Using KDL-60R520 in Europe - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 09-23-2013, 02:46 PM - Thread Starter
farif2's Avatar
I got this TV from Costco.ca. The TV itself is awesome but strangely it says 120V and 60Hz only. I have a old Sony LCD and a LG Plasma and two smaller Samsungs. ALL are multi voltage and multi frequency (meaning 110-240V and 50/60Hz). This is the first TV that I see as a 120V and 60Hz only. I called customer service but they seemed clueless and I got the normal "No you cannot as its 60Hz required. Danger Danger........
My issue is that I am moving to Africa and buying a TV there is close to impossible. I have to take one with me. I have a PAL to NTSC converters (HDMI) and I am told that the Satellite receivers there can output to HDMI. Sooo....the only issue is voltage
Has anyone used a 120V and 60Hz TV on 120V BUT 50Hz? Any issues.
There are no motors or so in a TV sot theoretically I feel it should work, but theoretically any switching power supply (like in all flat panels) should be 50/60hz anyway. Why is Sony particularly stating NO YOU CANNOT
Anyone having some actual experience?
farif2 is offline
post #2 of 3 Old 10-02-2013, 06:46 AM - Thread Starter
farif2's Avatar
Anyone?
Does anyone has experience using a 60Hz only TV in Europe with a transformer?
farif2 is offline
post #3 of 3 Old 10-02-2013, 11:08 AM
iBrad's Avatar
You won't have a problem as long as you don't fed 230V AC into 120V directly, without a step-down power transformer.
Power supply electronics are analog nature and will fluctuate regulary, there is yield range of about +- 5% to 10-20% etc.
I use here a 230V/50Hz AC to 110V/50Hz AC, 75W step-down transformer with a 110V/60Hz NTSC DVD player without any problem.
SONY is covering theirs, in case something goes wrong outside the specs.
iBrad is offline
Reply LCD Flat Panel Displays
Sony Kdl 60r520a 60 Inch Led Tv
