which I like. Also have a vizio 80"M which I kept because of good size/cost/performance. I returned a 70" Q+ (S series) because it just didn't have the naturalness of the Sony. What should I get now? Another 850A (assuming I can get one) or can you suggest something better? Is the KDL 950B a better picture ? Does the XBR65X900A provide a better picture when on standard HD? Is its 4K obviously better than the HD on the 850A ????
Philharmonic is offline
post #4147 of 4872 Old 07-22-2014, 09:03 PM
viper04468's Avatar
Is this normal?
What you appear to have is light bleed due to the edge lit design. It's inherent. I have it too, but you can mitigate it a few ways. Turn on scene select sync for starters. I also turned on the light sensor since I'm likely to only notice at night in a dark room.
Next, play with the brightness settings. I'm at 48 with backlight at 4 (when led control is set to low, 2 when led control is off). Try playing around with it and see if it helps.
viper04468 is offline
post #4148 of 4872 Old 07-22-2014, 09:49 PM
MoesArt's Avatar
Tubetwister and WhiteSands, I appreciate your replies.
WhiteSands, I'm pretty confused now. None of what I'm going to write is meant to be argumentative, and I'm sorry to seem like I'm harping on this point but it is my one and only issue with this set. I have a feeling we are miscommunicating. You have lots of experience and knowledge, so I respect your opinions here, but I'm worried I haven't described the problem well to you. I thought you'd immediately know what I was talking about since this DSE/cloudiness seems to be a common problem throughout this thread. Let me see if I can clarify it better this time.
You think I have a bad panel from the problems I describe, but I must've read at least 1-2 dozen other people previously in this thread complain about the exact same problems with a few people commenting these problems are inherent in this set. A few people returned their sets, and others kept them.
You said no vertical banding, cloudiness or DSE should be tolerated on this set. If that were the case, I think most of them would be returned to Sony because I personally believe (the more screenshots I see) that most of them have the DSE.
Given your definition of vertical banding as a narrow vertical white bar most visible during motion, then I take it back... I don't have any vertical banding. You said cloudiness is when the bright LEDs shine through a dark scene. I have some of that, but I'm not sure if the DSE is different than the cloudiness. Why? Because the cloudy pattern is the same size/shape as the DSE pattern. My set looks like it has just 1 problem... there are some slightly darker areas on my set... black background, light background, it doesn't matter... it looks like someone had sprayed a layer of dust on my set (the Dirty Screen Effect).
I've previously referred to the 2 pictures I saw in post #3324 as extremely close to what my TV looks like when there is a solid color background (such as the ones shown in these pictures). These pictures are so close to my set that there's no need for me to take pictures of my own. That poster (guvadc) called it banding, but I would call it cloudiness/DSE.
I've copied and reposted those pictures from post #3324 below as I'm wondering if anyone followed my link to them: Now, would you say that the set in these 2 pictures is a defective panel or is this just typical/normal DSE on a 65W850A?
In spite of this ugly cloudiness/DSE you see in the pictures below, if I play any Blu-Ray (such as Wings of Life) the only time anyone would see the DSE/cloudiness on my set is on clear backgrounds (blue skies, solid green grass, white clouds, white walls, etc.). The other 95% of your typical movie you would think the picture on my set looks perfect (like yours). This is why I'm so torn about returning it. Great 95% of the time, annoying the other 5%. That percentage depends solely on how often there are scenes with solid color backgrounds.
In the post right above mine, someone took pictures of a black screen, and I see yet another blotchy cloudy spot that reminds me of my cloudiness/DSE. It seems like every picture I've seen posted throughout this thread of the 65W850A showing a solid colored background has DSE/cloudiness. This is why I think and wonder if my panel is really defective or actually normal.
Sorry again to harp on this but it's my big issue. I could go back through the thread and collect more links to pictures and posts showing/describing my same problem, but I'm sure you've already seen them. That's why I say I'm confused. You say this problem shouldn't be tolerated and is very uncommon, yet every solid background picture I've seen posted seems to show the opposite. So I'm thinking I must have done a very poor job explaining my problem in prior posts and you think I'm describing a different problem. Hopefully these 2 pictures will clarify.
