Ultra Slim bezel TVs...need ideas - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 09-23-2013, 01:38 PM - Thread Starter
cleland500's Avatar
I've got a fairly specific situation in my den. I've got a mantle above the gas fireplace and to either side it is drywalled/framed in. We have an older 50" Panasonic plasma up there currently. I'd like to get the largest screen size I could in the opening, which is why I'm looking at TVs with the slim bezel. I've got plenty of depth and height to go larger, the problem is width. My max width is 52.75", I've been scouring the interwebs smile.gif for awhile now and I've come up with a couple TVs that might work. They don't have the best reviews but they would fit really nice and for my wife they'd be fine. The LG would be a really tight fit, according to the specs I've found I'd only have .10" to work with. I'd like to stay under $2k if possible, does anyone have any others they could suggest?
Panny TC-L58E60
LG 60LA8600
cleland500 is offline
Reply LCD Flat Panel Displays
Panasonic Tc L58e60 58 Inch Smart Led Hdtv , Lg Electronics 60la8600 60 Inch Cinema Screen 3d 1080p 240hz Led Lcd Hdtv With Smart Tv Built In Cam