You said I can compare my TV to most of your better screen shots. Have you ever posted a solid color background (JPG) of your set in this forum? If I were to compare a shot of a lake or a forest (unless there were clear blue sky) I'd expect my set would look identical to yours.
You asked how do I compare my 65W850A to my prior LG 55" and Samsung 52" LCDs (which I did side by side before I moved them around). The 65W850A is so much better looking and vibrant/colorful than my LG and Samsung sets it's amazing... it's a stunning and great picture... EXCEPT when there are solid color backgrounds where I can see the cloudiness/DSE on the Sony. My Samsungs and LG TVs have no hint of cloudiness/DSE. It feels like I upgraded the picture quality but got a new problem (DSE) I'd never heard of before until now.
All I'm trying to determine here is if my panel is really defective or if in fact it's normal and common (as I'm beginning to think).
ID:	175458   Click image for larger version
MoesArt is offline
post #4149 of 4872 Old 07-23-2014, 12:13 AM
Quoted: 754 Post(s)
Liked: 403
I would send it back. To me clouding is a light colored blotch (like a white cloud) on a dark back ground. Like a shot of deep space or the black screen you sometimes get when a TV show is going to or coming back from a commercial. This is caused by light leakage from the LED lights. I think the banding you're seeing is more of a screen uniformity issue and should not be there on a S-PVA panel but often times seen on a IPS panel. Tubetwister and Whitesands certainly know a lot more about this stuff than I do so if I'm wrong please correct me. Can Sony even replace your 65w850a with another new 65w850a? They may have nothing but referbs left. That's one reason I asked in another thread if the 65s990a is similar to the 65w850a except for the curved screen. To my eyes they look a lot alike PQ wise.
post #4150 of 4872 Old 07-23-2014, 01:26 AM
WhiteSands's Avatar
Quoted: 103 Post(s)
Liked: 462
JacobC1983, your set looks the same as mine. The reason here your seeing the edge lit LEDs shine though the black (clouding) is that their running at twice their brightness due to no-signal applied. You can read the text on the screen to see that. A good thing to remember on this set, if their is no HD or blu ray/dvd signal to control the LEDs they run at double brightness. Sony does put up a black screen to protect your eyes and these screen shots show the bleed though or clouding twice as bad as it really is. My set shows the same as yours and without the camera I don't see the clouding with no-signal applied.
The one screen shot of HDMI-1 and the full black screen looks to be taken just before the set has fully booted-up. This again is normal for this set as it's in the process of applying a picture to the screen.
WhiteSands is offline
post #4151 of 4872 Old 07-23-2014, 02:53 AM
WhiteSands's Avatar
Quoted: 103 Post(s)
Liked: 462
MoesArt, yes I get confused as the members here in the forums are using test screens and such to check their sets for DSE on a light or white screen and clouding usually with no signal applied just to see how their set compares to others.
You mentioned to me I think more than once you see these problems on your set with a good signal applied. If so I say your panel is bad. My set plays just fine as long as i'm watching regular HDTV or a blu ray movie. I'm simply trying to compare my set to yours to see if yours has a problem. You did tell me you have a very good HD signal soruce so that's not the problem.
I never have seen any screen shots of your TV other then with a light or gray screen, none with a picture or TV show on the screen to see if this is a problem with your set while watching a TV show. Actually a short video of your screen on some moving outdoor object like I pasted below would make it easier to see the problem. read on..
Your screen shots using white and gray screens. It's your darker gray screen that bothers me most. The darker center on the screen looks like a bad panel to me.
This looks bad enough to be seen while watching a TV show especially when the camera is moving around like panning across the screen. If so this could be what your calling the DSE effect which would be correct.
Be sure to check out the DSE video link for comparison at the bottom of this message.
Here are 2 different levels of gray screen shots from my set for comparison.
Here below from youtube is a TV set in Brasil with a bad panel possibly a LED-reflector problem. This type problem I would call a really bad DSE problem.
I'm not sure what brand TV this is, but look at the blue sky above the plane and across the upper part of the screen when the camera is panning the blue background sky. You can easily see the DSE in this video. That would drive me crazy if I had a set like that.
So if you can see problems like this on your screen I would waste no time in replacing the set.
Try to click the square box in the lower right of the view to go full-screen. Press the ESC key to go back to the smaller screen size. If you want to play this video over and over then press where is says youtube next to the full-screen app.
Name:	Banding Test 005.jpg
ID:	175658   Click image for larger version
Name:	Banding Test 006.jpg
post #4152 of 4872 Old 07-23-2014, 06:07 AM
tubetwister's Avatar
Location: The Outer Limits....Don't trust any air I can't see ☺
Quoted: 1384 Post(s)
Liked: 622
Whitesands knows more than I do especially on the bigger panels he's usually on point .
if one can see something significant on a program I would think it has something wrong .
Glad my real TV is a Plasma ☺ not they don't have their own issues now and then but so far it has been good .
The Sony led is doing good likewise . 2 bad the big panels have so many issues I.m sure Sony isn't alone here
OTOH if Foxconn is fabricating the back lights and assembling the panels who knows they are usually pretty good though AFAIK. They made this Sony,the panel backlight and 2 of my HP PC all screwed together well decent quality and finish and no problems other than a last gen Seagate drive in one PC that took a liking to bad sectors at 2 yrs. I put a new Seagate 3.5" Sata 6 single platter with more cache in there it's faster now pretty fast as metal goes ,good R/W /seek speeds the last gen drives had a high probability of failure early on .
No edge lights in the crib here so thankfully none of that flashlight and cloud business I would be wanting to break
out a can of whoop ass if I got stuck with one of those ! never had to swap out a set so far and I'm pretty picky.
lucky I guess out of 5 sets , good luck with your set .
Did yours turn out to be a Samsung panel ? I couldn't verify nothing with that #
tubetwister is offline
post #4153 of 4872 Old 07-23-2014, 06:31 AM
JacobC1983's Avatar
Thanks for the reply --- I will mess with the brightness settings.
I took these pictures to show the effect I see without a picture on the screen. Pointing it out while a movie was playing seemed difficult.
I see the bottom corners the worst during dark movies. It is clear to the eye - first noticed it during "a good day to die hard"
My Home Theater
post #4154 of 4872 Old 07-23-2014, 10:16 AM
Stoneguy's Avatar
MoesArt, what you are seeing on your TV is an issue that many edge lit LED TV's have. It's a screen uniformity issue. Many W850a's seem to have this issue, exhibited by darker vertical bands mostly prevalent in the middle of the screen. Some people call it banding. Mine has the issue, White Sands has the issue as do others in this forum. The question is how bad is yours and how much does it affect your viewing experience. You mentioned how visible these bands are when you watch golf. I have noticed this as well. Also on baseball. Most HD TV shows and Blu rays you don't see it because there is a lot going on in the background and it becomes less noticeable. It comes down to your tolerance level. For the most part I love the picture on this TV and am getting used to those times when the uniformity affects what I am watching.
Stoneguy is offline
post #4155 of 4872 Old 07-23-2014, 10:48 AM
MoesArt's Avatar
I totally agree with you. WhiteSands (the guy is awesome!) has helped me a lot (in addition to what he's posted here). his screenshots of a gray background show a similar DSE/cloudiness pattern to what I see. People are saying that the cloudiness is a brighter than the background issue whereas mine is a darker than the background issue, so then it's just "DSE". He said it was caused by the Triluminous filter layer. Anyway, you are right that on a normal background it is far less noticeable, but as the pattern doesn't change it's visible against scenes with solid color backgrounds (green grass, blue sky) just as you describe. It's not horrible, and some people didn't even notice it, but I do. It's a slight annoyance that has been bugging me. Once I see it, I always see it because my mind knows it's there. Whitesands suggests returning the set, but I still feel my set is probably pretty average, and seeing Whitesands' set with the DSE pattern helps confirm that. Yes, mine is worse than his, but I've seen other screenshots that are worse than mine (DSE).
Sadly I'm out of time right now, so I'll have to follow this up later with more info. I will eventually post some actual screenshots of my TV, but they look like what's been posted. I'm still probably going to keep the TV (today is my last day to return). I just wanted to see how mine compared to others and if it was defective. Whitesands thinks it is (without having actually seen a picture of my TV), while you think it's typical. Bummer (for me) that I procrastinated so late. I'm going to see if I can get the store to let me do a return/rebuy at the old price to get another 30 days, but I doubt the threat of returning it will work.
MoesArt is offline
post #4156 of 4872 Old 07-23-2014, 11:16 AM
Stoneguy's Avatar
MoesArt, I was going to do an exchange (Best Buy) but at the last minute decided against it. There were too many good things about my TV to take a chance in getting a worse TV. I can always go to Sony (maybe under warranty) if it continues to bug me but like I said, I'm kind of getting used to it.
Stoneguy is offline
post #4157 of 4872 Old 07-23-2014, 02:20 PM
Quoted: 12 Post(s)
Liked: 9
I'm not sure what everyone is getting all crazy about with our KDL65W850a. The Picture on mine is awesome !
I'm watching a newer recorded BareFoot Contessa on Food TV and the picture is unreal!!! Take a look at the cooking channel too. When they zoom in on the food it's so clear you want to eat the TV.
All this stuff on banding etc... Does it really change the picture? I'm not sure... Or are you fishing for problems???
What about Samsung, LG and Panasonic do they have same issue...
http://www.rtings.com/info/gray-unif...een-effect-dse
LDBetaGuy likes this.
montero1 is offline
post #4158 of 4872 Old 07-23-2014, 03:48 PM
Liked: 622
Originally Posted by Cayloe View Post
Update on my 4mo set not powering on...
Had two technicians at my home yesterday for 4 hours and they replaced the two power supply boards on the left. Still no power. They did voltage tests on every conceivable part and discovered that there was no 5 volt current. 12 volts yes. Im not tech savy but the set needs 5 volts besides the 12 volts to function. I spoke with SONY this morning and told them that I am very upset that my 4mo old set stopped working and still doesn't work after they sent 2 parts instead of 3 (main board on the right). It has been over a week and now I need to wait up to 3 more days to hear back from a different department that will decide what to do next. Do they want to send me a new set? Send out the main board and have the technicians come back? I like this set very much when it worked but will most likely want them to reimburse me if they do decide to send out the technicians again to replace the main board. Pic quality isn't the best.
time to break out a can of whoop ass for the folks at Sony ! or the retailer maybe let them have it back
OTOH if you won the Sony panel lottery and got a decent one maybe if they can fix it with another new board that could work also otherwise you are back in the panel lottery taking your chances !
post #4159 of 4872 Old 07-23-2014, 04:16 PM
Liked: 622
Depends on the severity of the symptoms on each individual set that can vary significantly from set to set.
all phatt (large ) panels will have *some banding the trick is getting one without too much banding or other s#it.
Seems to be more prevalent on edge light panels if you get a decent one you won Sony panel lottery consider youself
lucky thay can make real good pictures.
Other brands are also having probs ( they all use outside panel suppliers except *most Samsung and *most LG.they both make panels some for Sony too !
Sony uses mostly AUO AMVA panels in the 8x and 8.5x sets maybe one exception or so.
Samsung SPVA rear lit are in the W600's
Sony 9x , 9.5x sets spread the love and have a little bit of every thing including LG S- IPS
Thin edge light panels are like that sometimes I would say use common sense don't use a grey color to test panel
too severe for any panel to pass test unless you are just looking at grey scale and not color banding .
lotta newbies do that and trip !
Use a light blue maybe 50-75 % REC.709 Blue jpeg or something like that to test maybe white for DSE green or blue for back light uniformity none will be perfect you just want something reasonable and nothing you can see when watching TV .
They ALL look like s#it with no signal rear lights too !
Nothing you want to be OCD about if that's the case get a smaller ~55" or less back light panel,Sony or LG rear lit FALD , or find an old CCFL LCD or consider Plasma while you still can .☺☺
post #4160 of 4872 Old 07-23-2014, 04:48 PM
Liked: 622
[QUOTE=montero1;25985786]I'm not sure what everyone is getting all crazy about with our KDL65W850a. The Picture on mine is awesome !
re/tubetwister
Plenty of of better stuff to watch than that bro you got Netflix ?
Food channels got good pictures and all though just be careful not to watch them to much or you might get labeled or something you feel me bro
post #4161 of 4872 Old 07-23-2014, 05:32 PM
Quoted: 12 Post(s)
Liked: 9
One more thing, If this panel is not good or is cloudy when on a black screen, well than why is it PURE black when you watch a movie that's in letter box for mat?
There's NO white showing on the bottom or top. IT's BLACK
montero1 is offline
post #4162 of 4872 Old 07-23-2014, 05:41 PM
Derbel's Avatar
Originally Posted by Shaun. View Post
Is the vignetting / dark side edges inherent to the w850a or are the few posted here just problem sets? Like I said earlier, I noticed it immediately on a demo set before reading this thread and learning others had the same problem. I know there was an ice rub method to work out the vignetting but it appears to only work for some.
They all have it. I will live with it since this is a good set for gaming. I had to return ones that had bad center banding...there were like three dark columns, and it sucked.
These TV's are made in mexico and have really inconsistent quality. The ones I have now are are nearly free of banding (you can see a slightly brownish center band if you take a pic of a white screen, but not really visible to the naked eye) and do not have flashlighting on dark scenes, but they have dark edges on the left and right, and a couple dark spots on both the top and bottom edge. The ice-rub method does nothing.
I think this is the best gaming TV in a fairly large size available now...nice picture quality, good colors and blacks, and a very low display lag. I will put up with the dark edges until someone makes a 65"+ TV that's better for gaming.
Derbel is offline
post #4163 of 4872 Old 07-23-2014, 06:03 PM
Tiptoe32's Avatar
Liked: 0
Hi WhiteSands
Could you send your settings to me also
thx
Tiptoe32 is offline
post #4164 of 4872 Old 07-23-2014, 07:24 PM
Cyrk's Avatar
Just picked up mine from Frys! WOW looks great so far, hooked up my HTC660 Sound bar. Picture looks great have not touched a thing on it yet... Look forward to messing with it and enjoying more. I am coming from a 61" Samsung DLP.
Cyrk is offline
post #4165 of 4872 Old 07-23-2014, 09:57 PM
MoesArt's Avatar
Quick update (mainly to WhiteSands and stoneguy)...
I think I worried and fretted so much about the DSE on this TV that I burned myself out and lost the energy to mess with it any further. I was too tired after getting home late today to try to pack it up and return it in the final few hours, so to quote Doc Brown I said "what the hell" and decided to keep it in spite of its annoying DSE issue.
I watched some scenes from Frozen Blu-Ray (like the blizzard near the end on the frozen ice), and the DSE is very clearly visible at several parts. You tend to see the vertical dark bands more than the central "cloudy" area, so it looks like 3 giant fingers (very faint though) when you get a snowy white scene. After it was frequently mentioned that the DSE should be more visible with motion, I started seeing it on non-solid backgrounds too when the camera was panning, but I gave up fighting it. It's still a pretty nice picture and I'm going to hope I can train myself to ignore the DSE somewhat. It doesn't bother anyone else in the family but me.
I'll work on some screenshots in the near future or maybe a video someday, but I'm not sure how visible the DSE will be to others except as a still screenshot. On that Youtube "Brasil" airplane video WhiteSands linked to, I watched it several times and could just barely make out a few instances of DSE. There's no difficulty making the DSE lines out on my set, but capturing them on video could be tough. Either my set is worse than the "Brasil" airplane video set or the Youtube video doesn't do the DSE justice. I think I see dark or fuzzy spots pop up here and there, but I think it's the compression.
I'm pretty convinced now that all 65W850A TVs have the DSE/cloudiness, but that the pattern and magnitude of the dirty/shadowy area varies greatly. I think my DSE is probably worse than average, but as I've said before I tried 2 new TVs at the store a few days after I bought it and those 2 TVs had equally bad DSE. It would've probably taken a few more sets until I got lucky enough to get one with substantially less DSE (and no bad pixels), and no store wants to let someone go through that many sets (though when you check them in-store they can wrap the sets back up and they probably still sold those as new though both sets had bad pixels so I couldn't imagine anyone would've keep those 2 sets I tried).
Now that I'm committed/stuck with this set, prepare to see some dazzling TV deals soon which I'll wish I had waited for. Since I supposedly have 60 days of price protection left with the Discover card, I don't expect the price to drop on this set (anywhere that has them left) for another 61 days. I believe/hope the Discover price protection covers the entire Internet and not just B&M stores?
MoesArt is offline
post #4166 of 4872 Old 07-24-2014, 04:34 AM
*UFO*'s Avatar
Quoted: 465 Post(s)
Liked: 361
Yes, all other brands suffer from DSE and clouding. It seems especially obvious on the w850a though, and that is most likely due to the fact that the picture quality is so good. With its saturated colors, high contrast, and good black levels, any imperfections really present themselves. Compared to an IPS panel that has DSE, the poor contrast and black level are more distracting. Its like staining a brand new white shirt.
FiloD and tubetwister like this.
*UFO* is offline
post #4167 of 4872 Old 07-24-2014, 06:07 AM
Raitzi's Avatar
Quoted: 47 Post(s)
Liked: 29
Here are my Netflix settings that I adjusted aiming to maximise "on screen contrast" and definition without too bad side effects.
I used "Hansel & Gretel: Witch Hunters" for contrast and reality creation adjustments and "G.I. Joe: Retaliation" for adjusting shadow detail color.
The reason I don't use dynamic contrast booster is that it just darkens dark scenes and brightens bright scenes. I wanted really candles and camp fire to pop out while maintaining good black level.(key components in this are brightness control, black booster, and gamma +1 to make those candles pop out in dark scenes)
General scene:
Backlight:Max
Contrast:Max
Brightness:47
Color:60
tint:0
color temp: Neutral
Sharpness:48
Noisefilter: off
MPEG noise filter: off
Dot noise filter:auto
Reality creation: Manual
video area detection: off
resolution:45 (more than this will start to look grainy)
noise filtering:min
Smooth gradation:low (helps if original content is showing gradiation bands in sky e.g)
motionflow :standard
film mode:auto
Black corrector: medium
contrast enhancer: off
gamma:+1
led dynamic control:standard
auto light limiter: off
clear white: off
live color:low
White balance:blue bias -2 (removes tendency for blue shadows if issue with your set)
detail enhancer: off
edge enhancer: off
skin naturaliser: off
(I used WD TV streaming box instead of internal netflix app to gain access to all the settings)
Raitzi is offline
post #4168 of 4872 Old 07-24-2014, 09:13 PM
Liked: 622
Raitzi
I do not own an 8x or 8.5x sony but a 2013 set your seeings should look pretty good with about any Sony I can think of though
what would you think about these settings in Cinema 1 or 2 or whatever the 8.5x has ? maybe a few points of brightness in daylight in cinema ? I've had good luck in the cinema /movie modes ( re adjusted much like the above ofc ) in that the colors were more realistic and natural and sometimes tamed down any color pushing and the gamma seemed to fall in line for shadow/black detail w/o crushing blacks or being overly bright . I wonder how the 8.5x is set like that ?
* forgot to add my set looks very good with very similar settings in general also just a little more detail in cinema and less blooming but it can also boil down to source and individual preference at the least also .
post #4169 of 4872 Old 07-24-2014, 10:39 PM
bodean's Avatar
Quoted: 170 Post(s)
Liked: 42
I agree, go with Cinema 1 or 2
Sony KDL65W850A 65" LED HDTV  || Bose Soundtouch 130 soundbar || Synology DS716+ NAS || XBOX One ||
Xbox Live : BoDEAN
bodean is offline
post #4170 of 4872 Old 07-25-2014, 12:38 AM
Raitzi's Avatar
Quoted: 47 Post(s)
Liked: 29
I mus try out cinema mode more
I put settings from French review to cinema 1. I think usually "calibrated" settings to cinema can seem too red to me when they usually use warm 2 as color temperature.
Raitzi is offline
Reply LCD Flat Panel Displays
Sony Xbr65x850a 65 Inch 4k Ultra Hd 3d Led
